Old 05-27-2020, 08:25 AM   #43
ZAZA2912
Drives: TOYOTA GT86
Hello, very interested in your section
the term clocspring often comes up
I can't translate it into French
the translator gives me clock
could you give me other explanations
thank you
ZAZA2912 is offline   Reply With Quote
Old 05-27-2020, 11:01 AM   #44
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
thank you
The clockspring is the piece that carries all of the wires for all the steering wheel controls. It is usually a long flat ribbon that is wound several times around the inside of a plastic case like a spiral spring in a clock.
dragoontwo is offline   Reply With Quote
Old 05-28-2020, 03:21 AM   #45
geraldjust
Drives: MR2, Sliver BRZ
it also houses a very delicate sensor that tells the car in what position the steering wheel is in. if replaced you also need to calibrate it though techstream.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 12-13-2020, 04:21 AM   #46
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
Hey guys, Im also in the process of upgrading my steering wheel and cluster. Im going to use the "old" clock spring. I will use the pedal shifter port to Bypass the issue of one missing port in the main connector. I already have a Pedal shifter connector for the moving side. Now Im in need of some Information and I hope some one can help me out:
-Im In need of 2018 model wiring Diagramm for the cluster and clock spring. Cant find any. I learned that cluster control Buttons are Pins 23,26,29 on the cluster and Pins 2,3,4 on the moving side Main connector of the 2018 steering wheel. But I wasnt able to find out how they are assigned to each other. As well I want to compare the assignment of the cluster Main connector to figure out some issues I have with my LS swap when using the facelift cluster instead of the old one. (MIL is flickering and fuel Level and consumption readings are not plausible)
-I already found out that the 2013 Model 10 pin connector and the 2018 model 12 pin connector are using different pins/crimps. So the depinned wires of the 2018 steering wheel cannot be put into the 10 pin connector. Does anybody know a source where the 2013' pins can be purchased? Also I need some additional pins for the fixed side of the clock spring and of course for the cluster Main connector.
Thanks in advance!
TRS is offline   Reply With Quote
Old 12-29-2020, 02:21 PM   #47
TRS
TRS's Avatar
Hello all,
I have finished my steering wheel upgrade. I succesfully used the "old" Clockspring and also figured out a way to do this without using the shift pedal signal port. So this would also work for AT cars.
As well I found a good source for single terminals. They are also much cheaper then the repair cables which can be bought from the dealership. So just the harness of the remote Buttons need to get New pins to match the old 10pin connector und some more pins and cables to build two little additional harnesses for the radio controls and the cluster controls.
If somebody is interessted I can try to make a little how to. Here is a pic of the final result:
Old 01-09-2021, 05:23 PM   #48
repillows
Drives: 2013 Scion Frs
Originally Posted by TRS View Post
Hello all,
Hey I tried sending a PM about the steering wheel controls but can you make and in-depth video on how it’s done? Thanks!
repillows is offline   Reply With Quote
Old 01-09-2021, 06:55 PM   #49
TRS
TRS's Avatar
As promissed earlier, DIY is done die to request for it. You can find it here:
https://www.ft86club.com/forums/showthread.php?t=143822
I didnt make a video since I believe it would be not the Best way to transport all necessary information.
Old 02-28-2021, 03:08 PM   #50
ZAZA2912
Drives: TOYOTA GT86
hello, where did you buy the 2017 steering wheel with the control buttons
Old 02-28-2021, 03:10 PM   #51
ZAZA2912
Drives: TOYOTA GT86
Old 02-28-2021, 04:24 PM   #52
repillows
Ebay. I bought a 2020 head unit and wiring for clockspring on ebay as well just need to buy an airbag.
Old 07-07-2021, 03:02 PM   #53
Lefafwa
Lefafwa's Avatar
Drives: 2016 BRZ
Maestro vs ASWC-1
Thanks for posting this. Quick question: Is there an advantage of the Maestro kit over the ASWC-1 kit that you'd originally considered?
Is there a reason you chose the Maestro over the ASWC-1?
Originally Posted by demariners View Post
And COMPLETE. After lots of research I was able to do this!
Was able to re-pin the factory clock spring. Adding 5 wires to it. Running then my own wiring to the radio with a Maestro SW kit. Then programming the Maestro SW kit for the correct resistance on the wheel and including the illumination.
What was required to do this was the wheel and airbag with all the wiring and the Maestro SW kit.
So I own a 2015 BRZ and now have a 2017 Steering wheel with OEM buttons. Works like a champ!
2016 BRZ - JR Super Charger
JR Dual Oil cooler/Radiator
Torque Solutions Short Shifter
Lefafwa is offline   Reply With Quote
Old 03-08-2022, 07:46 AM   #54
ZAZA2912
Drives: TOYOTA GT86
Merci
Old 03-08-2022, 07:53 AM   #55
ZAZA2912
Drives: TOYOTA GT86
Hello, I have time so I am attacking the site again.
first question, why do you have to change the airbag?
Why not submit the 2013 one
Old 03-08-2022, 07:55 AM   #56
ZAZA2912
Drives: TOYOTA GT86
for demariners
2013-2016 vs 2017 front pipe Var Engine, Exhaust, Transmission 2 10-09-2018 03:19 PM
2016 BRZ vs 2017 BRZ CBR600RR FR-S / BRZ vs.... 175 11-16-2016 02:47 PM
Trading in 2016 BRZ for 2017 BRZ? acethebrz BRZ First-Gen (2012+) — General Topics 27 10-13-2016 10:02 PM
2017 Tails on 2013-2016? djsyndrome Cosmetic Modification (Interior/Exterior/Lighting) 2 09-04-2016 05:51 PM
Replacing steering wheel and seats mclevin AUSTRALIA 11 06-23-2012 07:53 PM
