Old 01-14-2019, 10:18 PM   #43
Grady
Grady's Avatar
Ok made the commitment today to make the change. No going back now. Items done so far.
Cut the 4 wires for the backup camera from the 28 pin connector and wired into the 5 pin connector on the new radio.
Cut the remote amp on wire from pin 9 of the 28 pin connector and relocated to pin 8 of the 10 pin connector.
Spliced the accessory power wire to the Aux unit assembly pin 5 of the 8 pin connector and pin 1 of the 28 pin connector.(this is suppose to be an ign signal)
Added a ground to pin 1 of the 8 pin aux unit assembly.
This has it working along with the backup camera, Satellite radio, radio, BT streaming, STARLINK Apps.
I still need the wire harness and usb plugs from the 2018 to plug into the aux unit assembly. This should get Apple car play working. GPS antenna. Plastic trim piece. Steering wheel controls from a 2018, this hopefully will get the steering wheel controls working.
The microphone assembly from the 2018 is different (it has 2 mic’s) but it works with the 2017 mic with no changes.
This radio has retained accessory so it does not shut off for a couple of minutes when you turn the car off. It needs a ground signal from one of the door courtesy lights. This plugs in to pin 4 of the 12 pin connector.
Old 01-26-2019, 06:54 PM   #44
Grady
Grady's Avatar
Update, it is all working. I will do a separate detailed post with the wire diagrams. It is well worth it if you can find a totaled car and take the parts from.
Old 2017 parts
The Following 3 Users Say Thank You to Grady For This Useful Post:
METAL_SU-37 (03-28-2019), MrSkubi (02-05-2019), tfp (02-21-2019)
Old 04-05-2019, 05:23 PM   #45
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
I have a 2013 BRZ limited. While it's been in the shop, I've been driving a 2018 legacy and love the Android Auto function. Would love to upgrade my head unit.
I'm guessing your 2017 had steering wheel controls already, so you just needed to ensure the new controls worked.
Did you post a full thread with steps, images, and wiring diagram?
G_Rossney is offline   Reply With Quote
Old 05-01-2019, 10:07 AM   #46
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
If anyone is doing this swap and needs the 2018 steering wheel controls, I have a set. Great work @Grady !
tehShirt is offline   Reply With Quote
The Following User Says Thank You to tehShirt For This Useful Post:
Grady (05-01-2019)
Old 08-08-2019, 08:00 PM   #47
kaferjca
Drives: 2017 Toyota 86
2017 Toyota 86 steering controls work. Grady, can you post a picture of the back of the HU with the needed wires?
kaferjca is offline   Reply With Quote
Old 08-09-2019, 07:21 PM   #48
Grady
Grady's Avatar
I do not have a picture of the back with the needed wires.
Go here and there are links to the WDM that should explain everything.
http://www.ft86club.com/forums/showthread.php?t=132631
Old 08-18-2019, 01:56 PM   #49
G_Rossney
I'm getting a 2018 Limited OEM head unit for free and I want to install it in my 2013 Limited. Glad I found this thread! GREAT Info! I'll be able to pull a lot of the items described in the thread from the donor 2018.
Really want Android Auto in the car.
Old 08-19-2019, 09:38 PM   #50
vitriumGTS
Drives: 1986 Corolla GT-S Hatchback
Beatsonic just got Apple car Play to work on these newer units. Android coming early next year: https://www.instagram.com/p/B1WkOshHu8b/
vitriumGTS is offline   Reply With Quote
Old 01-13-2020, 02:57 PM   #51
dude_inthemoon
Drives: '17 BRZ PP Crystal Black Silica
was there any weird mapping of the buttons? I wanted to try using the 86 TRD edition wheel.
dude_inthemoon is offline   Reply With Quote
Old 05-08-2021, 07:41 PM   #52
Left4deadkillez
Drives: 2016 hyper blue Subaru BRZ
on a 2016 pin 8 is power antenna where would I relocate for amp
I installed the 2018 radio into my 2016 it works all but the door speakers I think it might be due to the amp wiring (the fuse is good) any thoughts?
Left4deadkillez is offline   Reply With Quote
Old 01-20-2022, 11:48 PM   #53
G_Rossney
I've got the same issue. I got everything working in my 2013 except the low end/bass.
I originally upgrade to a 2018 Non-Navi radio and got them working, but after looking at tons of wiring diagrams, I was having a heck of a timing finding the AMP trigger. Finally found it on one of the smaller connectors. I did use the AMP by pass method and that worked.
Old 01-22-2022, 12:38 PM   #54
Grady
Grady's Avatar
These are factory radios. No mapping available, they are designed to work together. You will have to compare the TRD controls to the others to determine if they are different.
Wtb 2017 subaru brz oem radio and dash trim piece jorgerendonjr Want-To-Buy Requests 2 10-28-2017 01:25 AM
2018 Honda Civic Type R V 2017 Ford Focus RS JPxM0Dz Other Vehicles & General Automotive Discussions 0 06-29-2017 11:41 AM
Has anyone replaced their 2017 BRZ Radio?? 007BRZ BRZ First-Gen (2012+) -- General Topics 3 06-02-2017 03:35 PM
2017 BRZ or wait for 2018 redesign? Different car around the same price? Icedude1011 BRZ First-Gen (2012+) -- General Topics 39 03-30-2016 09:38 PM
Noticeably low and sharp volume with AM radio stations with stock BRZ radio tracerit Electronics | Audio | NAV | Infotainment 0 07-24-2013 02:38 AM
