#43 |
Drives: 2018 Golf R
Its metal. And kinda thick.
Sent from my Nexus S using Tapatalk 2
Parting out HERE
#44 |
Drives: race cars
My 2 biggest hang ups with where I have seen turbos mounted on these cars is 2 fold:
1. it requires a electric pump for the oil return. If/when these fail, so does your turbo. 2. Maintenance - for a track car, like mine, turbo bolts and couplings always need to be checked, as the heat and vibration make them loose. Maybe this engine doesn't create those vibrations, but I'd be skeptical. And in order to check the torque on these, its a little harder than popping the hood. But I'm not currently in the market for forced induction, so I'll let others figure it out. ![]()
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below. http://fecompetition.wordpress.com/ https://www.facebook.com/FECompetition |
#45 | |
Drives: DGM BRZ Limited
Turbo seals never seal 100% anyway, but I would have concerns about the cat after the turbo. It probably wouldn't survive it for long. I am not super excited for the scavenge pump either, or the fact that proper coolant lines aren't used. This kind of setup will require a turbo timer to prevent premature turbo failure, or a patient owner. If the pump could hold up for 50k miles I would be ecstatic. But realistically if you got 2-3 years you might be lucky. Anyone have experience with these pumps and their reliability? |
#46 |
Drives: 91 Corolla (dd) S14 (daily drifter)
It's just poorly written and English probably isn't his first language but I get his point. He's referring to someone else's turbo kit where the turbo is under the engine. It's almost the lowest point of the vehicle and that can be sketchy. Water, debris and all around grime can easily get on the turbo as well as the possibility of the turbo itself scrapping pavement.
The Following User Says Thank You to GenkiElite For This Useful Post: | Brzce (08-28-2012) |
#47 | |
Drives: MX5
#48 | |
Spaceman
Drives: 2013 Firestorm Scion FR-S
Sent from my Galaxy Nexus using Tapatalk 2
#50 |
Drives: race cars
Not sure what kind of turbo wouldn't fail if the scavenging pump failed. Sleeve bearing and DBB turbos would blow their seals which may be repairable, but you'd have to have them serviced.
#51 |
Boosted
Drives: Sideways
Lol you guys act like you didn't expect HKS to price like this.
#52 |
I wouldnt say a non issue. It may not be the lowest but its pretty low. Not the best spot for a daily driven vehicle. A track car or something thats brought out on sunny days is fine but having it where it is in crappy weather or constuction zones where tar and crap can get on it is a no go in my my book and most others as well. We've seen it mounted between the radiator and engine and I see no good reason to have it bottom mounted.
#53 | |
Boosted
Drives: Sideways
Sent from my Nexus 7 using Tapatalk 2
#54 | |
I've had several turbos leak oil into the intake or exhaust under certain "experiments" and still perform perfectly once the issue was corrected. So that's my experiences. I've had drain lines kink on bottom-mount SR20s with disco potatoes. Oil would pour into the exhaust, but fix the kink and everything was good as new. ![]() |
#55 |
Drives: 2013 FRS-6MT Argento
#56 |
Drives: 13 Hot Lava, 01 Miata, 09 Outback
I've only taken the lower guards off once, but it seems like this turbo would be back by the plastic section. Considering how hot turbos can get, I'm assuming that splash guard would need to be removed entirely.
-Justin
What is your prediction on FT86 power and Subaru 086a power? | 86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 08-26-2013 11:49 PM |
Enjuku Racing - Agency Power - New Products Released | Enjuku Racing | Engine, Exhaust, Bolt-Ons | 0 | 07-16-2012 04:46 PM |
New Zealand BRZ Pricing released | lazyluka | AUSTRALIA | 30 | 04-25-2012 05:54 AM |
TO ALL MY CANADIAN FRIENDS - BRZ Canadian Pricing Released | zex | BRZ First-Gen (2012+) -- General Topics | 7 | 04-24-2012 12:46 AM |
Canadian pricing released 25,990 | Mather | CANADA | 1 | 03-31-2012 12:01 PM |
