Old 06-12-2021, 06:04 PM   #43
Hamza
Hamza's Avatar
Drives: Widebody 86/F56 Mini Cooper S
Cold air intakes change how the air flows across the mass air flow (MAF) sensor. You can correct for this in the tune. Look up the MAF Scaling thread in the software tuning section of the forum. Without correction, the engine will probably still run decently as you have noticed, but it will produce less power, less reliably because the amount of air it thinks it is using will be wrong.
You can flash the car hot. I would do it all the time when making adjustments.
Note: Stage 2+ is for cars with catless headers iirc. You probably know that, just making sure.
Thought I'd update: Did looking around about changing the MAF sensor values in romraider. I guess I could say I got the idea
but
stock intake is back in not worth the effort
Hamza is offline   Reply With Quote
The Following User Says Thank You to Hamza For This Useful Post:
Spuds (06-12-2021)
