#43 |
ZC6A2B82KC7J
Drives: 2002 WRX
They are both very similar and good exhausts. I have heard the Perrin and I have the nameless on my car and they both sound more or less the same. I chose the Nameless because it was a lot cheaper since it is just an axleback and I didn't see any benefit to replacing the midpipe. I'll save my money for headers/front pipe combination where the real power is. The build quality on the axleback is really incredible, it is like a work of art. The tips are the perfect size and offset and really made the back end of the car look a lot better.
#44 | |
Potato Farmer
Drives: #SLOBRZ
Really cant wait for you guys to get with the times and use the Metric system like the rest of us modern country's :P ![]()
Something something butter..
www.vic86brzclub.com |
The Following User Says Thank You to fuddbutter For This Useful Post: | sierra (11-22-2012) |
#45 |
Drives: 2013 Subaru BRZ
Thanks for reviving this thread. I'm also trying to decide between Perrin or Nameless, but I may put off the decision for a little while. Have the power gains been proven by independent tests yet?
I was leaning toward the Perrin, but now I'm thinking: Does the Nameless option (of axleback+frontpipe) really produce about the same power as the Perrin Catback (if not more)? If so, wouldn't the Nameless be a clear winner given that it weighs a lot less than the Perrin? |
#46 |
Drives: 86
the weight quoted for Perrin cat back was for the resonated version. my understanding is the non resonated cat back is lighter. can't someone confirm?
thanks |
#47 | |
"The catback without a resonator weighs 26lbs total, so about 12.4lbs less than stock. But then you have to deal with a louder and probably raspier exhaust." I do want something quieter though so I'm considering the resonated Perrin or the offset version of the Nameless. |
#48 | |
Drives: Ultramarine frs
Gotta fine tune my ecutek tune with it this week. Tap'd from my G-Nex
The Following User Says Thank You to mach330 For This Useful Post: | BabaYaga (08-05-2014) |
#49 | |
#50 | |
Tap'd from my G-Nex
#51 |
Kurenai Samurai
Drives: Red and manual
Loud and proud. Perrin non res.
The Following 3 Users Say Thank You to driftartist For This Useful Post: |
#52 |
Drives: 86
the perrin systems are really a trade off.
go with res cat back + non cat front pipe and you have more power but also more weight. go with non res cat back + cat front pipe then you gain less power but you also lose weight. if non cat front pipe + non res cat back isn't too loud then that's the best solution for power & weight gain. personally i think i'd go for non res catback and cat front pipe as i don't mind a little noise. |
The Following User Says Thank You to Nardi330 For This Useful Post: | gmookher (10-26-2012) |
#53 | |
I just need to hear all of these combos in person, back to back. That shouldn't be too tough, right? ![]() |
#54 |
Drives: SWP Limited manual BRZ
im probably going to confuse you guys even more on your choices. I have a visconti tune and a resonated perrin catback. I have over 2k miles on this set up. I swear overtime it has become a little louder. I would say it is easily 10% louder than when I first got it. Go figure I LOVE IT. Perrin is awesomeness
The Following User Says Thank You to Norcalmav23 For This Useful Post: | PERRIN_Chris (10-10-2012) |
#55 |
Drives: 86
once the exhaust is run in, does it sound louder or softer or no change???
firstly too many choices on the market for exhaust. but now that i have picked Perrin, still too many variables.....!!! |
#56 |
definitely louder. More growl. Not loud at all. But I really wouldn't say super quiet, especially now, I give it a 5 out of 10 on the loudness scale.
Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
Nameless Performance Exhaust Group Buy | jwuwu | Southern California | 56 | 10-28-2012 10:11 PM |
Question about Nameless Performance exhaust | Metallic BRZ | Engine, Exhaust, Transmission | 16 | 08-05-2012 09:06 PM |
Nameless Performance Exhaust Group Buy | jwuwu | BRZ First-Gen (2012+) -- General Topics | 1 | 07-24-2012 02:12 AM |
