01-25-2022, 01:46 PM | #43 |
Drives: 2022 GR86
Here's a direct link to just the sensors on TireRack:
https://www.tirerack.com/tpms/detail...odClar=Limited |
The Following 3 Users Say Thank You to timurrrr For This Useful Post: |
01-25-2022, 02:31 PM | #44 | |
Drives: 2020 Outback XT, 2022 BRZ
So they do work, just won’t show on dash for a few miles at least after programming. Give it a little time and/or miles before assuming there is a problem. You do have to select the second set of monitors via glove box after the codes are entered, dealer should do that. If they don’t, ask them to cycle via button. |
01-25-2022, 02:36 PM | #45 |
Drives: 2022 GR86
01-25-2022, 09:04 PM | #46 |
Drives: 2022 BRZ
Great news. The T6 is a lot cheaper than OE.
01-26-2022, 11:29 AM | #47 |
Drives: '22 BRZ
I was just able to activate, learn, and program new TPMS sensors using the Autel TS501. Worked like a charm - only took 5 minutes. The snow is thwarting my efforts to drive the car around to confirm PSI readings on the dash, but so far so good.
01-26-2022, 11:56 AM | #48 | |
Drives: 2023 BRZ Limited
Keep us posted on whether it is a success after you test it out |
01-26-2022, 07:35 PM | #49 | |
01-26-2022, 07:58 PM | #50 |
Drives: 2022 GR86
Thanks! Once you confirm the ywork for you, I might as well order too
02-01-2022, 10:20 AM | #51 |
Drives: Ice Silver 2022 BRZ Limited
Yesterday I went to the Subaru dealer I bought the car from to have them register my new wheels / sensors to my car.
After about a little over an hour, the service advisor tells me that they are unable to do it. He said that when they hooked up the computer to my car, it asked for the 7 digit serial # for each new sensor. I was told the only way they could do that would be to dismount my wheels and tires, take off the tires to read the serial #s, then remount and balance, and register the new sensors. Was told it would cost me $200 to do this. I'm not concerned over the $200, but I was afraid that the dealership might possibly scratch my new wheels, so I declined to have them do this. saluki89, I sent you a Private Message. If you can help me out, I'd appreciate it very much. |
02-01-2022, 11:57 AM | #52 |
Drives: '22 BRZ
Yeah, bad news on my attempt as well. The TPMS warning light came back after about 30 miles. I have a support request in with the manufacturer of my TPMS tool - waiting to hear if they'll have an update for our car.
02-01-2022, 12:15 PM | #53 |
Drives: '22 BRZ
Man, why does Subaru TPMS have to suck so bad?!
02-01-2022, 01:08 PM | #54 | |
Drives: 2022 GR86
I had a hunch that when I receive my sensors I should take photos of their codes or whatever, just in case... However, can't they just read the sensors with some tool? I remember an America's Tire guy reading my stock sensors without taking the stock tire off the stock wheel back in the day. |
02-02-2022, 12:32 AM | #55 | |
Drives: '22 BRZ
The Following User Says Thank You to Panda Grahams For This Useful Post: | timurrrr (02-02-2022) |
02-02-2022, 01:32 AM | #56 |
So since you were not able to program them. Do you think maybe you can read them with your tool, and then the dealer can use that information to program them with their computer? Or do you think they would still have to remove the tires from the wheels to get to the sensors themselves?
The Following User Says Thank You to Up4speed For This Useful Post: | timurrrr (02-02-2022) |
Similar Threads | ||||
Intermittent Wipers backwards | Runner10 | Issues | Warranty | Recalls / TSB | 34 | 09-18-2024 05:22 PM |
Schrader 33500 TPMS EZ Sensors compatible with Rays wheels? | Infinity | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-07-2020 05:08 PM |
Carsguide: the refresh is a step backwards | Sport-Tech | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 03-21-2017 04:31 PM |
Someone's backwards response to me on Reddit | Linseal | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 07-29-2013 01:35 PM |
How to make the dealership bend over backwards? | Kiteless | Scion FR-S / Toyota 86 GT86 General Forum | 48 | 10-30-2011 05:05 PM |
