Old 02-28-2022, 03:58 PM   #43
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Are you fouling your MAF with too much oil? That is one of the two reasons I steer clear of reusable filters. That and, without increasing cross-sectional area, the only way to get an air filter to flow better is by reducing filtration.
I really dislike K&N’s for anything other then something used strictly for sand
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (02-28-2022)
Old 02-28-2022, 05:00 PM   #44
Ultramaroon
not playing cards
Ultramaroon's Avatar
I guess they're ok if the goal isn't to maximize engine life.
humfrz (02-28-2022)
Old 02-28-2022, 05:14 PM   #45
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have seen a number of desert bikes not survive a weekend with them. Silt and ash just passes through them.
Old 02-28-2022, 05:52 PM   #46
humfrz
Still better than the aftermarket "air cleaners" that we used back in the day -
jcw99 (03-04-2022), Ultramaroon (02-28-2022)
Old 02-28-2022, 07:24 PM   #47
Ultramaroon
not playing cards
I wasted too much time yesterday looking in vain for a pic of a tiny air cleaner over a v8.
humfrz (03-01-2022), soundman98 (02-28-2022)
Old 02-28-2022, 11:15 PM   #48
soundman98
ProCrastinationConsultant
soundman98's Avatar
Fab rats on YouTube just picked up a rat rod truck with one.
Ultramaroon (03-01-2022)
Old 03-01-2022, 01:38 AM   #49
humfrz
Well, just you rich kids had V-8s.
soundman98 (03-01-2022)
Old 03-03-2022, 02:53 PM   #50
Christian628
Drives: 2013 Scion FRS
Without seeing a log or knowing the code I can't tell you what's going on. The ECU pulls the afr from the O2 so maf may be fine. I'd really only fix issues and not mess with anything else. Let it hit 100 miles minimum then start logging. Through your previous logs it didn't look like you had an exhaust leak and it looked like the maf was reading fine. O2 sensor gaskets can probably be picked up at a local parts store.
So do I just change the scaling in rom raider or do i change the primary open loop fueling chart based off the afr average chart it gives me? And whats the afr cell hit count chart for?
Christian628 is offline   Reply With Quote
Old 03-03-2022, 03:21 PM   #51
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You log for and change closed loop first.
Old 03-03-2022, 03:28 PM   #52
Christian628
Something seriously wrong?
Yeah i logged for open and closed loop and made the changes to scaling. So now i change POL or after logging some more driving?
And so for Stock afr do i put in afr or commanded afr?
Old 03-04-2022, 09:40 AM   #53
humfrz (03-04-2022), Ultramaroon (03-04-2022)
Old 03-04-2022, 11:48 AM   #54
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No need to mess with those things when maf scaling. When you change the maf scale and reflash you need to put some miles on it again to let the ecu relearn fuel trims. You need to do that every time you reflash. Unless you see something bad in the logs like low IAM, crazy fuel trims, ect. Once I reflash I usually log the car once to make sure nothing bad is going on and then I don't bother logging again till I get some miles on it.
Old 03-04-2022, 12:44 PM   #55
Ultramaroon
not playing cards
^^^ this
Sorry about derailing your thread, OP. No is on point. One step/change at a time and observe carefully.
NoHaveMSG (03-04-2022)
Old 03-04-2022, 06:49 PM   #56
Christian628
I think i have tracked my idle issues down to the ac being on… idk. Only notice the problems and crazy afr when my ac is on. Thoughts?
Something is wrong S/C Smaay Forced Induction 25 01-09-2020 10:52 PM
E85 gone wrong MGPAX Software Tuning 34 03-17-2016 10:53 PM
What did I do wrong? Hags86 Tracking / Autocross / HPDE / Drifting 8 02-25-2015 01:36 PM
HELP! WRONG GAS IN CAR nabil_frs Issues | Warranty | Recalls / TSB 85 04-01-2014 01:44 AM
What's wrong with this car? Suberman CANADA 41 01-14-2014 12:35 PM
