Old 02-25-2021, 09:53 PM   #43
grumpysnapper
grumpysnapper's Avatar
It's not a CSG spec differential, but rather, each LSD ordered from CSG has the option of being configured to match the driving discipline the car is used for, along with the tires used, suspension, and power output of the car. In some cases, aero is also taken into consideration.
In this instance, a CSG spec doesn't make sense, since it wouldn't work for everyone, or even a wide range of users.
OS Giken LSDs are currently backordered, but the next batch on order by CSG arrive at the end of March. At that time, each unit is opened up and configured as needed before shipping.
Very very true.
I've had one fitted now for nearly 5 years, great diff... but really does need to be set up properly by someone who knows what they are doing.
Initially mine was installed by a general purpose diff guy...and it wasn't too impressive.
I then had a genuine specialist have a "play" with it....it was like night and day.
grumpysnapper is offline   Reply With Quote
The Following 3 Users Say Thank You to grumpysnapper For This Useful Post:
botbs (02-26-2021), CSG Mike (02-26-2021), DocRecon (02-28-2021)
Old 02-28-2021, 12:06 PM   #44
DocRecon
Muscle Car to Import
DocRecon's Avatar
Drives: 2013 Asphalt FR-S
Going off my OP: I've decided to try something other than the typical brands you see on an import, since I have experience with muscle car brands. It may turn out well or it may not; however, I'll update the community when I get it on in the event it helps someone else. I decided to go with the 6 puck McLeod Street Supreme clutch kit and McLeod aluminum flywheel (~12-14lbs, I don't recall at the moment). Also, I bought an upgraded Versus forged clutch fork and Versus billet clutch pivot. I haven't installed them yet but will soon. I went with McLeod due to my muscle car background and to just try something not a lot of others have yet.
DocRecon is offline   Reply With Quote
The Following User Says Thank You to DocRecon For This Useful Post:
CSG Mike (07-25-2022)
Old 07-23-2022, 05:05 PM   #45
Amputechture
Drives: 2014 BRZ
How are you liking it? My Exedy S1 is holding up to my new flex fuel setup, but I'm fully anticipating having to upgrade soon...McCleod seems intriguing.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
The Following User Says Thank You to Amputechture For This Useful Post:
DocRecon (09-08-2022)
Old 07-26-2022, 04:32 AM   #46
Brz-123
I am curious to know if the OE clutches for the 2nd gen GR86 / BRZ are stronger and better than the Gen 1 ones and if that's a good replacement? Also how is the availability of these parts as the cars themselves seem to be in short supply.
Brz-123 is offline   Reply With Quote
Old 09-08-2022, 12:28 AM   #47
DocRecon
DocRecon's Avatar
Sorry for the late reply. I've been swamped at work and completely forgot about the forum. I'll say the McLeod is definitely not for the Daily, if you're in a lot of traffic. I run in to a lot of lights on my daily commute and sometimes if traffic is bad it can be a bitch.
It grabs really well and with the car having as much power as it does, from running the SC, I have to barely feather the gas and pull out a lot of times while still riding the clutch. Don't get me wrong, though. It is mean on a full take out , pulls, and an all out run. When the car is fully winding out it will grab and go. It's a beast. I was even on the interstate one day and dropped in to fifth to do a pull doing about 65-70mph, but hit too low an RPM and it held. The car broke traction and thrust forward.
The clutch rattle can be a little bad in first sometimes depending on how and where you're pulling out, but in other gears it isn't a problem. I also get some flywheel noise only when running the A/C. All in all, I think it's a fair clutch but just watch the application. I think it's a good clutch but one for the track and not one for a DD doing 30 stop lights every other block, or so with heavy traffic.
Doc
Old 09-16-2022, 03:05 PM   #48
Amputechture
Drives: 2014 BRZ
Doc
No problem, thanks for sharing all of that. I deal with Tampa traffic on the reg, definitely not the clutch for me considering. My Exedy S1 has started to slip, so I've been having to drive her on the wastegate map.
DocRecon (11-08-2022)
Old 01-30-2023, 04:16 PM   #49
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
Originally Posted by Jdmjunkie View Post
I have a single plate OS Giken setup and I can't recommend it enough! Break in was a bit off a pain but once that is over it is the best clutch I have ever driven, performance wise.
Why do you like this clutch? Also what was annoying about it?
I am also looking at a South Bend Stage 2 daily.
GPhilly is offline   Reply With Quote
Old 01-30-2023, 07:09 PM   #50
Jdmjunkie
Drives: Scion FR-S 10 Series
I like the clutch because it is light, easy to drive, and has a better throwout bearing. OSG clutchs are a complete system, so they include: flywheel and clutch, upgraded throwout bearing, and braided clutch line.
The annoyance was only during the break in period because the pedal was extremely stiff and the bite point was like an light switch. After driving it for a few weeks it eased up considerably, still stiffer than stock but much easier to modulate. My 60+ year old mother has driven it and had no issue.
If you are looking at OSG I would talk to Mike at Counter space garage.
Jdmjunkie is offline   Reply With Quote
The Following User Says Thank You to Jdmjunkie For This Useful Post:
GPhilly (02-01-2023)
Old 01-31-2023, 01:42 PM   #51
Jdmjunkie
Also forgot to mention that the kit also comes with a upgraded clutch fork as well.
Old 02-01-2023, 08:32 AM   #52
GPhilly
GPhilly's Avatar
Thanks, I did ask on the weekly reddit thread and got Mikes input. Just trying to gather info since there is some CSG bias. I have heard great things about both clutches.
Old 02-03-2023, 05:00 PM   #53
There is no bias in strictly factual replies.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Jdmjunkie (02-03-2023), nathand (02-04-2023), x808drifter (02-04-2023)
Old 02-04-2023, 11:31 PM   #54
jflogerzi
jflogerzi's Avatar
I have the same clutch and OEM Flywheel. Ran great with my FRS when it was boosted. Still fine after not being boosted
2013 Series 10 FRS #553
FS: OEM Clutch & Flywheel pleong Transmission and Driveline 2 10-14-2014 01:00 PM
Fs: act flywheel and clutch Guildjs Transmission and Driveline 9 05-18-2014 03:26 PM
Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? OICU812 Engine, Exhaust, Transmission 2 05-17-2014 01:56 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
