#43 |
Drives: 2013 Scion FR-S Raven
I'm buying the Racecomp Engineering Yellows and am wondering the same thing?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#44 |
Drives: Whiteout FR-S
OEM camber bolts should be fine, i'm waiting on mine to come in now so i can put my springs on.
#45 |
Drives: Legacy GT
Just to make something clear, the bolts aren't to bring the alignment back into spec with springs. The front camber will be fine without them if you're looking for oem numbers.
The bolts are to take it out of spec in the more negative direction to improve handling. |
#46 |
#47 |
#48 | |
- Andrew |
#49 |
What is the camber in the rear with just the springs?
#50 | |
Drives: 2006 STi
my friend has stacked bolts in the rear of his GD wagon. Im planning to go this route plus using camber plates to see what maximum camber we can get. Ill make some markings and see how it goes . These fenders on the BRZ are looking alot smaller than i thought
#51 |
Drives: Legacy GT
If you're looking for a lot of negative camber without plates don't bother buying new bolts and just slot the holes in the strut. You can get all the adjustment you want (well, until the tire hits the strut/spring), and maintain the stock clamping load. It only takes widening the hole a couple mm to get a lot more camber, and if you wanted you could stick washers in and tack weld them to the struts when things are in the right spot.
Slotting or installing the OEM crash bolts is the strongest and safest way to go. One set of aftermarket bolts is fine and they don't usually slip when installed correctly and set to max negative. Two sets of aftermarket bolts might be pushing it. Last edited by jamal; 10-09-2012 at 12:16 AM. |
| The Following User Says Thank You to jamal For This Useful Post: | ayau (12-27-2012) |
#52 |
Drives: Legacy GT
#53 | |
Drives: 2006 STi
LMAO.
![]() someone needs to make a Camber FAQ thread that goes over everything from front camber to rear camber. camber plates, camber Bolts, control arms, toe arms, camber bushings all that jazz
#54 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I've slotted struts on a couple of different cars, I always use an air powered die grinder. A dremel is really inadequate for the task.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#55 | |
Drives: Legacy GT
I was waiting for RCE or someone to do the camber adjustment faq but I guess I could work on something. |
#56 |
Drives: 2006 STi
sounds good
sold my coils from my old car today so new BCs coming soon . As far as millimeters, how big would the slots have to be for lets say 1 degree of camber? Dont want to grind away too much
| Installed coilover; Too much camber in the back. | trueno86power | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 69 | 04-11-2016 08:00 AM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 01:19 PM |
| Camber plates | Captain Snooze | AUSTRALIA | 7 | 07-02-2012 07:51 PM |
| Camber arms? | skoodge | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 06-24-2012 11:09 PM |
| Excessive negative camber? | MTeator | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-22-2012 11:30 AM |
