Old 10-31-2018, 08:55 AM   #43
Lantanafrs2
Drives: 2013 frs red
Just what this platform needs lol. But we have a low cg and great balance!
Old 10-31-2018, 09:06 AM   #44
Originally Posted by RZNT4R View Post
That doesn't thicken anything. It is the same stuff regurgitated by the other car blogs just a few days late. There is zero new about this one.
In fact they don't even have the facts from the paper they are quoting correct since they say it is only the Twins and the original says it is all the vehicles.
extrashaky (11-07-2018), Rabidpug (10-31-2018)
Old 10-31-2018, 12:48 PM   #45
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
While I agree they are just repeating the same information, they did not say it is only the twins. They said the twins were the only specific model named so far. Semantics, I know. I must be bored. Lol
Sent from my P008 using Tapatalk
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
The Following User Says Thank You to coryandy For This Useful Post:
Tcoat (10-31-2018)
Old 10-31-2018, 12:51 PM   #46
True enough.
Old 10-31-2018, 01:02 PM   #47
Lantanafrs2
I don't see how there can be 5 years of bad valve springs. That's a lot of questionable wire.
Old 10-31-2018, 01:05 PM   #48
Well considering that the valves were changed in 2017 it could be just the later engines. What doesn't make sense to me is the mention that different models may be involved. Surely they don't all use the exact same springs across all the engine versions.
funwheeldrive (10-31-2018), Lantanafrs2 (10-31-2018)
Old 10-31-2018, 01:24 PM   #49
funwheeldrive
Maybe the factory that produced the majority of Subaru's valve springs failed some kind of quality check?
The Following User Says Thank You to funwheeldrive For This Useful Post:
Tcoat (10-31-2018)
Old 10-31-2018, 01:28 PM   #50
cjd
cjd's Avatar
Drives: 2017 BRZ
If the supplier was getting steel for springs from one of the companies making crap alloys, I'd expect multiple parts to have the same problem. That assumes they don't get every spring from a different supplier, which my limited time working on supply chain management tools suggests isn't unreasonable.
Won't know till the official papers are filed.
Towel packed and ready.
The Following User Says Thank You to cjd For This Useful Post:
Tcoat (10-31-2018)
Old 10-31-2018, 01:32 PM   #51
Would be odd for several different parts to make it past quality checks for a prolonged period but most certainly not out of the realm of possibilities.
If there is any accuracy to the reports we should know in a few days.
Old 10-31-2018, 02:10 PM   #52
cjd
cjd's Avatar
Drives: 2017 BRZ
As long as the solution isn't "lower the redline" ...
My previous car made peak HP at redline and appeared to be still on the climb... done because there was worry about valve spring issues and warranty if they went higher. Pity - I was 2HP shy of the factory crank rating, but at the wheels... without any mods.
Old 10-31-2018, 03:16 PM   #53
Semiihcircle
Drives: 17 BRZ
How did you do that~!!!!
Semiihcircle is offline   Reply With Quote
Old 10-31-2018, 05:23 PM   #54
cjd
cjd's Avatar
Drives: 2017 BRZ
Not totally sure. Luck of the draw, maybe. I also hold (as far as I know) the record for 1/4 mile time as shipped from the factory (tires were garbage) so it seems likely luck. I've only been to the 1/4 that once, ever... It was a 2001 ACR and not many were made.
Semiihcircle (10-31-2018)
Old 10-31-2018, 05:55 PM   #55
Lantanafrs2
I'd rather have good valve springs then a red manifold.
Old 10-31-2018, 06:39 PM   #56
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Considering we know nothing about if this recall will happen or which years and models that it applies to... you may very well end up having both bad valve springs AND a boring black plastic manifold with 5 less horses
NCtoBRZ is offline   Reply With Quote
The Following User Says Thank You to NCtoBRZ For This Useful Post:
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
