#43 |
New here!
Drives: 2013 FRS 10 Series
@Overdrive thanks for all the advise. I think a trickle charger wouldn't be a bad thing. As they say prevention is better than cure. I have had a dead battery on my motorcycle and a car. I guess it was just because of the fact that it sat they for couple of weeks then drive a week and sat again for few more weeks.
BTW, I got a quote for the 205/55/16; the Blizzaks WS80 are $798 and Nokian 8's(studded) are for $822. The wheels are extra $380, but will try to find if I can get them cheaper somewhere. I am getting more inclined for the studded Nokians because of the ice and it wears out much less and seems to be pretty close to a performance tire too. @Guru I don't understand the winter beater concept either. Not that rich either to afford two cars and take care of them all. The steel wheels though, what are the specs for that? 16x6.5 5-100 or something different? My only concern is the drive from the parking lot to the tire store (a 3 mile journey). It hasn't snowed in a while though. Any suggestions, should I be worried coz of the stock tires on them. Will take it really slow. |
#44 |
New here!
Haha, I will look for that. I am out of town for few.. can't wait to gete back to get it all preped up for the winter and drive around!
#45 | |
#46 | |
Really, just head for a salvage yard and grab some wheels from another Subaru like a Forester or older WRX/2.5RS if you want 16". You should be able to get them pretty inexpensively, certainly less than $380. I use the 17's from an Outback. The few mm's difference in offset is pretty meaningless IMO and this is the third winter I'm running them with no problems. Get the studded tires or an ice tire where you are, I'm not sold on the WS80's being the best choice.
| The Following User Says Thank You to gravitylover For This Useful Post: | Overdrive (01-10-2017) |
#47 |
Drives: 2015 BRZ Sport Tech CWP
+ on the Nokian Hakkapeliitta 8's. The name alone is worth it. We are not allowed to have studded tires here but if I could it would have been my choice.
#48 | |
Drives: 2016 Ablaze FR-S MT
14 inches on stock height only right? I put Blizzaks on but still have yet to find enough courage to drive on any snow. Used to be a wild child and go out in blizzards in my camry with all seasons though |
#49 |
I sometimes miss studded tires!
#50 | |
I would rather drive thorough deep snow than packed snow/ice anyway.
#51 |
Drives: 2003 S2000, 2008 Fit
Be gentle with all your inputs: no hard braking or flooring the gas, or quick direction changes. Look farther ahead so you can anticipate your next move.
Smooth is safe. Sent from my SM-G930W8 using Tapatalk |
#52 |
New here!
@Guru just the sound of the name makes you want to get them, Hakkapeliitta means light cavalry men. I guess it will be the Nokians.
Didn't knew studs were not allowed in Canada! Thanks for all the advise though guys. I hope I can find the steelies, but it shouldn't be a problem 1 out of every 2 cars is a Subaru in Anchorage!! |
#53 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
I think finding used Subaru wheels is a good choice suggested to you a few posts back. You should be able to get a set cheaply. They don't have to be pretty and perfect, just whole and able to hold air and be balanced. The offset is close enough that fitment will work and you won't have any concerns of rubbing or contacting brake/suspension pieces. Buying new steelies is kinda highway robbery. Find a used set that someone else ate the new cost on, and save yourself some money. You might even find a set of used wheels with tires for sale locally like I did, and spend less than half that high cost you posted earlier for a set of wheels with tires mounted, maybe even with TPMS already installed, too.
Also, make sure you get a maintainer and not just a charger. A maintainer will stop charging fully when the battery is 100%, and then just maintains (heheh) the full charge safely from there so your battery doesn't get overcharged.
-O/D
2016 FR-S, Hot Lava Last edited by Overdrive; 01-11-2017 at 01:04 AM. |
| The Following User Says Thank You to Overdrive For This Useful Post: | why? (01-10-2017) |
#54 | |
But, you lost me when you talked about a battery freezing, when it's in your car parked, in a garage. Where in the USA do you live .....?? I figure if a battery freezes inside of a garage, it is either very low on charge ........ OR you really need to move to a warmer climate ...... ![]() humfrz |
#55 | |
![]() ![]() I had to settle for the R2's. Also an amazing winter tire.
#56 | |
Sittin' Sideways
-O/D
2016 FR-S, Hot Lava |
| Another newbie, another mod list (Suggestions wanted!) | MitchEv | Engine, Exhaust, Transmission | 6 | 04-29-2016 10:58 PM |
| Newbie needs... | Salemate | Canada Classifieds | 10 | 12-23-2015 04:07 PM |
| snow....starting to like snow! | brzr | CANADA | 19 | 01-23-2014 01:10 PM |
| Newbie | Toyota 20v | AFRICA | 6 | 01-18-2014 05:32 PM |
| Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires | stockysnail | Northwest | 36 | 12-19-2013 02:12 PM |
