Old 01-18-2022, 01:43 PM   #43
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by demasrv View Post
Oh my god those alignment pins would've been so useful.
Right?
Old 01-18-2022, 06:03 PM   #44
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Those pins are genius. And would seem to be dirt simple to make. Big to NHM.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
NoHaveMSG (01-18-2022)
Old 01-27-2022, 08:43 AM   #45
chipmunk
Drives: _
OP, have you considered buying a low mileage salvage and do a full engine swap? In my area, it's around $4000. There are plenty of crashed FRs and BRZs out there, just make sure that it's a side impact or rear end. I wouldn't touch frontal collisions.
chipmunk is offline   Reply With Quote
Old 01-30-2022, 06:52 PM   #46
dvsd1991
Drives: 2013 white frs
Got the engine apart today, #2 bearing went out
dvsd1991 is offline   Reply With Quote
The Following 2 Users Say Thank You to dvsd1991 For This Useful Post:
Tcoat (01-31-2022), Ultramaroon (01-31-2022)
Old 01-31-2022, 12:49 AM   #47
FrickingReallySlow
Drives: 2015 FR-S
Thanks! 2 and 3 share the same oil passage, any pics you can share with us the rod bearings of 2 and 3? would be interesting to see the amount of wear on 3 even though it hasn't spun.
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
NoHaveMSG (01-31-2022)
Old 01-31-2022, 01:29 PM   #48
dvsd1991
I will share when I split the case, I haven't gotten that far yet
The Following User Says Thank You to dvsd1991 For This Useful Post:
FrickingReallySlow (01-31-2022)
Old 02-05-2022, 02:51 PM   #49
dvsd1991
pictures uploaded of bearings 2 and 3
The Following 5 Users Say Thank You to dvsd1991 For This Useful Post:
bcj (02-06-2022), blsfrs (02-05-2022), FrickingReallySlow (02-07-2022), NoHaveMSG (02-05-2022), Ultramaroon (02-06-2022)
Old 02-09-2022, 03:04 AM   #50
FrickingReallySlow
Drives: 2015 FR-S
Very different wear rates between these two. Assuming there's no plugging up of the hole passage for #2 it could also be too tight of bearing clearance on #2 or wrong bearing set chosen. The wear pattern on #3 looks exactly like E90 BWM bearing failures which was caused by wrong tolerances. But who knows if oil starvation bear failure ever looks different from low clearance failures....
The big ends passages are cross drilled so you can look down them to see if they have blockage and that the diagonal drill was capped properly or force some water into your oil galleries to see if equal amounts comes out of 2 and 3.
Looking at the 2022 BRZ FA24 parts, #2 and #3 still share the same center main bearing oil passage so if they didn't "fix" this, I would trust Subaru in that sharing an oil passage from the center main bearing may not actually be an issue.
The more I think about this the more it seems like a statistical tolerance stack issue across manufacturing. The bearing sets on FA20 are used for forester,brz,wrx,legacy,outback,xtrek basically across the entire product line and it goes from STD, 0.03,0.05 and then big jump to 0.25. All 4 are shared parts. Now if we look at 2022 BRZ there are now 5 bearings sets, 1 size is shared across all the FA24s and the remaining 4 sets are 2022 BRZ specific and not shared. This could be real reason FA24D will be more reliable + the fatter straighter rods
The Following 3 Users Say Thank You to FrickingReallySlow For This Useful Post:
blsfrs (02-09-2022), itschris (02-10-2022), Ultramaroon (02-09-2022)
Toyota 86 after crash engine wont start maciekg9 Scion FR-S / Toyota 86 GT86 General Forum 8 11-16-2021 04:53 PM
Spun Rod Bearing? itsAlex Issues | Warranty | Recalls / TSB 38 03-12-2021 09:03 PM
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 06:39 PM
Engine failure - Spun rod bearing TWICE dinoniel Issues | Warranty | Recalls / TSB 38 11-07-2016 01:17 PM
Spun Rod Bearing #4 KE70 Issues | Warranty | Recalls / TSB 13 07-05-2016 03:17 PM
