#43 | |
Because compromise ®
Drives: Red Herring
2/ My point is that corner weights are affected by spring height regardless of which springs are on the car. There doesn't seem to be an "objective" corner weight. If I put the original shocks back on the car I am getting oem corner weights. I was wanting corner weights independent of the spring height/rate. I will happily accept that this is not doable or it is not the done way. 3/ I have no intention of speccing a damper curve. I'm not even thinking about it. I am relying on their expertise to valve the dampers appropriately given the spring rates and my intended use. They also want to know the tyres I am using and the sort of lap times I am doing at the tracks I visit.
#44 | |
Drives: '23 BRZ Limited
Excellent. Do you have benchmarks you'll be able to compare to once you get the new stuff on? I know on my Miata at Hallett, going from Flyin' Miata VMaxx coilovers to the 949 Racing BGK setup (ASTs) I dropped about 2 secs a lap on the same tires that were a year older. Hallett being my local track that's pretty technical and bumpy in places. |
#45 |
Drives: Velocity Orange 86 GT
I don't know that you can benchmark something like suspension. We've had 2 second differences in lap times on different days on the exact same car setups simply because of temperatures, how rubbered in the track was after rain etc.
All you can really have is a dyno graph that shows something that you may be looking for in particular and the additional confidence/poise that only a good driver spending some solid time can say. And even them it could be preferance. It's like brake pads. There is no "better" just different. Many F1 drivers use different pads/rotors etc even on the same teams. |
| Question About Negative Camber: More Negative Camber == More Grip at Corner? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 03-10-2019 03:08 PM |
| Question - Black OEM Shift Knob Weight | h8meh8ers | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-22-2015 01:41 PM |
| Turn Signal / Corner Light DRL Question | J_McElwee | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-18-2015 12:25 PM |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 12:38 PM |
| A serious wheel question that goes beyond weight and appearance... | boredom.is.me | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 06-28-2012 11:41 AM |
