Old 07-20-2012, 03:50 PM   #43
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I ordered mine from retrofitsource with my kit
tonystewart is offline   Reply With Quote
Old 07-20-2012, 08:57 PM   #44
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Originally Posted by colHolm View Post
As promised (originally posted here):
Blacked-out headlights on Ultramarine.
Light output:
(this was pre alignment - didn't take a similar shot afterwards. oops)
Now that front shot is beautiful! Great job!
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 07-22-2012, 12:26 PM   #45
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by frs View Post
why not show us how your headlight looks like with the retrofit? any difference from the original look?
Mine look OEM. I thought about blacking them out, but I feel that makes the turn signal stand out more. I will be painting the headlights, but Im still deciding on which way to go with it.
do you need to disable the DRL if you install with the bi-xenon ?
As previously mentioned, you dont need to. I kept the DRL relay, so I still have DRLs and I also have 4 high beam lights.
Originally Posted by tonystewart View Post
For those who've done it, were you as impressed as I was (hugely impressed) by the high beams?
Yep, I love them. But with how bright the output is on the lowbeam, I very rarely need to use them.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-04-2012, 01:15 PM   #46
frs
Drives: frs
where do you connect the wires from the projectors? im confused, this is my first time doing these.
frs is offline   Reply With Quote
Old 08-04-2012, 01:19 PM   #47
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Which wires?
Parting out HERE
Old 08-04-2012, 01:36 PM   #48
frs
Drives: frs
The wires that come with the projector unit that turns on the projector highbeam
Old 08-04-2012, 03:34 PM   #49
tonystewart
After you push thru waterproof cap install ends and install to splitter/jumper wire supplied
The Following User Says Thank You to tonystewart For This Useful Post:
Chamaco (01-22-2019)
Old 08-04-2012, 06:09 PM   #50
frs
Drives: frs
oh, so they go to the factory highbeam connector.
then theres no connection for highbeam bulb?
Old 08-04-2012, 08:09 PM   #51
tonystewart
the jumper connects hid servo to high beams thru jumper
The Following 2 Users Say Thank You to tonystewart For This Useful Post:
86-tundra (12-17-2013), civicdrivr (08-06-2012)
Old 08-06-2012, 01:28 PM   #52
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
As @tonystewart said, you should have received a y-cable in your kit. The female connector goes to the chassis highbeam connector. One of the male connectors goes to the stock highbeam/drl bulb and the other goes to the projector highbeam solenoid.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post:
OjiGeorge (09-07-2012)
Old 08-08-2012, 03:33 PM   #53
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
So excited to do this conversion on my car once it arrives!
Old 08-13-2012, 07:08 PM   #54
keithbribac
Drives: Gray
What is the bulb size of the projectors used in the retro-quick system?
keithbribac is offline   Reply With Quote
Old 08-13-2012, 07:28 PM   #55
tonystewart
H1
civicdrivr (08-14-2012)
Old 08-20-2012, 02:02 PM   #56
Squishy86
Squishy86's Avatar
Drives: Your Car
I did this same mod with the same projectors onto my Accord. It's not as amazing as TSX or RX projectors but is worth the money. Every once in a while TRS will sell "Less than perfect" projectors at half the price. I ordered them and they were near flawless besides a minor scuff on the side of the lens that didn't affect visibility. If you have steady hands, this mod is definitely worth it.
Squishy86 is offline   Reply With Quote
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 07:37 PM
The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion Andrew @ TRS Exterior Parts - The Rest 84 07-23-2012 09:43 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 07:11 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 06:07 PM
Five axis limited retro Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 28 05-18-2012 03:16 PM
