| Member's Car Journals Car journals by our members. |
#43 |
Pokemon Master
Drives: 2014 Scion FR-S
Exhaust compared to Q300? Really liking this exhaust.
![]() '10 MazdaSpeed 3 Velocity Red Mica - SOLD PDM 2 '14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS |
#44 | ||
![]() Quote:
More aggressive! Right in the middle between the Q300 and N1. |
#45 | |
Drives: 2014 DGM BRZ Limited
I Don't Appreciate Your Lack Of Sarcasm
'14 BRZ Limited '17 Crosstrek '87 Buick Grand National |
#46 |
Drives: '14 BRZ
#47 |
btr.life
Drives: 2022 GR86
How much does the MXP RS exhaust weigh in total? Savings from stock?
#48 |
Drives: Raven FR-S
#49 | |
#50 |
GCS Interior Footwell Lighting Kit
[ame="https://www.youtube.com/watch?v=MS4TBKhM1u8&t"]GCS Interior Lighting Kit - FT86SpeedFactory - YouTube[/ame] New luxury vehicles like the 2017 BMW 5 Series come with ambient interior lights that set the mood of your drive. Granted the price of a new 5 series is about double that of our car, we still wanted to incorporate this luxury feature in our 86. ![]() For the lights we chose to go with the GCS RGB Interior Footwell LED kit with Bluetooth connectivity so we can easily change the colors on the fly from our phone. Everything can be controlled through the Happy Lighting app that’s available for both iOS and Android. There is an almost endless amount of colors, pulses, and gradual color changes to choose from, and it will even pulse the lights to the beat of your music. ![]() The kit comes with 4 LED light strips so we’ve got every seat covered, and we only need to connect two wires to power the entire system, which makes installation very quick. The hardest part about the install is running the LED wire through the center console from the driver’s footwell to the passenger side. But if you enlist a friend to sit at the other side, the process becomes much easier. ![]() This aesthetic mod gives our 86 a greater sense of occasion when you’re behind the wheel. But if the bright LEDs that fill the footwells full of color are a bit too much, you can always tone down the brightness to suit your tastes. |
#51 |
Drives: 2017 Toyota 86 M6
How are those fortune auto prime coilovers? I'm in the market to buy a set of coilovers and was wondering how they do on the streets and at the track? Ill do some occasional track days and auto x and I only use my 86 as a weekend car. Wanna get rid of the body roll and the stock huge wheel gap!
#52 | |
#53 |
Intec Fender Insert Turn Signals ![]() The FRS, BRZ, and 86 each have their own uniquely styled fender garnish, but sadly none of them are functional. So in order to get some practical use out of what is normally just decoration, we installed the fender turn signals from Intec. ![]() Currently these Intec fender insets are only available in gloss black, but that’s perfectly fine with us since it matches our gloss black emblems. On the inside the light strip is powered by an amber LED and it can easily be seen in the daylight. ![]() This will be a very simple install and these fender inserts full replacements and fit just like the oem ganish. For any FRS or GT86 this will be a simple plug and play install since the turn signals are separate from the headlights, and Intec provides a plug and play harness for this application. But if you own a BRZ or 86 like we do, the turn signals are integrated into the headlight, so you’ll have to do a small modification to the harness and tap into the headlight wires. It may sound complicated, but it’s a pretty straight forward install. I explain this more in detail in the video. [ame="https://www.youtube.com/watch?v=03QY6Q3NIFQ"]Intec Fender Turn Signals - FT86SpeedFactory - YouTube[/ame] |
#54 |
Pedal Upgrades
A common complaint with these car is that the brake and accelerator pedals are spaced too far apart, making it a little more challenging to get consistent rev matches for heel and toe. However there are a couple options to tackle this problem, and the two solutions can be combined for better results. The first options is the SRP pedal covers [ame="https://www.youtube.com/watch?v=Dwc3PVXrT-0"]How to Upgrade your Pedals - FT86SpeedFactory - YouTube[/ame] These bolt on to the factory pedals and give the gas pedal an extra ¾” that extends on the side to make it much easier to blip the throttle. ![]() They come in a full pedal set with a grid texture that adds a bit of extra grip and also gives the pedals a completely different look, which in my opinion looks much better than stock. But if you just want the extended gas pedal they sell them separately in a finish that matches the stock pedals. The second option is the Velox throttle pedal spacer kit [ame="https://www.youtube.com/watch?v=FBJyfgXvFWI"]Quick Heel Toe Mod - Velox Pedal Spacer - YouTube[/ame] If you don’t like the idea of drilling into your stock pedals and would rather install something quick and easy, then the Velox Spacer Kit may be a better option for you. It’s goes in between the throttle pedal assembly and the firewall and moves the pedal 15-20mm (adjustable) to the left closer to the brake, and 25mm forward, closer to the driver. ![]() Since there are only four bolts and one electrical connection you need to worry about for this install, it shouldn’t take more than 20 minutes. Both options are going to help make your driving more consistent, but when they’re combined you’re left with a pedal setup that’s close enough to land every throttle blip, yet spaced far enough apart that you can still comfortably operate the pedals wearing boots. |
| The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post: | Scrappydoo (05-30-2017) |
#55 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Those side turn signals would be so much better without that stupid lettering
#56 |
Drives: 2017 86 Coupe
I have three questions,
1. There are a few people selling the component that houses the toggle switches And the duel zone climate controls for the BRZ and the limited-edition Toyota 860 would that be a plug-and-play unit in the new 2017 Toyota 86? 2. Would the instrument cluster with the info screen on right side from a Toyota 860 limited edition, be a plug and play if you also had the steering wheel controls for the right side of the steering wheel? If not what would it take to make them work? Thanks, Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter |
| CSG Mike's personal 2017 BRZ build and thoughts. | CSG Mike | Member's Car Journals | 235 | 09-10-2019 12:03 AM |
| 2017 Toyota 86 | Driftz | Southwest | 3 | 06-04-2016 03:52 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 03:42 PM |
| FT-86 SpeedFactory Vortech Supercharger Build | FT-86 SpeedFactory | Forced Induction | 91 | 09-26-2013 09:02 AM |
| >>FT-86 SpeedFactory One Lap of America Build<< | FT-86 SpeedFactory | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 84 | 05-23-2013 05:22 PM |
