Old 01-12-2022, 06:36 PM   #43
hedtrip
hedtrip's Avatar
Drives: 2013 toyota 86
It only took 4.5 months but most of my #fa20deletekit has arrived.
The Driveshaft hasnt showed up yet but should tomorrow.
And i still have to Wait for the Adapter plate I have no idea when that getting shipped yet.
hedtrip is offline   Reply With Quote
The Following 4 Users Say Thank You to hedtrip For This Useful Post:
endless_pain (01-24-2022), Irace86.2.0 (01-12-2022), ML (01-12-2022), Wally86 (01-18-2022)
Old 01-14-2022, 10:32 PM   #44
hedtrip
hedtrip's Avatar
I did a unboxing video of the Kpower 86 swap kit & went over a lil on all the major components
The Following 2 Users Say Thank You to hedtrip For This Useful Post:
endless_pain (01-24-2022), Irace86.2.0 (01-15-2022)
Old 01-16-2022, 04:23 PM   #45
hedtrip
hedtrip's Avatar
So i have started putting the K24 together as far as i can for now.
I still dont have the Adapter plate so i cant mount the trans.
So i did the Oil pan, engine mounts, coolant neck, & built up the Instake mani.
The Following 3 Users Say Thank You to hedtrip For This Useful Post:
endless_pain (01-24-2022), Irace86.2.0 (01-16-2022), Wally86 (01-18-2022)
Old 01-16-2022, 04:34 PM   #46
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Looking good so far!
villainous_frx is offline   Reply With Quote
The Following User Says Thank You to villainous_frx For This Useful Post:
hedtrip (01-16-2022)
Old 01-16-2022, 07:29 PM   #47
hedtrip
hedtrip's Avatar
So like others i had a issue with the Dip stick hitting the oil baffle in the pan.
So i had to drill out some holes so the dip stick was actually useful.
I did email Kpower about the issue.
Jdmjunkie (01-16-2022), villainous_frx (01-17-2022), Wally86 (01-18-2022)
Old 01-17-2022, 03:50 PM   #48
hedtrip
hedtrip's Avatar
Ive been busy.
New video, installed some stuff.
The Following 5 Users Say Thank You to hedtrip For This Useful Post:
endless_pain (01-24-2022), Four_wheel_drifts (01-18-2022), Jaden (01-17-2022), Jdmjunkie (01-17-2022), Wally86 (01-18-2022)
Old 01-18-2022, 07:56 PM   #49
hedtrip
hedtrip's Avatar
So i did a test fit to see how things fit.
[/url]
The drain plug does look pretty close to the subframe but not as bad as Ebush.
So i will take a hammer to it.
Old 02-07-2022, 05:38 PM   #50
hedtrip
hedtrip's Avatar
Since im still playing the Wait game. I was bored & vented my Valve cover.
This is a No Weld Solution.
Old 02-07-2022, 06:39 PM   #51
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I suppose the other thing you could have done was sacrifice the tap after starting the hole and just used a saw or angle grinder to cut the tap in half, so you had the clearance to bottom out the NPT to -10AN adapter. You could have also finished the hole you made through that section to the inner area. At least you figured out a solution. Trial by error. I know it all too well.
Old 02-08-2022, 11:21 AM   #52
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
This is going to be awesome when done. Should have had this setup from factory rather than the FA20
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
The Following User Says Thank You to Ghost of Akina For This Useful Post:
Arthur-A (02-08-2022)
Old 02-13-2022, 04:23 PM   #53
hedtrip
hedtrip's Avatar
Almost 6 months & my adapter plate is here finally.
Irace86.2.0 (02-13-2022), Jdmjunkie (02-13-2022), RedReplicant (02-13-2022)
Old 02-14-2022, 10:09 PM   #54
hedtrip
hedtrip's Avatar
Things are starting to come together
I fits i sits
Dzmitry (02-15-2022), RedReplicant (02-15-2022)
Old 02-15-2022, 04:22 PM   #55
GabeoHuncho
Drives: 2013 FR-S Vortech V3
Hell yeah, looks tight, literally and colloquially lol
I think this would be my method if my FA ever poops the bed
GabeoHuncho is offline   Reply With Quote
Old 02-15-2022, 04:44 PM   #56
hedtrip
hedtrip's Avatar
My original plan was to wait until I blew it up. But... Fa are worth alot more money none blown up.
The Following User Says Thank You to hedtrip For This Useful Post:
villainous_frx (02-15-2022)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 10:41 AM
HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions Corradooo Engine, Exhaust, Transmission 2 11-25-2017 08:16 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 11:14 PM
