Old 04-19-2023, 12:28 AM   #43
grumpysnapper
grumpysnapper's Avatar
Originally Posted by Ruben_86_ View Post
If you manage to solve that vibration, it will surely end up appearing somewhere else
Yes, the root cause is the shift shaft insided the gearbox rear casing...but you can minimise its effects to a very large extent.
grumpysnapper is offline   Reply With Quote
Old 04-19-2023, 12:23 PM   #44
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by grumpysnapper View Post
The rattle is actually internal vibrations transferred from the shift shaft just inside the gearbox then along the rod up into the shifter mechanism.
I took video of this a while back wondering if it was contributing.
https://www.youtube.com/shorts/5ZN0nQEFmlc
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
autoracer86 (04-19-2023), grumpysnapper (04-20-2023), kevaughan (08-23-2023), Swolzee (04-24-2023), Wangspeed (04-19-2023)
Old 04-20-2023, 12:25 AM   #45
grumpysnapper
Yeah, thats the beast.... its annoying.... there is a very slight "play" somewhere internally with the rod in the rear housing, enough to transmit vibrations back through the shaft. Unfortunately the bush that the rod passes out through doesn't provide enough of a dampening effect.
I've been running my "hack" now for about a year, and it's held up really well...even surviving the carbon prop shaft self destructing directly underneath it.
Those harmonics affect the different shifters in varying ways.
Initially I also thought that there might be vibrations caused by the solid mounting of the exhaust to the gearbox. But I built some rubber mounts to eliminate that prospect.... and nothing changed.
The Following User Says Thank You to grumpysnapper For This Useful Post:
Old 04-24-2023, 09:46 AM   #46
Swolzee
Swolzee's Avatar
Drives: Honda Insight
The trick is to try and dampen the rod mechanism as it exits the upper rear casing area, and then dampen the whole shifter arm.
I created a sort of "V" shaped bush that the shifting rod sits/slides in, wedged, on top of the large ring where the prop shaft enters the gearbox.
I use a very large zip tie that creates a small amount of downward pressure to force the rod against the "V" of the bushing.
That takes care of the most obnoxious rattle, but you still need to do some work above the tunnel, inside the car.
I simply take lots (lots!) of fairly dense insulation foam (the sort of black foam you wrap around a roll cage for example), cut it into smallish strips, roll them tight.
Then you go to town and pack/squeeze/push them into the entire cavity around the stick mechanism...so that it sort of fully/firmly encases the mechanism, as high as you can go.
Of course make sure all linkages, and bolts on the shifter are as tight as possible (I use locktite blue)
Its painful, but this removes about %90 of the rattle.
I'd love to see some pics of all this. Especially the bushing and how you have it installed.
Are any of you running stiffer diff bushings?
I'm thinking about going back to my OEM bushings to see how much that helps.
Swolzee is offline   Reply With Quote
Old 04-26-2023, 06:42 AM   #47
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I have installed and uninstalled the differential bushings 2 times to do tests, if it improves the throttle reaction, but for me it does not compensate for use on the road
The transmission insert seemed completely unnecessary
The subframe inserts do seem fundamental and have no inconvenience.
Ruben_86_ is offline   Reply With Quote
Old 04-26-2023, 09:06 AM   #48
grumpysnapper
Next time I'm under the car I'll take some pics.
In my experience OEM bushes or stiffer bushes have made no effective difference.
In the same way that trying to isolate the whole shifter mechanism (from direct contact with the transmission tunnel) with rubber bushes, which I have also tried in the past, made no real improvement.
The vibrations/resonance are all internal to the transmission rear housing, and then transferred directly out along the selection shaft.
Swolzee (04-27-2023)
Old 04-27-2023, 10:18 AM   #49
Swolzee
Swolzee's Avatar
I'd really appreciate this. I need to develop a solution for my sanity.
Old 08-14-2023, 01:01 PM   #50
Texas2016Frs
Bottled FRS
Drives: 2016 manual frs
My shifter rattled so loud that it was audible when playing music loudly.
I almost entirely eliminated the rattle; however, it still rattles above 4700 RPM but not bad at all.
I put a slightly thicker Oring in between the shifter bushings and added two thin neoprene washers. I put one on against the linkage arm and one outside of the supplied nylon washer. This REALLY tightens up the shaft. It is a bear to get it on there. But once I did it almost completely eliminated my rattle.
If you are finding that depressing the button completely reduces your rattle this likely wont do much for you. It worked wonders for me.
Texas2016Frs is offline   Reply With Quote
The Following User Says Thank You to Texas2016Frs For This Useful Post:
DocWalt (08-15-2023)
Old 08-15-2023, 11:56 AM   #51
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
If anyone needs a V3 IRP shifter, lmk.
I’d rather it go to someone here vs some low balling clown from offer up.
SCCA T4 - FRS
New RACING short shifter from Individual Racing Parts Tor Engine, Exhaust, Transmission 161 12-20-2017 09:07 AM
TRD short shifter rattle fix morrisonmagic Engine, Exhaust, Transmission 2 06-01-2016 11:30 AM
WTB: Megan Racing Cat-Delete pipe And short shifter AZ_Racer_1 Want-To-Buy Requests 1 01-25-2015 01:54 AM
NonStopTuning Short Shifter, Info, Ideas, Feedback thread NonStopTuning Engine, Exhaust, Transmission 5 10-23-2014 11:38 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
