#43 | |
Drives: Subaru BRZ
![]() . Hilarious. ![]() ![]()
#44 |
Drives: 2013 SWP BRZ Ltd. / E60 M5
I lost count of the number of studs I replaced before swapping to ARP. Haven't had an issue since. Nuts were always taken off with air/electric tools but put back on by hand/torque wrench.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
#45 | |
#46 |
Nuts don't cross thread studs.
People cross thread studs.
Gold. That is a very decent effort, although I fear Ben is about to discover a worst species of person than a deranged fake-bomb builder: judgemental internet arseholes.
#47 | |
Drives: '15 BRZ RA
They build wing boxes for the Boeing 767, 777 & 787 and will build the same in future for the Boeing 777X: http://www.subaru.com.au/news/fhi-ce...entre-wing-box http://www.fhi.co.jp/english/news/pr...12_07_11e.html http://www.fhi.co.jp/english/news/pr...0e_111090.html And this know-how is transferred also to their cars! Anyway, I just mentioned it because there was a question about the quality of Subaru and some side comparisons with Porsche.
#48 |
I sure hope the airlines' mechanics remember to change the wing box studs and nuts after the 74th removal/reinstallation.
#49 | |
#50 |
The Stig's German cousin
Horseshit. On my Celica I easily swapped tires a couple hundred times over 8 years on the stock studs and never once had an issue - and neither did the other ~100 owners on the forums who tracked/autocrossed their cars and also changed wheels regularly. It was simply not an issue.
The number of people I know personally, in real life, who have had this issue with their twin but not their previous car is more than I can count on one hand. The number of twins owners I know in real life can be counted on two hands. The studs suck and they cross thread on their own. |
#51 | |
| The Following 2 Users Say Thank You to joe strummer For This Useful Post: | CSG Mike (06-13-2016), strat61caster (06-13-2016) |
#52 |
I'm not a mechanical engineer so I'll leave that distinction to those in the know. Point is the stud gets ruined and becomes unusable, and it's happened to too many people who knew what they were doing and were being painfully careful when changing wheels due to the reputation of the twins' studs.
#53 | |
Someone quoted 2-3 years to me once. That probably sounds right for the faster cars out there. As you can see in this thread some people get away with longer, but at some point you run the risk of a wheel coming off. Most every car I know that has lost a wheel had R comps and aero, but I also know a street-tired EF Civic that nearly lost a wheel (3/4 lugs were spotted loose). |
| The Following 2 Users Say Thank You to renfield90 For This Useful Post: | DarkSunrise (06-13-2016), Sleepless (06-13-2016) |
#54 |
I've done 100+ on the BRZ with stock studs and have never had an issue. Never had an issue on my other Subarus either. I loosen them by hand and always thread them by hand first, and don't use shitty lugnuts.
#55 |
Drives: 2014 BRZ
A friend had issues with aftermarket lug nuts coming loose and the wheel fell off. turned out the nuts an incorrect shape so didn't properly seat against the wheel. Wonder if this may be causing some of the issues since loosening nuts will damage the studs.
I've been using the nuts from TireRack exclusively and they have performed well.
#56 |
I doubt it. You'd seriously have to go out of your way to buy the wrong lug nuts since almost all aftermarket lug nuts are the 60 degree conical seat all aftermarket and the stock wheels use.
Someone putting the wrong nuts on there and not noticing it when they did is baffling. |
| WTB WHEEL STUDS | TomShugoy | Want-To-Buy Requests | 0 | 02-08-2016 07:44 PM |
| ARP Wheel Studs | FR-S Matt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 11-09-2015 07:50 PM |
| ARP Wheel studs and 10mm hubcentric wheel spacers | S1CNSTY_SUBIE | Wheels and Tires | 3 | 04-17-2015 09:31 AM |
| WTB OEM Wheel Studs | Anthony | Want-To-Buy Requests | 8 | 08-27-2014 04:22 PM |
| Meeting with Subaru field engineer in two weeks | Subie | Issues | Warranty | Recalls / TSB | 35 | 02-25-2013 02:50 PM |
