#43 |
Drives: 2013 FRS Whiteout
| The Following User Says Thank You to Pure Automotive For This Useful Post: | Draco_PR23 (05-12-2016) |
#44 |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
Donnie's?
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
#45 |
Boosted
Drives: Not a supra....yet
makes sense, same issue i had when i looked into the swap. Its the issue of paying at once; only thing a cd009 might be cheaper down the road ( replaceable, will hold more power and waaaaaaaaaaaay smother
#46 |
Drives: Toyota GT86
Subscribed
#48 |
Drives: Subaru BRZ
Waiting.....getting bored....short attention span
| The Following User Says Thank You to Norville Rogers For This Useful Post: | Pure Automotive (05-16-2016) |
#49 |
#50 |
Drives: United States
Nice!
#51 |
Update 5/25:
We have started ordering preventative/necessary parts for the engine. JDM engines are usually a little rough and have been sitting in a warehouse or on a boat for who knows how long. Here are the parts we are replacing: Timing Belt Water Pump Water Pump Housing (The JDM water pump assemblies are completely wack) Spark Plugs Valve Cover Gaskets PCV Breather Hoses Thermostate And this is only what we have found so far, I'm sure there will be more to come as far as that goes. We are currently waiting on a couple of these to come but I couldn't resist at least sitting it in the car so to see where it is so far. ![]() ![]() Up first in the hack and hammer game is the factory heater hoses and the diagonal cross bar mounts. These definitely have to be removed and the heater hoses need to be as short as possible. ![]() I'll be back with more updates once we get some more parts on the engine and make some more room, hopefully we will get the engine to its final mounting point! |
| The Following 8 Users Say Thank You to Pure Automotive For This Useful Post: | 8686 (05-25-2016), Calum (05-30-2016), CxG (01-14-2017), Draco_PR23 (05-25-2016), flippy (07-25-2016), Guff (05-25-2016), hmong337 (05-25-2016), JazzleSAURUS (05-25-2016) |
#52 |
Drives: Subaru BRZ
Cheers for the update.
I'm new to this jdm stuff, what is special about the engine? |
#53 |
Drives: 2015 WRB BRZ
Man I hope this goes well and stays within a reasonable budget. I would really be interested in having this swap done in the future. Good luck!
#54 | |
Now w/ over 400 womprats!
Drives: BRZ LZR
Just to name a few things.
- The Ancient BRZ Sacrament by Zaku |
#55 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Main issue, As I don't mind doing any of the other crap. Are you guys working on being able to supply a plug and play harness? with stock ECU? I would like to just do a simple swap down the road. 1jz vvti with a power fc and exhaust.
797Performance.com
#56 |
Drives: 2014 Whiteout FR-S Manual
Will you be doing anything to help correct the weight distribution? I'm planning on a similar swap way down the road when it's more documented and supported, but I wouldn't want to destroy the handling.
Sent from my XT1575 using Tapatalk |
| Budget V8 Swap (under $10,000) | wutsaiu | Engine Swaps | 146 | 06-11-2018 09:53 AM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| WTB A/T BRZ/FR-S CA Budget 21k | Euan | Want-To-Buy Requests | 4 | 07-21-2015 12:50 AM |
| $2K Budget. What Would You Do? | Skippman | Electronics | Audio | NAV | Infotainment | 46 | 02-22-2013 12:23 PM |
| There goes my MOD'ing Budget | RedRocket | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 10-19-2012 09:14 AM |
