Old 10-16-2016, 10:39 PM   #43
frosty288
frosty288's Avatar
Drives: 2015 BRZ
Originally Posted by VeloxEric View Post
It has the correct supplied hardware for both setups. We have been using it on our shop car with the Full-Race turbo kit at over 300whp for 6 months now, zero issues, functions great.
We have it on another local car that has had power up to 480whp, no issues as well.
Thanks,
Eric
Excellent! I didn't want to get into the wizardary of two individual oil catch cans on a turbo setup and this seems to be a 2 in one deal. The coolant option is a sell as well.
frosty288 is offline   Reply With Quote
The Following User Says Thank You to frosty288 For This Useful Post:
VerusEric (10-17-2016)
Old 10-18-2016, 08:31 PM   #44
Stig29
These are now for sale on our website and soon FT-86 SpeedFactory.
http://www.velox-motorsports.com/#!p...c-c921839a6b69
I noticed during final assembly that the bases on the blue units had some discoloring. I'm not sure what happened during the anodizing process but these are on clearance for anyone that doesn't need a "show quality" AOS. Below is an example of one of these blems.
Thanks,
Eric
Hi Eric,
I have been interested in a OCC or AOS for some time. After much extensive research I came across this unit which from a quality, cost and effectiveness standpoint is in my opinion by far the best option for the FRS both for NA an FI applications.
I am planning to move to FI in the future but for now, would it harm anything setting the AOS up in the recommended FI configuration with NA?
Also, I went to the website and could not find any discounted models as described above. I am assuming they are sold out but just thought I would ask just in case. These units are absolutely worth full price in my opinion, but I would love to save some money if possible.
Thanks
Stig29 is offline   Reply With Quote
Old 10-18-2016, 08:47 PM   #45
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by Stig29 View Post
Hi Eric,
Thanks
I really appreciate the compliments. You are correct about the blems selling out, they went quickly.
It does not hurt anything. You'll get slightly better crankcase evacuation running it in an OEM config but I doubt you would notice a change in MPG. Ideally, you'd want to run both hoses to the intake to get a bit of suction! That's my goal, or perhaps to check-valves to venturi tubes in the exhaust, haven't decided yet, but likely the intake.
Thanks,
Eric
VerusEric is offline   Reply With Quote
Old 10-19-2016, 05:12 PM   #46
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
@VeloxEric
Where exacrly does the mounting bracket pick up?
Does the mouting position play nice with the Ptuning water methanol injection setup?
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 10-19-2016, 07:08 PM   #47
VerusEric
VerusEric's Avatar
Originally Posted by Spartarus View Post
@VeloxEric
Installation Manual: check out step 2.10 and 2.11. Should answer most of your questions. If you still have some, I'll grab new pictures! Just let me know of what exactly.
Thanks,
Eric
Old 10-19-2016, 10:45 PM   #48
Spartarus
...Just add nauseum
Spartarus's Avatar
Thanks,
Eric
Thanks,
That answers all of my questions.
This will fit with the Ptuning WMI kit.
I'm thrilled.
-Spartarus
The Following User Says Thank You to Spartarus For This Useful Post:
VerusEric (10-19-2016)
Old 10-26-2016, 02:26 PM   #49
frosty288
frosty288's Avatar
Drives: 2015 BRZ
Just placed my order for this bad boy. Changing my intercooler this weekend so figure it would be a good time to clean out the pipes and install the AOS
VerusEric (10-26-2016)
Old 10-26-2016, 03:25 PM   #50
sato
sato's Avatar
Drives: Dodge Patitas
Will stock vehicle benefit from this very beautiful and functional addition?
Old 10-26-2016, 04:11 PM   #51
VerusEric
VerusEric's Avatar
Yes. The OEM setup most certainly coats the intake manifold with a thin film of oil.
Our very very early prototype design with 1k-1.5k miles of daily use, no abuse.
So yes, it will benefit and collect oil, most definitely.
Thanks,
Eric
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
new2subaru (10-26-2016), sato (10-27-2016)
Old 12-29-2016, 05:27 PM   #52
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
In the AOS install instructions on PG 8 we're removing the PVC system that goes from the block to the intake tube. I'm running at JRSC setup and this goes to the SC intake tube (pre SC).
On PG 12 looks like green is to the AOS. Then yellow or orange (let's go with yellow) will connect to my JRSC intake. What does the orange connect to? Options are vacuum source or vented to atmosphere.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 12-29-2016, 06:43 PM   #53
VerusEric
VerusEric's Avatar
Forgot to update this thread! We ran another production run of these and they are back in stock . Blue came out great this time and looks phenomenal! They're also on sale till the end of the year .
This is in reference to the forced induction style where we delete the PVC valve and block the intake manifold port, correct? It sounds that way so I will explain in more detail below.
Both yellow and orange go to the intake or are vented to atmosphere or are routed to another source of vacuum (exhaust check valves). This is described in step 2.13.1.4, which is quoted below:
"The point from where the PCV valve used to go on the block typically is routed to the far left location (shown in RED below). The front block location is typically routed to the far right location (shown in GREEN below). The two inner ports, which are the outlets of the AOS, will go to a vacuum source, preferably, or can be vented to the atmosphere (shown in YELLOW and ORANGE below). Vacuum sources include intake or exhaust scavenging through Bernoulli’s principal."
Thanks,
Eric
The Following User Says Thank You to VerusEric For This Useful Post:
Bramick (12-29-2016)
Old 12-29-2016, 06:59 PM   #54
Bramick
Bramick's Avatar
Vented to atmosphere is leaving it unconnected?
Sent from my Nexus 6P using Tapatalk
Old 12-29-2016, 07:01 PM   #55
VerusEric
VerusEric's Avatar
Correct, running the hoses somewhere that connects to nothing.
Old 12-30-2016, 05:13 PM   #56
Bramick
Bramick's Avatar
Sharing my Velox AOS install with Jackson Racing Super Charger (Forced Induction) install.
With Optional Drain Back Kit and Velox Cam Plate
If I'm leaving one hose to atmosphere do I need to install the 3/8" NPT to 1/2" hose adapter on the AOS? I'm thinking no. If not I'm all set.
The Following User Says Thank You to Bramick For This Useful Post:
VerusEric (12-30-2016)
Verus Engineering High Performance Radiator - Gauging Interest VerusEric Engine, Exhaust, Transmission 90 07-08-2023 08:43 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 02:44 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 06:23 AM
Raceseng | Revo Pulleys Information and Release Raceseng Engine, Exhaust, Transmission 3 10-09-2016 12:01 PM
