#43 |
Drives: 2017 CWP BRZ Limited (MT)
Just got my toycam3 and something isn't right. The picture below shows the harness that came with the radio on the left and the toycam3 on the right. Others have had this just plug and play, but mine are clearly different. The one that came with the head unit plugs into the car just fine. The toycam 3 does not. Am I just an idiot?
#44 |
Drives: 2017 Toyota 86
Kenwood DDX917WS head unit -- any installed?
For subarus you need the ax-subusb2 and you need to make a custom harness from the ax-sub28swc, you can also make the oem aux port to work with this harness.
![]() ![]() ![]() Sent from my iPhone using Tapatalk Last edited by HBKeazy!; 07-17-2017 at 08:21 PM. |
| The Following User Says Thank You to HBKeazy! For This Useful Post: | Jakinit (07-17-2017) |
#45 |
In addition to what HBKeazy! Shared this guide is excellent.
http://www.ft86club.com/forums/showthread.php?t=111866 He also found the guide. |
| The Following User Says Thank You to Jakinit For This Useful Post: | HBKeazy! (07-17-2017) |
#46 | |
Drives: 2017 BRZ PP CWP
Anyway, all's well now. Damn, this unit sounds good with real bass! Thanks again. |
| The Following User Says Thank You to willimusk For This Useful Post: | HBKeazy! (07-18-2017) |
#47 |
Drives: Subaru BRZ
Oem camera
If I have a 2017 BRZ that came with backup camera do I need to get the 12-6v AX tomcam3 adapter?
Does the FM radio work in the states ? |
#49 |
Drives: 2014 Subaru Impreza WRX Hatchback
DDX917ws compatible with 2014 WRX Base Hatch
Hey guys, I'm looking to get a Kenwood DDX917WS from fasmoto shipped to Canada. Just wondering if anyone has any experience with installing this unit into a North American WRX. I see a few have done it in a BRZ but I want to make sure it will be compatible with my WRX. Any info would be much appreciated.
#50 | |
Drives: 2017 BRZ Limited
#51 |
Guys, if you're interested DDX918WS came out: practically same specs, except for a little smaller screen but 720p.
Any chance of region change on 917? |
#52 |
Yes is does. I'm more concerned with the wiring. I still want all my OEM steering wheel controls and usb/aux ports to work. Also I've heard that the tuner doesn't pick up the same frequency.
#53 |
Drives: 1949 UFO
I had the 917 and now the 918. Everything works on my 86 except dvd as it is region locked.
#54 |
#55 |
Drives: 1949 UFO
The viewable screen size is smaller in the new 918. BUT it is HD. There are new settings, icons and better sound processor. My main reason to upgrade was the ability to control the optional Whetron Cameras for 360 viewing. Im still waiting for those to become available.
#56 |
Why would the tuner not work? FM in Australia is 87.5-108 MHz. FM in US is 88-108 MHz. Things like HD Radio and tags might not work, but the stations should tune just fine.
| Kenwood DDX916WS head unit -- any installed? | willimusk | Electronics | Audio | NAV | Infotainment | 39 | 07-27-2017 10:47 AM |
| Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US | GSX-R35 | Electronics | Audio | NAV | Infotainment | 17 | 05-26-2015 03:37 PM |
| Anybody know ... what head unit this is? | chaoskaze | Electronics | Audio | NAV | Infotainment | 3 | 12-21-2014 06:44 PM |
| Soo i installed a new head unit....gaps | Sniper2606 | Electronics | Audio | NAV | Infotainment | 2 | 01-16-2014 05:12 PM |
| Toyota sized Kenwood Navigation unit | Laurie | Electronics | Audio | NAV | Infotainment | 36 | 09-26-2012 12:07 PM |
