#44 | |
ProCrastinationConsultant
#45 |
I've read some report of Centric warping after 6 months.
https://www.amazon.com/Centric-Parts.../dp/B000BZXR5Y I'd rather spend more and get quality parts. Gonna look up Power Stop & DBA Last edited by GrantedTaken; 09-13-2019 at 10:48 PM. |
#46 | ||
Some companies/plants are better than others of course and can make those tight spec parts that many of the others can not. We have taken several large OEM contracts away from our major competitor simply because they could not meet some very tight specs. The other company is probably the go to company on this forum and they could not meet the requirements whereas I doubt many here even knew we make brake components at all much less that we are one of the top three highest volume manufacturers in the world for them. We are constantly testing our competitors quality and know where the other brands stack up against us for both good and bad. And, before anybody, asks NO I can not share that data or I would quickly become unemployed. So in summary if you buy dirt cheap rotors they will be crap no matter who's name is on them. If you stick to mid priced ones for street or light track use they will be fine no matter who's name is on them. If you buy expensive high end rotors you will have some quality. The only caution on any level is don't get suckered into paying big bucks for a cheap rotor because it has grooves holes or other things to make it seem like a good one when really it isn't.
#47 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | wparsons (09-17-2019) |
#48 |
You get what you pay for.
#49 |
So the slotted rotors don't offer any measurable advantage over a solid rotor? Just mostly more marketing wank?
| The Following User Says Thank You to soundman98 For This Useful Post: | wparsons (09-17-2019) |
#50 | |
So on a quality, well designed and properly processed rotor do they work? Most certainly, but at a price. On a cheap one they are mostly just bling for the ricers and could cut the life of the rotor substantially. So... if a brand offers a solid rotor for $10 and one that is identical but slotted for $20 you can bet it was not processed well.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | soundman98 (09-14-2019), Tristor (09-14-2019) |
#51 |
Drives: 2017 Subaru BRZ Limited
| The Following User Says Thank You to Tristor For This Useful Post: | soundman98 (09-14-2019) |
#52 | |
1) Improper bedding procedure after rotor/pad installation. 2) Wheel hub out of true (most shops fail to correctly verify hub and rotor runout with a dial indicator) 3) Improper (excessive) torque applied during tire and wheel installation causing rotor to be forced out of true (this also damages your wheel bearings and hub assembly) 4) Uneven rust build-up on the rotor face from the car sitting parked a long time was not cleared prior to hard braking leaving uneven pad material that exacerbates over time. 5) The rotor had a casting issue during manufacturing which resulted in an uneven surface. Only one of these issues is actually caused by a "bad" rotor, and generally regardless of cause it first manifests to the casual driver around 5000 miles after pad/rotor service. Given this, someone reporting that they experienced "warped rotors" after 6 months means absolutely fuck all about Centric quality. Given the track record of Centric I 99.99999% guarantee their issue was caused by #1, #2, or #3. There's a lot of knuckleheads that don't know what a dial indicator is, don't give a fuck about wheel bearing play, and think 7 ugga uggas on the 1/2" impact is the right torque spec for lug nuts. But you do you man, if you want to spend more money for no reason since you're not doing performance driving, by all means go for it. DBA makes fantastic products too, at a premium price. |
| The Following 4 Users Say Thank You to Tristor For This Useful Post: |
#53 |
Also, I'm out. I've done a lot to try to help you in this thread and you seem to not be receptive to people answering your questions with solid information. I see no point in continuing to waste my time. If you had any clue about parts quality you'd be able to look at my build thread on these very forums and recognize that I don't cheap out or cut corners on anything on my car, and I would never recommend something I wouldn't use myself. But by all means, act like Centric/StopTech is a bad brand because you found one guy who didn't know how to bed in his brakes and spend more for DBA. DBA makes good products too, but for your purpose it's absolutely unnecessary overkill.
| The Following 5 Users Say Thank You to Tristor For This Useful Post: | humfrz (09-14-2019), Mr.ac (09-14-2019), soundman98 (09-14-2019), Tcoat (09-14-2019), weederr33 (09-14-2019) |
#54 | |
Your number 5 is only possible if the customer didn't want to pay for 100% end of line gauging. Like I said before the customer sets the specs and gauging can vary from 100% to 1% depending on their requirements. Not to say that a bad one couldn't slip through or 100% system but to place a failed rotor on a good finished product skid would mean taking it off the reject chute and carrying it about 50 feet to the palatalizing area. There are very few operators that are that ambitious.
#55 | |
http://www.brakeandfrontend.com/warped-rotors-myth/ https://www.apcautotech.com/getmedia...c-8-2018_1.pdf
#56 |
I've had second thoughts. I think I'm going to keep my rotors and just replace the pads. I'll just use centric pads. I agree that centric rotors premium are perfectly fine.
My rotors seem smooth actually upon second inspection . and the lip is not that bad at all |
| The Following User Says Thank You to GrantedTaken For This Useful Post: | strat61caster (09-14-2019) |
| Bad ball joint;possible to just replace balljoint or do I have to replace control arm | kev0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 01-03-2019 03:07 PM |
| Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 02:26 PM |
| Vinyl on driver's seat split open; dealer will replace | babydriver | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 12-20-2014 08:55 PM |
| Why do my Stoptech brakes squeel so loudly? Fix or replace? | eikond | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-20-2014 02:17 PM |
| Help me replace my rear brakes? | PoWn3d_0704 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 02-28-2014 03:55 PM |
