Old 06-17-2020, 12:45 PM   #43
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Originally Posted by WNDSRFR View Post
To me it's kinda like buying an aftermarket CAI. What the stock intake isn't cold enough for you?
Well,tell that to my friend,who put a full K&N CAI in his Chevy SS and got ~10-15whp gain(iirc). And yes,he has the dyno sheet to prove it,so...
Th3rdSun is offline   Reply With Quote
Old 06-17-2020, 04:40 PM   #44
WNDSRFR
Drives: FR-S,GTI
This is not a Chevy SS. This is an FR-S. Of course there are many cars where the intake could be improved. This is just not one of them. There are some CAI's that look cool or they make a cool noise, but I don't think any improve on the performance of the OEM. Without the stupid sound tube of course.
But this post got me wondering if my shifter really does have a problem.
If you go out to your car and put it in gear. Engine off. And move the gear shift left and right. Is there no play at all? Try any gear. Every gear. Is there really no play at all?
I really goota know.
The Following User Says Thank You to WNDSRFR For This Useful Post:
soundman98 (06-18-2020)
Old 06-17-2020, 05:04 PM   #45
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it feels okay I don't think I would worry about it
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (06-18-2020), WNDSRFR (06-18-2020)
Old 06-17-2020, 06:47 PM   #46
Decep
Drives: 2013 FR-S Series 10
Wow. Talk about an entitled, pissy little attitude that now banned guy had. Dont think i've ever seen anything like it in all the forums i've been a part of.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following 2 Users Say Thank You to Decep For This Useful Post:
KR-S (06-17-2020), Opie (06-18-2020)
Old 06-17-2020, 06:54 PM   #47
It got far far far worse!
KR-S (06-17-2020)
Old 06-17-2020, 07:25 PM   #48
Ohio Enthusiast
Drives: 2018 BRZ
On my 2018 BRZ with stock shifter I get no play (well, maybe 1/16") front to back and about a 1/4" play left to right in gear (all the gears are about the same). In my Focus ST I replaced all the shifter bushings (including the cable ends) with solid aluminum and it still had more play than my BRZ.
Ohio Enthusiast is offline   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Old 06-17-2020, 10:21 PM   #49
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Fuck! I guess I missed quite a shitshow! Somebody summarize what happened for me.
Old 06-17-2020, 10:55 PM   #50
radroach
Drives: car
A brand new 86 / BRZ does not have play in gear.
The loose shifter play in gear was the first thing I noticed after I got the car back from the shop after getting the clutch serviced, had 55k miles on the car.
The looseness does have an effect, but the shifting action is "good enough" to live with, the 86 transmission is actually pretty great if you can drive it well enough and keep the car in good service.
Old 06-18-2020, 12:04 AM   #51
Decep
Why would you mess with the shifter when changing the clutch out? I sat back and watched my mechanic change out my TOB and clutch and he didn't mess with the shifter at all.
RCE SS-1 Coilovers
Corsa Catback
Old 06-18-2020, 12:35 AM   #52
churchx
churchx's Avatar
Drives: 2014 GT86
Whatever the actual technical background, i'm glad that admins acted and shitstorm ended. Even if there always are two sides of truth (i'm guessing that banned OP thinks that it's all undeserved and he is innocent victim that did everything right and it's unhelpful and ungrateful community, evil trolls, fascist admins, that are at fault), nothing can warrant rude swearing as in cleaned up posts, pissing off many in community. Even if there had been mega-useful good technical info that would benefit lot of owners on fixing very common issue, it's not enough to justify being hostile prick. Even if particular issue hasn't affected me i always like reading threads (i'm sure many do) in technical sections to rise own technical knowledge in general, learn new things, familiarize with different areas of car that i like .. unless it turns out like this.
The Following 3 Users Say Thank You to churchx For This Useful Post:
KR-S (06-19-2020), Opie (06-18-2020), soundman98 (06-18-2020)
Old 06-18-2020, 12:43 AM   #53
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you drop the trans out to change the clutch you have to disconnect the shifter linkage and remove the retaining pins for the shift assembly. You can do it from under the car so you likely did not see him mess with it.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Opie (06-18-2020)
Old 06-18-2020, 02:15 AM   #54
solidsnake11
Drives: brz
Jack car up pull transmission replace either centering springs and or detent balls. Hunt stiffer springs for both if you really hate it. You could also modify some of the parts in the transmission to make it tighter. Post an exploded view of the transmission and I will let you know which ones they are.
If its in gear in the video weld hockey stick then grind it down to tighter tolerances.
The CD009 has centering springs so you could get the conversion from mazworx to fix it depending on how much you hate it. .
The bushings you are wanting to replace are very thin so I'm not so sure they would cause problems.
solidsnake11 is offline   Reply With Quote
Old 06-18-2020, 02:18 AM   #55
solidsnake11
Drives: brz
Dang you banned him before I got to have some fun.
The Following User Says Thank You to solidsnake11 For This Useful Post:
Opie (06-18-2020)
Old 06-18-2020, 09:56 AM   #56
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Ugh, why did I have to miss it?!
MS, CSCS, TSAC-F, CPT
Shifter kinda stuck and extr play after clutch install airrick Engine, Exhaust, Transmission 10 04-27-2020 10:26 PM
Is this the normal amount of play for stock shifter? dhuang Engine, Exhaust, Transmission 16 10-17-2018 09:54 AM
How much shifter play is normal? radroach Engine, Exhaust, Transmission 16 08-02-2017 11:25 PM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 10:57 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
