06-16-2021, 07:30 PM | #43 | |
In fact, the AutoX'er may be panic braking, rather than progressively. |
06-16-2021, 07:31 PM | #44 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | TommyW (06-19-2021) |
06-16-2021, 07:32 PM | #45 | |
AutoX'ers should never be pedal dancing, to maximize their performance. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Goingnowherefast (06-17-2021), smg1138 (06-22-2021) |
06-19-2021, 03:30 PM | #46 |
Yes but as a driver I am still learning. Also new tracks that could be bit scary
2013 Series 10 FRS #553
06-19-2021, 05:48 PM | #47 |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Goingnowherefast (06-21-2021), jflogerzi (06-19-2021) |
06-19-2021, 07:10 PM | #48 |
chicken tonight
The Following User Says Thank You to Ultramaroon For This Useful Post: | jflogerzi (06-19-2021) |
09-06-2021, 09:14 PM | #49 |
Just a quick update: Ran it at Sonoma with 200TW tires and will not go back. Always pedal dance! All the time
EDIT** First time at this track ever and there are some spots you can get in trouble
RCE T2's, SPC LCAs -4/2.6 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 v730's 225's Last edited by jflogerzi; 09-08-2021 at 11:37 PM. |
The Following 2 Users Say Thank You to jflogerzi For This Useful Post: | CSG Mike (09-07-2021), Ultramaroon (09-06-2021) |
06-01-2023, 09:35 AM | #50 | |
Drives: 2023 GR 86, Steel Silver, Base
You can use trail braking in other elements but the declining radius sweeper is the most important element to use it. Last edited by dalte2; 06-02-2023 at 07:46 AM. |
The Following 4 Users Say Thank You to dalte2 For This Useful Post: |
06-01-2023, 09:23 PM | #51 | |
Can you show me a datalog from an AutoX where the trail brake application is increasing the ability to turn laterally, without getting into EBD? Keep in mind, this is 1st gen specific, not 2nd gen. |
06-01-2023, 11:16 PM | #52 | |
The point is, trail braking is not easy, but to be at the top of the AX game, you have to do it. It isn't optional. After practicing hundreds of times I'm still not good at it, but it is very helpful. I'm just trying to dispel the myth that trail braking isn't a skill that an AX driver needs to learn. In my view, it is the hardest skill to be learned and therefore probably the last skill a driver should integrate. I run 2nd generation but 2nd gen also has EBD so what is the relevancy of that question? All of the top AX drivers in my region trail brake, no matter the car. And, nearly all have ABS (except the trailered Miata race car) and therefore most have some form of EBD. Let me think of the top cars at my local AX, GT4, Tesla 3 performance, GTI, BRZ, Miata, Z06, SS 1LE's, etc. If they are top 10 at my local AX (of 145), they trail brake. To make it into that elite group, you have to trail brake to save the some tenths to be at the top of the leader list. If you are able to place in the Nats without trail braking, then my hat is off to you. My understanding is top drivers trail brake and it has certainly helped my times. And, I work every event to get better at it to drop more time. If there is some issue with 1st gen and a quirk in their EBD that prohibits trail braking then I'm speaking from ignorance as I have no 1st gen experience. I read your post to suggest that trail braking in AX (in general) was not necessarly and that is what I am attempting to clarify for readers of this forum. Last edited by dalte2; 06-01-2023 at 11:28 PM. |
The Following 2 Users Say Thank You to dalte2 For This Useful Post: | DocWalt (06-02-2023), RedReplicant (06-02-2023) |
06-01-2023, 11:19 PM | #53 | |
06-02-2023, 01:09 AM | #54 | |
High level drivers will develop their own preferences, and will likely do what works for them. |
06-02-2023, 01:11 AM | #55 |
06-02-2023, 01:37 AM | #56 |
Drives: 4 wheels
Come to check some stuff on the forum after a few years. The mighty CSG still knows everything
The Following 3 Users Say Thank You to justint5387 For This Useful Post: |
Similar Threads | ||||
WTB: pedal dance box | captain awesome | Want-To-Buy Requests | 6 | 08-19-2019 12:37 AM |
Pedal dance problem | Sapphireho | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 07-31-2017 09:25 PM |
Pedal dance | Simqc | Issues | Warranty | Recalls / TSB | 6 | 05-22-2016 09:56 PM |
OFT - Pedal Dance Mode. | RustySocket | Software Tuning | 2 | 08-24-2015 06:55 PM |
Pedal Dance Device | robot | Tracking / Autocross / HPDE / Drifting | 3 | 01-10-2014 09:26 AM |
