Old 05-13-2016, 04:16 PM   #43
dallenj
Drives: Grey FR-S
Originally Posted by #maverick# View Post
The Vband inlet is the same size as a t3 inlet. I ran the vband and loved it. Plus a vband is much lighter than a bulky ass t3 flange
What about the inlet diameter is 2.5" or 3" trying to find out what parts i need to mount it on my exhaust
dallenj is offline   Reply With Quote
Old 05-13-2016, 04:26 PM   #44
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Inlet is going from header to turbo, outlet was vband as well and it was 3", run a 3" downpipe
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 05-13-2016, 04:35 PM   #45
dallenj
Drives: Grey FR-S
I know the down pipe should be linked to a 3" I need to know if the up pipe to the turbo is a 2.5" v-band. I haven't really worded these questions properly sorry.
Old 05-13-2016, 09:00 PM   #46
mrk1
Drives: Sterling BRZ Ltd
I have a Precision V-Band inlet flange at my shop, I can measure it tomorrow. Its certainly not 3". I use the Tial housing myself so I don't know this off hand
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-14-2016, 06:07 PM   #47
dallenj
Drives: Grey FR-S
It would be great if you could do that. Thanks
Old 05-14-2016, 07:16 PM   #48
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
The 5858 is a great turbo. Stick with the .82ar in both setups. NON ported shroud. Without cams and a higher rev limit, the 6262 will have a more narrow powerband. But the response from that turbo is amazing for its size. Lag isn't much of an issue, but boost onset will be around 5000rpm. With a 7400rpm rev limit, this leaves you with a narrow powerband.
I'm not a fan of ported shrouds, because they negatively impact the compressor efficiency, and you can still surge with them. I'm also not a fan of too small or too large of exhaust housings. Tried them all. The .82 Vband housing is the best. Delay of boost onset might be only 2-300rpm from the .63 but it pulls much harder up top. Non-ported compressor housing and the .82 AR exhaust is best IMHO, for what it's worth.
I love the GTX3576R turbo. Water cooled center sections last longer. No debate. Precision makes great turbos, but their "air cooled" ceramic ball bearings still have pretty high failure rates. The packaging of the Garrett turbos is slightly better, the CHRA is more narrow, but it requires water cooling.
I'd be willing to bet the 6262 CEA with 16psi will get you to 500whp. But will it have a more favorable powerband to the 5858? Probably not.
Coheed is offline   Reply With Quote
Old 05-15-2016, 01:16 AM   #49
#maverick#
#maverick#'s Avatar
My buddy made 500whp at 17 psi on a 5858 with p&l turbo kit
The Following User Says Thank You to #maverick# For This Useful Post:
Coheed (05-15-2016)
Old 05-15-2016, 07:22 AM   #50
mrk1
Garretts GTW3476 should be considered as well, its new comes in both journal and ball bearing. Cost is much closer to the precision
The Build Thread
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
#maverick# (05-16-2016), FRS Justin (05-15-2016)
Perrin Crank Pulley, Precision Turbo PW39 Wastegate - SOLD Amir Ghadiri Engine, Exhaust, Bolt-Ons 7 02-07-2016 08:59 PM
SOLD Precision Turbo tumbla.jr Engine, Exhaust, Bolt-Ons 2 05-21-2015 10:15 PM
Invida n1 exhaust motiv overpipe injen intake precision 4854 turbo for sale Anthony7515 Engine, Exhaust, Bolt-Ons 7 09-16-2014 10:28 PM
9 SEC -PRECISION 6466 SUB-ZERO MOTORS FT86 CUSTOM TURBO KIT , ENGINE BUILT 600WHP+ SUB-ZERO Forced Induction 44 07-09-2014 09:44 PM
