Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-24-2021, 07:23 PM | #43 | |
Drives: -
Simplest Bestest Mods to tighten up steering, turn in and body flex
I remember that video, it was kinda crazy. The new cars are 50% stiffer so they might not work as well on them. |
04-24-2021, 08:59 PM | #44 | |
Doors/windows close against flexible rubber seals in order to seal properly (in many different conditions) and repeatedly over the life of a car. They are not designed to be totally solidly mounted. I would have no issues with TRD claiming it holds the door in place to a greater degree. Whether the door "needs" to be further held in place is another question, that they might need to put a case for (in order to charge the price they ask for the product). I know that ultimately it doesn't really matter, it always a personal choice, but it genuinely irks me when cynical salesmanship over reaches, on purpose, to mislead genuine enthusiasts, many of whom don't have a lot of spare cash to waste. |
The Following 3 Users Say Thank You to grumpysnapper For This Useful Post: |
04-25-2021, 06:10 AM | #45 | |
LMGTFY
Drives: 13 FRS, 91 Miata
but I'll bite. Cars that have staggered offsets usually have them for rear grip reasons. McLaren has a mid engine layout. More weight being tossed around in the back and WAY more power. Need fatter tires. The twins are well balanced from to back and has a rather stable wheelbase. So there is no reason to go staggered. It'll just add understeer. Obviously simplifying the crap outta this, but those ate the basics. |
04-25-2021, 06:48 AM | #46 | |
Drives: '15 BRZ RA
Personally, I prefer to stay with an equal size wheel/tire setup on a 200tw 205 tire. In this way, I keep the responsiveness and quick turn in without the need to add an additional weight on bigger wheels/tires and other reinforcements. The disadvantage is that I have to spend more money on tires, but as usual it is all about compromises. |
The Following User Says Thank You to nikitopo For This Useful Post: | x808drifter (04-25-2021) |
04-25-2021, 11:01 PM | #47 | |
Drives: Black BRZ
If you are as smart as you think yourself to be, then how come you need to "simplify the crap outta this" and not just give the proper, in depth answer? With respect to your comment about the cars being mid-engined and a rear, wider tire supporting the extra weight - I get that! I should've mentioned that - and I'm pretty sure I'm not mistaken here - cars like the S2000 and M2 also have factory staggered setups without there being any need to support extra weight in the rear. So they run staggered setups to support more power and what I was trying to get at is that how come modified 86s (usually with more power than stock) still run non-staggered. Wouldn't a staggered setup on, let's say, a 300hp 86 be better as you'd retain the turn in response and get the wider rear to handle the added power? The resulting understeer could be dialed out and since I hardly ever see this being done I figured I must be missing some other benefit(s) of a square setup. So that's pretty much what I was trying to figure out and your smug response seems pretty unnecessary. Note to self: better to just search up these things next time rather than getting into pissing contests on these forums...what an incredible waste of energy and also quite the letdown |
04-25-2021, 11:05 PM | #48 | |
Drives: Black BRZ
In conclusion I guess it would be up to the owner to decide how badly they'd like to keep that turn in response. |
The Following User Says Thank You to WC-BRZ For This Useful Post: | nikitopo (04-26-2021) |
04-25-2021, 11:46 PM | #49 | |
Drives: 2016 HyperBlue
Often times there is more room in the rear for wider tires. Give that, some people opt to run the widest tire that fits to get power down and that ends up staggered. You can take that to the other extreme like drag racers and run skinnies up front. :-) It's all about what you want out of your car. But, if you run 225 front and 245 rear on a mildly modified 86, you're probably gonna get a lot of understeer unless you've done some extreme things. And what good is nice turn in if it quickly turns into understeer? |
04-26-2021, 07:29 AM | #50 | |
LMGTFY
If I was trying to be rude I wouldn't have even bothered trying to explain the basics, I would have just told you to search. You started by comparing a high power mid engine car to a low power FR. The gives 2 first impressions. 1: You don't understand even the basics of front vs mid engine cars and why mid engine cars have wider rears. so I feel I need to simplify the crap outta it to get the bare basics across. 2: Using your two wildly different cars in the original comparison. The post must be a troll/joke post. If you had led off with the comparisons with the M2/S2K like you did later I would have taken it much more seriously. It's almost always better to run a square setup if possible and use the rest of the suspension to fine tune the rest. Fatter rear or front tires are used to make large changes to over/understeer and general vehicle stability. IE: when you cant get any more grip out of the suspension. Wheelbase also comes into play. Short cars will rotate easier and be harder to catch if they start to slide, so some intentional understeer may be desired. (Lots of OEMs also make cars understeer intentionally) M2/S2K for example. In autocross however oversteer is usually desired quite a bit more so like in nathand's description the S2k's run a square setup. It is also very easy to go too wide with the tires. A 235F/245R wont destroy the cars handling but that is assuming the you need that extra bit of tire to put the power down. And at that point you should have enough power in the rear that the rear width is no longer causing excessive understeer so much as its keeping the rear from stepping out under throttle. |
The Following User Says Thank You to x808drifter For This Useful Post: | SkyeHack (04-26-2021) |
04-27-2021, 02:11 PM | #51 | |
Less bimmer crossover on this forum but with the front struts similar to an 86's and lack of camber gain they need the front tire as much as we do. |
The Following User Says Thank You to strat61caster For This Useful Post: | x808drifter (04-28-2021) |
05-12-2021, 05:27 AM | #52 |
Drives: Whiteout FR-S (Soon!)
Thanks everyone for your comments, experiences and opinions. Much appreciated!
Sorry for the delayed response ... been a few 85+hour weeks finishing up a movie Car is currently on stock wheels/tires. Have a set of pretty but dusty OZ Superleggeras in storage needing new tires. Previously mounted w/S03 Pole Positions carried over from my 2003 WRX....which I loved (stiff sidewall and dry/wet traction). Based on the previous comments, will likely upgrade to S04s this time around, not all seasons after all. Then incrementally upgrading bushings seems like a no brainer ... and steering rack lockdown (?). I'll update this thread as I go and will definitely be back with more questions Cheers, Broz |
05-13-2021, 02:06 PM | #53 | |
Drives: 2017 PP BRZ
Similar Threads | ||||
Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 06:47 PM |
steering turn-in | notout86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 05-20-2014 09:16 PM |
FRS turn signal mods | subiestyle | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 03-07-2014 01:34 AM |
Simplest possible install for tablet | transition | Electronics | Audio | NAV | Infotainment | 9 | 02-11-2014 05:43 PM |
