| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#43 | |
Drives: '23 BRZ Limited
And someone who has never been to the track and been with an instructor, or had an instructor drive their own car, aren't pushing the car nearly as hard as they think they are.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | vindiesel (06-28-2023) |
#44 |
Drives: 2022 Subaru BRZ
I did one autocross event post-pressure instrumentation, so I can take a deeper look at that data. It was difficult to parse because I forgot to set up the Aim in a point-to-point mode vs circuit, so I ended up with a lot of laps put together and there are expected pressure drops as I’m waiting for the next run.
#46 | |
The primary goal of my initial video was just to point out that this problem is observable with the right instrumentation and that I believe these pressure drops are cause for concern. Everything beyond that is an unproven hypothesis. |
#47 | |
Drives: 2022 BRZ
Yeah, that is really strange. @KillerBMotorsport, is that a timing cover you pulled from an FA24? How crazy would it be if Subaru somehow used the wrong drawing or there was some manufactoring mistake and those ribs were accidentally excluded. |
#48 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
There are other slight difference apart from the missing ribs as well. |
#49 | |
Drives: Toyota 86
6 months old video is there.
#50 |
Drives: 2015 FR-S
Do you have a link to this technical changes document?
#51 |
Drives: 2015 FR-S
Gen1 vs Gen2 upper oil pan
Its really the design of the upper oil pan/oil pickup (not timing cover) that's the defining difference between the oil sloshing movement on track. the first 2 pics on the Gen2, you can see that there's a huge void in the upper oil pan as well as the way the oil pickup is skinny right where it goes into the timing cover that provides a huge passage for oil to move into.
Compare that to the Gen1 picture (my car with killerB pickup) the giant casting and giant oil pickup mating surface basically blocks the majority of the pathway for oil to get into the timing cover. The casting and mating surface of the oil pickup is also at a lower level (mating surface level of the lower oil pan) which would act as a lower baffle just by itself. |
| The Following User Says Thank You to FrickingReallySlow For This Useful Post: | NoHaveMSG (07-03-2023) |
#52 | |
| The Following User Says Thank You to Blighty For This Useful Post: | Luns (11-12-2024) |
#53 | |
Just trying to understand what going on. Because it does look like its not the FA24D timing cover as detailed by Subaru anyway. The upper oil pan is a little more difficult to properly match from the documentation as its a weird angle, but it looks far more similar (even though they do note a few changes to it as well). |
#54 |
Drives: 2023 brz limited 6mt red
Doesn't’ the wrx using the same engine essentially. Shouldn’t they have the same if not worse problems then the brz given the oil lubricates turbo as well plus more heat? (I know less people autocross these as well)
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
#55 | ||
Drives: '23 BRZ
I had local Subie dealership (with great techs who are knowledgable enthusiasts) inspect for RTV, they found a bit (small amount relative to some pics I've seen) but enough that they agreed that inspection/removal would be warrantied. I just ran NJMP Lightning on Monday/Tuesday (won my class in time trials!), which has both an extended and banked right-hander (turn 9) as well as two right-handers with big elevation changes, turns 1 and 5 both are sharply uphill from turn-in up to a peak near apex and then sharply downhill. I tried to minimize laps throughout the event while ensuring I was on top of competition who was lapping 2x more than anyone else! Looking forward to seeing results with the baffle... Last edited by ZDan; 06-29-2023 at 11:33 AM. |
#56 | |
| 2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 0 | 11-18-2022 06:15 PM |
| Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp | KillerBMotorsport | BRZ Second-Gen (2022+) — General Topics | 50 | 10-29-2022 08:36 AM |
| High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 10:51 AM |
| FS: NEW Bluemoon Oil Baffle & Killer-B pick up tube. | FRSH86 | Engine, Exhaust, Bolt-Ons | 2 | 04-20-2020 11:49 AM |
| Compatibility: Moroso Baffle and Killer Bee Oil sump | Nightflo | Engine, Exhaust, Transmission | 3 | 04-27-2019 10:40 PM |
