Old 04-05-2023, 02:58 PM   #43
M0nk3y
Originally Posted by kask2_6.0 View Post
It has been a little slower than anticipated on the manufacturing side but they are coming along. I currently have 20 sets at powder coat I'm waiting to get back. Then they will be available!
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
kask2_6.0 (04-06-2023)
Old 04-06-2023, 10:38 AM   #44
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Custom made louvers
Just posted this in my Journal. See details there.
I have yet to have a heat issue, but I haven't done a really hot day at the track either. I do have the long tube Nameless headers and want to get some of their added heat out.
BTW, that's just my "street splitter" and street gargoyle that's on the car.
Scargod is offline   Reply With Quote
Old 04-06-2023, 11:26 AM   #45
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Originally Posted by GrandSport View Post
I do now (took me a while but I figured it out) but after a 30 min session in texas summers, it still happens.
The club I track with in Ireland run an open pit lane format. I think the max amount of track time one could have is like 6 hours haha.
So I have stuck to just doing a handful of laps then coming in to let things cool down. I am hoping this saves me from the need to update coils and major cooling updates.
I will be switching my coils and harness if my method doesn't work lol
autoracer86 is offline   Reply With Quote
Old 04-06-2023, 08:09 PM   #46
Goosfraba121
Goosfraba121's Avatar
Drives: 2013 Subaru BRZ
so where can we order em up :P i wanna get in on the first 20. got FB messenger or anything?
Goosfraba121 is offline   Reply With Quote
The Following User Says Thank You to Goosfraba121 For This Useful Post:
kask2_6.0 (04-07-2023)
Old 04-06-2023, 10:51 PM   #47
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
In to order
SkyeHack is offline   Reply With Quote
The Following User Says Thank You to SkyeHack For This Useful Post:
Old 04-07-2023, 12:12 AM   #48
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by SkyeHack View Post
In to order
I'll post updates on IG when they're ready to order!
@gk.engineering.co
kask2_6.0 is offline   Reply With Quote
Old 12-25-2023, 08:02 AM   #49
billstock67
Drives: 2017 Toyota 86
Anyone have feedback on this hood?
https://www.marshcomposites.com/prod...86-covert-hood
billstock67 is offline   Reply With Quote
Old 12-25-2023, 08:40 PM   #50
Originally Posted by billstock67 View Post
Form first function second. Great looking hood, but you'll get way more cooling surface area with some drop-in vents, placed properly.
Old 12-26-2023, 01:25 AM   #51
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Their other design looks more functional. But, as has already been said, a set of properly placed vents will still probably work better and be significantly cheaper.
Old 12-28-2023, 10:00 AM   #52
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
wondering why you say that. Looks like iut would have some good negative pressure running over it. Obviously, a lip would help a bit and give you a tiny bit of (much needed) front downforce. Better or worse, I think it would be in the noise. When it's moving, you really shouldn't need much. When it's stationary, the only thing that really matters is the surface area of the holes, which also have a point of diminishing returns. For popping coil packs, they're all probably in the wrong spot. You'd want them over the center of the engine and at the highest point. It's obviously a lot more expensive than a vent though.
I actually like it a lot. It matches my viper hood vents
https://www.viperpartsusa.com/wp-con...451-003-00.jpg
2014 BRZ: WRL Build (GP2) Gutted, caged, coilovers, AP enduro, etc-
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is online now   Reply With Quote
Old 12-28-2023, 03:40 PM   #53
jflogerzi
jflogerzi's Avatar
I have good luck with wrapping the coil in gold foil tape. verus hood vents for a street car or track spec Hood vents for a dedicated track car
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 12-28-2023, 03:56 PM   #54
Even with a big pressure differential at speed, you can only push so much air through those 2 small holes, vs a much larger vent.
To visualize, compare the surface area of the inlet (front bumper opening), to the outlet.
To put this in perspective, the outlet is MUCH larger for the aux radiators, than inlets, on most German cars.
By increasing area appropriately, you're reducing pressure differential, because you're simply flowing more. High pressure through a coffee stirer, vs low pressure through a Mcdonalds straw. Which flows more?
norcalpb (12-29-2023)
Old 01-07-2024, 07:43 PM   #55
GrandSport
GrandSport's Avatar
sure, I get cross section, but those don't look like they're much less than my vents. Or I'm just misremembering my vents.
Coil pack issue, pls help Limitz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 09-19-2022 01:17 AM
Varis V1 CF Cooling Hood beltax90 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-04-2020 08:33 PM
Strange issue - looking for suggestions - Possible DI or Coil pack problem sfruski Engine, Exhaust, Transmission 6 10-02-2018 02:07 PM
Overheating / Cooling System Basics Rennmeister Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 11-08-2017 06:16 PM
FS: VARIS cooling bonnet hood 2 Chris6052 Canada Classifieds 10 08-18-2017 08:59 PM
