#43 |
Drives: FRS
I have the Full blown and Full blown radiator and Spal fans. I only got it for extra security with opening up sooner.
#44 |
Drives: 86 GT
Another update - did another test on a long highway uphill recently.
Ambient temperatures were at 36C, with gears intentionally held lower to get more heat into the coolant, and the temps stayed lowest at 86C throughout the entire run. Oil temps were averaging 109C, with a Forester water to oil exchanger. With the new thermostat opening at 82C I could manage only 86C - this indicates that the stock radiator does have additional cooling capacity, but not much left given in a tropical setting. Regarding oil temperatures I am seeing a slightly more substantial drop, about 5C peak to peak. As the coolant further cools, more heat from the engine oil gets transferred to the coolant due to the larger temperature difference which then brings back up the coolant temps. With owners in Japan reportedly are running at around 84-85C with the same setup - this is as far I can probably get with the stock radiator.
DIY stuff at Compelica Works
| The Following 3 Users Say Thank You to Compelica For This Useful Post: |
#45 | |
Drives: 2015 midnight blue limited edition.
Sent from my Pixel 6 Pro using Tapatalk |
#46 | |
Drives: 86 GT
Alternatively you can gain some further headroom by venting the hood or the undertray (which I've done the latter and posted some findings here).
| Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic | ecko04 | Electronics | Audio | NAV | Infotainment | 10 | 05-05-2018 04:47 PM |
| Aftermarket Headunit with Aftermarket Amp | Jollibee86 | Electronics | Audio | NAV | Infotainment | 2 | 04-04-2018 10:39 PM |
| WTB aftermarket Oil cap | BlackyRose | Want-To-Buy Requests | 2 | 10-16-2013 12:14 PM |
| How does TC/VSC act with aftermarket LSD? | empower-auto | Engine, Exhaust, Transmission | 5 | 12-06-2012 08:48 AM |
| Aftermarket Amp Kit for FRS | kombatlion | Electronics | Audio | NAV | Infotainment | 7 | 11-06-2012 03:03 PM |
