View the official forum sponsors list |
10-10-2014, 01:53 AM | #43 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
subbed... will eventually get around to ordering these.
The Following User Says Thank You to hmong337 For This Useful Post: | Diode Dynamics (10-12-2014) |
10-12-2014, 08:55 PM | #44 |
i have toms tail. this was asked earlier but was taken to PM. is it easy to make the signal side brake light too? and have both the brake and signal blink when signaling?
10-12-2014, 09:51 PM | #45 | |
I think the side part on the TOMS tails is the running light. It is not wired up in the tail light to be a dual-stage light (bright and dim modes) so it would be difficult to make it work as the turn signal. You could make the whole running light portion into the turn signal (instead of the brake light) but generally that's not a good idea because the running lights aren't bright enough to be turn signals. Thanks, Paul
10-12-2014, 10:04 PM | #46 | |
im wanting to make the brake/signal both light up when u brake and both blink when u signal if thats possible with a little bit of rewiring your kit running light strip(outer), brake light is not lit on this pic(middle), signal(inner) mine is red |
10-14-2014, 06:58 PM | #47 |
frank
Drives: Subaru BRZ WRB
I am really liking this.... but is there way to make the turn signal lights to brake light instead of reverse light?
It probably requires a brand new plug-n-play...
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA Build Photo Album - http://bit.ly/brz_wrb SoCal LA 86 Club Member |
10-14-2014, 07:29 PM | #48 |
Drives: 2013 Scion FR-S 10 Series #2013
I've already ordered but I was wondering, I saw that you mentioned an oem connector could be put into the system for true plug and play installation in place of the splice.for those of us alright with the price increase would it be possible to pay the extra to get the oem connections?
10-14-2014, 08:09 PM | #49 | ||
The paper installation instructions that come with the kit will include a number of different scenarios so you can make a custom connection if you'd like! Two t-taps will be included, so you can make the connections yourself if you'd like to make the old turn signal light up as the brake, still light up as turn, or do both, if you'd like, instead of connecting it to backup.
10-14-2014, 08:10 PM | #50 | |
If we do offer it in the future it would probably be a $20 upgrade. Since that would make the kit $50 instead of $30 we decided not to include it for the initial run.
10-14-2014, 08:59 PM | #51 |
Drives: 2014 Scion FR-S|Whiteout
This is awesome. Well done guys!
Quick question: If you have the hyper flash module in place under the steering column, do you need a hyper flash relay in back? My gut says no, but you guys are the experts!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
10-14-2014, 09:42 PM | #52 | |
10-16-2014, 01:20 AM | #53 |
Ridge Racerrrrrrrrr
Ordered!
The Following User Says Thank You to SkAsphalt For This Useful Post: | Diode Dynamics (10-16-2014) |
10-16-2014, 09:03 AM | #54 |
Track Junkie
Drives: Argento Scion FR-S
Just placed a order! I went back to stock taillights and this is perfect!
The Following User Says Thank You to The Slow One For This Useful Post: | Diode Dynamics (10-16-2014) |
10-16-2014, 12:09 PM | #55 |
Add me to the list! Paypal sent! Woohoo!
The Following User Says Thank You to *LongFella For This Useful Post: | Diode Dynamics (10-16-2014) |
10-16-2014, 01:19 PM | #56 |
Drives:
very cool product... placed order!
2014 6-speed Monogram (37J) |
The Following User Says Thank You to zeal86 For This Useful Post: | Diode Dynamics (10-16-2014) |
Similar Threads | ||||
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! | Diode Dynamics | Interior Parts (Incl. Lighting) | 158 | 08-08-2018 06:52 PM |
Adjustable TURN SIGNAL LEDs for FR-S & BRZ ~Choose color & brightness~ Plug-N-Play | KI_ZN6 | Exterior Parts - Lighting | 685 | 02-18-2016 11:03 PM |
** INTRO PRICING** JWM Switchback Turn Signal LEDS For FR-S Owners | JWMotoring | Exterior Parts - Lighting | 212 | 04-06-2014 11:24 PM |
Quickets AND Cheapest Turn signal and DRL LEDs? | BlackyRose | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 06-17-2013 09:52 PM |
