Old 02-19-2017, 05:29 PM   #43
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Not the first time that a mod has sidelined a rocker
Scrappydoo is offline   Reply With Quote
Old 02-19-2017, 05:48 PM   #44
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by bfrank1972 View Post
I'd be more inclined to think engine temp/lack of oil pressure would be a culprit.
They all contribute to hasten the demise of an improperly manufactured part.
Inspect all of them. If they show any sign of a characteristic weakness, address that. The number of high-mileage modestly boosted stock engines in existence points to stock rocker arms being up to the task.
Old 02-19-2017, 07:51 PM   #45
Tokay444
Anti stance.
Tokay444's Avatar
Does it? o.0
The vacuum to which you're referring is downstream of the valve. It has to open up against that - like lifting your hand off of a shop vac hose.
Or am I missing something? Honest question.
We know the motor uses reversion at certain rpm ranges, to substitute for the lack of egr valve. That's pulling exhaust back into the cylinder. The exhaust valve opens before bottom dead centre. That's vacuum in the cylinder.
Old 02-19-2017, 08:45 PM   #46
Ultramaroon
not playing cards
Are you saying at the time when the exhaust valve opens, pressure in the combustion chamber is below ambient?
Old 02-19-2017, 09:39 PM   #47
Tokay444
Anti stance.
Tokay444's Avatar
I'm saying boost adds no added stress to opening the exhaust valve.
For reversion to work, pressure in the cylinder needs to be less than in the exhaust manifold. Obviously the engine doesn't run under that condition through the whole rev range. It's done with fancy cam phasing.
Old 02-19-2017, 10:03 PM   #48
Ultramaroon
not playing cards
I'm lost because earlier you were discussing scavenging and then switched to reversion. I think reversion works by setting the exhaust timing really late so both intake and exhaust valves are open at the beginning of the intake stroke.
Oh, well. We agree that it doesn't really play in this failure.
Old 02-19-2017, 11:23 PM   #49
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
At the end of the power stroke, the pressure in the cylinder is still above ambient (for Otto-cycle). To open the exhaust valve, the rocker has to push against the spring force and the pressure in the cylinder. Increasing the torque of the engine will increase the pressure in the cylinder at BDC.
Shoving 40% more air in the cylinder would reasonably result in 40% increase in cylinder pressure when the exhaust valve opens. I think there is an argument that adding the supercharger could have caused the rocker to fail.
However, I suspect the spring force is much greater than the force from the cylinder pressure. I think one of the following is more likely to have caused the failure:
- manufacturer defect (the "it was going to fail anyway" argument)
- previous damage weakening the part (some high-rpm adventurism in the past)
- poor oil, or debris in the oil
I doubt the timing of the failure is a coincidence. I know if I had just installed some new parts, I'd be hammering down a canyon road, too. I'm interested in seeing the teardown.
C4RBON is offline   Reply With Quote
Old 02-19-2017, 11:59 PM   #50
Ultramaroon
not playing cards
Don't forget the force required to accelerate the mass of the valve. That's a huge contributor.
Old 02-20-2017, 09:03 PM   #51
leets4uc3
Drives: Sprintex carbon fiber wide body
Here is a better look at my rocker. Pin didn't walk out so I'm guessing bent valve. I ordered a new engine today and plan to get the other one out this weekend.
http://imgur.com/a/2YnvU
Sent from my Pixel XL using Tapatalk
leets4uc3 is offline   Reply With Quote
Old 02-20-2017, 10:00 PM   #52
Ultramaroon
not playing cards
The plot thickens. Did you overrev?
Old 02-20-2017, 11:04 PM   #53
leets4uc3
Nope. I was at 4k-6k revs because I was stuck behind some cars on the up. The way down I coasting pretty much. I only went half way up the mountain too. About 15 minutes up. I think i started to smell smoking oil shortly after I started to head back down.
Old 02-21-2017, 07:31 AM   #54
Kris86
Kris86's Avatar
Drives: RHD Gt86
oh wow, this is interesting.
u using stock valves and springs?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 02-21-2017, 09:31 AM   #55
celek
Resident Gear Head
celek's Avatar
After reading the pissing contest
In the past even in stock motors it has been an over rev and valve float spitting out rockers. Most tuned cars raise the rev limit for some dumb reason. So above the designed Stock redline the valve starts to float the rocker rattles around and spits out.
Over time you could see stress fractures like the pic above cause total failure.
Other rocker failures have seen the pin come loose and fall out but that's only 1 that I have seen.
Most failures have resulted in valve float above stock red line.
THIS engine is as light and loose as possible to make 200base HP
Combined in the failure here is Forced induction... which can cause valve float with pressure pushing against the valve head.
Keeps the valves open, pistons hulk smash valves, crush the rocker back and out of the engine.
I really would like another detailed reason for failure other than this since I have almost $12k in an engine build and like to avoid turning my money into a pile of sh!t because some companies no names mentioned won't release any information.
celek is offline   Reply With Quote
Old 02-21-2017, 09:40 AM   #56
leets4uc3
Yeah.
Hole in valve cover burdickjp Issues | Warranty | Recalls / TSB 25 11-29-2016 09:37 PM
Here's my luck… rocker arm put a hole in the valve cover -eXpo- Issues | Warranty | Recalls / TSB 10 09-23-2015 11:58 PM
WTB Frs Passenger Exhaust Hole Cover OMGArisman Want-To-Buy Requests 0 07-20-2015 12:16 AM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
Missing Key Hole Cover? Mrpolarbear Issues | Warranty | Recalls / TSB 12 08-10-2014 06:24 PM
