#43 |
Site Moderator
Drives: Stuff
Why can't I bid against you again? lol
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#44 |
Drives: 14 Limited BRZ
No they had their master tech give it a basic look over, he confirmed its the motor just going off that. They told me I can take his advice and options that they gave me previously and not pay anything. Or I can pay for the fee and they can do a proper look over to find the exact problem. But either way I need either an engine swap or a rebuild.
#45 | |
Site Moderator
Drives: Stuff
Sorry to hear about your friends uncle. You can source engines for less than that. I've bought and sold them between 1500-2000. Labor at 2k is.. well maybe normal but seems high as it doesn't take even 10 hours to do the swap and that's at a $200 bill rate...
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | p1l0t (09-26-2020) |
#46 | |
Thanks! |
#47 | |
Site Moderator
Drives: Stuff
-Dave
#48 | |
Did you run into any hassles putting the newer motor into your car? |
#49 | |
Site Moderator
Drives: Stuff
Not really, the 2015 harness plugs right in but the jackholes I bought the engine from cut the harness. I bought a conversion harness for the 2013 engine to use 2015 coilpacks from Subaru (they have a harness for 2013 cars and 2014 cars). That required me to move over two sensors from the bad 2013 engine to the 2015 engine.. IIRC it was water temp and oil temp but it's pretty obvious which need to be swapped when you have it in front of you. We've done the reverse swap as well (2013 engine into a 2015) and just plugged it in and went.
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | gravitylover (09-28-2020) |
#50 |
Thanks! That's comforting.
| Idle knocking noise | Kostamojen | Issues | Warranty | Recalls / TSB | 33 | 04-20-2018 02:09 PM |
| Engine running rich, stumbling, rough idle after motor swap | toyubie | Engine, Exhaust, Transmission | 19 | 04-07-2018 01:11 PM |
| What is this? Knocking Popping Tapping noise from the engine bay no codes | arren123 | Engine, Exhaust, Transmission | 49 | 01-11-2018 10:18 AM |
| Knocking on Startup? | 636 | Issues | Warranty | Recalls / TSB | 17 | 02-03-2014 08:18 AM |
| Strange engine noise during startup (Video inside) | StOpNG0x | Issues | Warranty | Recalls / TSB | 2 | 01-29-2013 08:24 AM |
