Old 04-28-2020, 10:37 PM   #43
Ashikabi
Ashikabi's Avatar
Originally Posted by solidsnake11 View Post
First test drive. Water pump is running full time so engine is coolling off while driving.
https://datazap.me/u/turbotoy2791/lo...?log=0&data=31
Attachment 187345
I can make a k24 run off a brz computer But I'm really struggling with this bmw water pump and Arduino. I ordered a china copy of the cwa200 seems the electronics is off. orded a vodo china copy then ordered a OEM, I think it doesn't use PWM control. Now I am waiting on another cwa200 copy. All the guys online show the cwa400 running off pwm.
It's always the little shit
The Following User Says Thank You to Ashikabi For This Useful Post:
solidsnake11 (04-29-2020)
Old 05-02-2020, 07:30 PM   #44
mrg666
pessimistic skeptic
mrg666's Avatar
That has been a remarkable job, especially running the VTEC with Subaru ECU. Will you do a dyno? And also a video, please!
The Following User Says Thank You to mrg666 For This Useful Post:
solidsnake11 (05-02-2020)
Old 05-03-2020, 07:33 AM   #45
tomm.brz
Drives: brz 2017 hksv2
i'm amazed at your work
i have a question: how is it possible to define the cc size of direct injectors in the fa20? they work with variable pressure, from like 0.4 to 20-22MPa
at what pressure are they defined 450cc ?
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
mrg666 (05-04-2020), solidsnake11 (05-03-2020)
Old 05-16-2020, 03:39 AM   #46
tomm.brz
i m stalking your YouTube channel waiting for a video of a WOT to 9000 rpm (:
The Following User Says Thank You to tomm.brz For This Useful Post:
solidsnake11 (05-16-2020)
Old 05-16-2020, 10:26 PM   #47
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Me too.
Still deciding on how to run the Vtec. Honda turns it on at say 5500 then it stays on till it goes back down too 5000.
I may go get it inspected then buy Racerom.
From what I read, the crossover point is like 3500-4000. Any sooner and there isn’t any gains or there are losses. Economy obviously hurts if you lower it too, and you won’t feel the delayed boost of VVVVTEEECCCHHHH!
Old 05-17-2020, 08:53 AM   #48
Irace86.2.0
My example was just say it didn't come on and go off at the same rpm.
I planned on starting at 4400.
Which is logical thinking on Honda’s part. If someone gets into VTEC then they probably are aggressively driving so they lower the threshold until the driver is clearly not aggressively driving. If you drop the threshold for getting out of vtec too low then the system could be jumping lobes too much when city driving. I guess it depends on what you plan to do with the car and how you drive. Maybe an aggressive map and an economy map would be a good idea.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Zer0 (05-19-2020)
Old 05-24-2020, 02:34 AM   #49
Irace86.2.0
Uhhh 30psi?!! How does that feel?
solidsnake11 (05-24-2020)
Old 05-24-2020, 05:12 AM   #50
tomm.brz
I The pdf about racerom you find on Help files on Proecu
explains this very well, the boost limits are always on
It worth a read
Anyway it s very noticeable the boost limit, in contrary to fuel cut caused by wheel slip that closes throttle , boost limit closes Accelerator pedal only and the % of cutting is settable.. like the hysteresis of the overboost before limit activation
It s a nice touch also for supercharged cars if you reach too high boost because of cold weather and you want to avoid, you can set the boost limit very soft, closing accel pedal just a little bit and the cut becomes very smooth
Old 05-27-2020, 05:51 PM   #51
Irace86.2.0
Vtec is now working!
Vtec is amazing!!!! I would say its a 130rwhp kick
Reminds me of an old quadrajet on a healthy V8.
logs show this
Vtec off 7000rpm 293gs at 15lbs
Vtec on 7000rpm 432gs at 14.5lbs
The new K20 turbo doesn’t have traditional VTEC on the intake. I guess the idea is that the turbo does enough work. The heads have less flow too. VTEC on the exhaust helps with spool I guess.
solidsnake11 (05-27-2020)
Old 05-28-2020, 10:02 PM   #52
Calum
That Guy
Drives: 2013 asphalt FRS MT
I've never understood this. If there's that much of a power increase that only means you should have been on that cam sooner. If you're after the max area under the curve the transition should be smooth as the power of one cam drops off and the other comes on.
The Following User Says Thank You to Calum For This Useful Post:
solidsnake11 (05-30-2020)
Old 06-01-2020, 05:00 AM   #53
tomm.brz
you have to push trc off for 4 seconds to completely disable and allow spinning
vsc is not enough
if you see accel100 and throrrle closing normally is because of wheel spin
if you press trc only quickly it wont disable it totally and it will deacticate after 50km/h
solidsnake11 (06-01-2020)
Old 06-01-2020, 08:58 AM   #54
tomm.brz
then no idea at the mom, it looks like a traction control cut but i can't help you
Try pedal dance
or even the pedal dance that ecutek offers in the app, it s at the end of the list under DTCs, called Traction Control i think
Old 06-05-2020, 03:03 PM   #55
tomm.brz
is the hose with maf same diameter as the one you had with fa20
Old 06-05-2020, 03:18 PM   #56
tomm.brz
what a beast.
Did you resolve the throttle closing while spinning?
why don t you try e85 :P
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 03:53 PM
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 06:31 PM
ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-21-2014 12:16 AM
Release Series 1.0 FR-S & FT-1 Pics from NYIAS (Warning: iPhone Pics) TM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 04-30-2014 04:31 PM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-12-2012 12:29 AM
