Old 11-17-2017, 07:37 PM   #43
Geez man, I've met drug dealers less shady about their top of the line stuff*
*I'm too lame to actually know any drug dealers
Most people think I'm crazy when they find out my pads cost $1518.
That is not a typo.
Old 11-17-2017, 08:42 PM   #44
strat61caster
strat61caster's Avatar
That is not a typo.
I was amazed the first time you posted that, I think this is the third time I've seen you talk about your magic pads.
All about smiles per mile, and >20x track days on $1.5k pads is cheaper than most track rats spend on consumables.
You don't need to convince me they're worth it, I just wish you'd stop dangling bait to "pm me for details/price" and just endorse the product.
ineedyourdiddly
endless_pain (11-20-2017)
Old 11-18-2017, 07:49 AM   #45
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
Holy S**t. @CSG Mike which pads are you running? I have tried PF08s (6 days and they are gone), DTC60 (3 track days) DTC70 (again 3 days). Killer for us is Summit Point which is hard on brakes. I have OEM caliper, titanium shims and stock blank rotors. Sticking with Hawk because of the contingency dollars. But if you have a better recipe, I am all eyes and ears. Thank you in advance.
Cheers,
Lutfy[/QUOTE]
Somewhere between Hawks and Mike's $1500 pads made of pure unobtainium, you might get good service from a set of GLoc pads. When I traded my STI for the BRZ this year I had GLoc R16 front pads and older Carbotech XP12 rears that fit the BRZ Brembos so I put them on the new car. 12 days on track this year I see no wear on the rears and think I see some wear on the fronts but nothing close to replacement level. Eventually I'll have GLocs all around, but for now everything seems to work just fine and wear is definitely minimal.
JSube is offline   Reply With Quote
The Following User Says Thank You to JSube For This Useful Post:
lutfy (11-18-2017)
Old 11-18-2017, 04:19 PM   #46
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
That is not a typo.
It's worth it for me as I track from Jan to Dec up and down East Coast. Be great if you can share the specs thanks in advance.
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Old 11-19-2017, 12:40 AM   #47
Sorry, gotta PM me for these. Out of my control.
Specs? They're 0.44mu and rated for 800C. These are not pads you buy for their paper specs, nor should you ever buy pads based on paper specs. Brake pad specs are about as accurate as tire UTQG ratings.
Old 11-20-2017, 11:01 AM   #48
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
@endless_pain would you believe I'm at nearly 20 track days on the same set of pads on my BRZ on stock calipers?
Unless AndyBRZ runs the same pad, your comment/question is nonsensical.
endless_pain is offline   Reply With Quote
Old 11-20-2017, 12:57 PM   #49
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Planning to finally venture that far north sometime next year. Which groups use the Grand course at VIR for their events?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 11-20-2017, 01:35 PM   #50
AndyBRZ
AndyBRZ's Avatar
Drives: 2014 Silver BRZ Track Car
TrackDaze offers one day with the grand course.
For me it is the only group I have used for the GrandCourse but I am sure there are more.
AndyBRZ is offline   Reply With Quote
Old 11-20-2017, 01:46 PM   #51
AndyBRZ
AndyBRZ's Avatar
Mine are Ferodo DS1.11 since I had my AP racing big brake kit.
I did get pad breakage in a couple of pads which alledgedly was caused by improper bedding according to the supplier (I do not buy this theory at all but whatever, I've got free replacement as it happened very early and in one day usually).
This is why my next set once I kill these Ferodos will be Carbotech XP-12.
Old 11-20-2017, 02:38 PM   #52
Why? There are many compounds that offer this type of life and capability, albeit at a much higher initial cost than the average entry level race pad.
Old 11-20-2017, 03:04 PM   #53
AndyBRZ
AndyBRZ's Avatar
Old 11-28-2017, 09:11 PM   #54
AndyBRZ
AndyBRZ's Avatar
I cannot thank you enough for sharing your knowledge with us.
Thanks to you, I have decided to go the Exedy route as well and also ordered the 30502AA150 clutch release bearing part from Subaru.
When I removed the transmission, I was greeted by a ball of shredded metal that used to be the clutch release bearing.
Signs of high temperature in the pilot shaft and the fork was scratched heavily as well.
Originally Posted by RallySTI View Post
Subaru updated the release bearing for these cars. The new part number is 30502AA150. This bearing (manufactured by NTN) has a better grease to deal with heat. The new release bearing isn't available in the North American aftermarket as of yet.
I work for EXEDY USA as a technical coordinator for the aftermarket, so I have a little bit of insider knowledge on these parts. We are wanting to supply this updated bearing (seems that all Subaru push type release bearings were revised) with our kits but cannot purchase this part from NTN USA as of yet.
I would stay away from the aluminum flywheels. McLeod is an American owned company but that does not mean their products are all coming from the US. They are one of our customers and supply quite a few of our products, modified and/or painted by them.
The aluminum flywheel are light but at a cost. They are all a 3 piece design ( flywheel body, friction surface and ring gear) and this can lead to warping/run-out issues as well as they are not a strong (burst resistant) as a 1 piece forged chromoly/steel flywheels. The biggest issue I personally had with aluminum flywheel is the friction facing becoming warped and causing disengagement issues well before the clutch needed to be serviced.
When the clutch or RB gives out in my 2013 BRZ (daily driven with as many track days as my work schedule allows) here is my plan of attack.
Velox fork and pivot
Updated release bearing from Subaru
(EXEDY clutch and flywheel for apparent reasons)
Either: the TF02 light weight flywheel and stage 1 (22% reduction in mass vs OE)
or the EXEDY Hyper single TH08SDV (dual friction) (33% reduction in mass vs OE)
The Following 3 Users Say Thank You to AndyBRZ For This Useful Post:
CSG Mike (11-29-2017), RallySTI (11-29-2017), strat61caster (11-29-2017)
Old 11-29-2017, 12:38 PM   #55
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I am still on stock calipers running DTC60's all around with DBA3000 rotors and a velox brake cooling kit. I am not quite as fast as a few of you that have commented but I have 10 days on them (3 at Watkins Glen and i drive to and from the track) and they are still good and I haven't had any fade with this setup. I have to replace the front rotors tho. They are a little past crazing at this point. One day I will be bawler enough to buy a AP Sprint kit. Just thought I would share my stock caliper findings.
This thread is great. Thanks!
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 11-29-2017, 04:47 PM   #56
RallySTI
Drives: 2013 Subaru BRZ
When I renoved the transmission, I was greeted by a ball of shredded metal that used to be the clutch release bearing.
What EXEDY clutch or flywheel did you choose ?
RallySTI is offline   Reply With Quote
2014 PNW Track Days & Info rice_classic Northwest 21 12-02-2014 01:31 PM
MVP Track Time 2014 Midwest Track Dates Feffman Great Lakes 4 04-15-2014 03:13 PM
Touge.ca 2014 Track Events Schedule - 20+ track events!! Touge.ca CANADA 0 04-05-2014 05:57 PM
MVP Track Time 2014 Road Atlanta Track Dates Feffman Southeast 2 03-27-2014 06:51 AM
