go_a_way1
Old 11-29-2020, 11:28 AM   #5573
peaches
Drives: '14 BRZ Limited
Originally Posted by mrg666 View Post
Aluminum foil is a nice idea and I think it is indication of electromagnetic interference. That should be dependent on the route cable runs through. The alternator is on that route and that could be the culprit. I bought the following replacement cable. And there has not been any p0172 for a long time now without aluminum foil.
https://www.bmotorsports.com/shop/pr...d/3307%7B2%7D5
The link doesn't work
peaches is offline   Reply With Quote
Old 11-29-2020, 01:23 PM   #5574
mrg666
pessimistic skeptic
mrg666's Avatar
let me do that again
Old 11-29-2020, 02:41 PM   #5575
peaches
That one works. So far it's still running fine, but I'll keep it in mind.
Old 12-02-2020, 03:22 PM   #5576
degozaru
Drives: 2016 oceanic frs
Originally Posted by jflogerzi View Post
Did you goto a standard smog shop?
I was reffed. I went to a state referee, it's basically a whole car inspection.
degozaru is offline   Reply With Quote
The Following User Says Thank You to degozaru For This Useful Post:
mswbrz (12-03-2020)
Old 12-02-2020, 04:14 PM   #5577
jflogerzi
jflogerzi's Avatar
Yuck...
2013 Series 10 FRS #553
Old 12-03-2020, 12:49 AM   #5578
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Where do u live bro ?
mswbrz is offline   Reply With Quote
Old 12-07-2020, 03:05 AM   #5579
degozaru
california
Old 12-16-2020, 12:06 AM   #5580
ExpertZero
Drives: FR-S 2015 Halo
Just hit over 35k miles on the jrsc so far in almost 3 years with the kit. So far no issues. Used an after market spring valve recommended from here years ago. Just changed my filter with a new one. Will do the oil and filter in the next two months.
ExpertZero is offline   Reply With Quote
The Following 3 Users Say Thank You to ExpertZero For This Useful Post:
CSG Mike (12-24-2020), HaXx (12-16-2020), mrg666 (12-19-2020)
Old 12-16-2020, 01:32 AM   #5581
HaXx
Drives: jrsc_brz
Wow, imagine that. Can you say that again so all the clowns who tell people to budget a spare engine when they go forced can hear you?
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following 3 Users Say Thank You to HaXx For This Useful Post:
CSG Mike (12-17-2020), Jmonty (12-27-2020), mrg666 (12-19-2020)
Old 12-16-2020, 08:38 AM   #5582
AndreC
Drives: Fast track beast
Which spring valve did you get? Referring to the recirculation valve?
It's on my to-do list.
Sent from my SM-G973W using Tapatalk
AndreC is offline   Reply With Quote
Old 12-18-2020, 02:53 PM   #5583
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
Out of curiosity, in the first picture, is the end of the silicone connector on the outlet of your compressor past the lip on the outlet of the compressor housing? It kinda looks like it's not since you can start to see part of the lip of the compressor housing outlet, but presumably you would have a fairly significant boost leak if that were the case.
vfrqqq is offline   Reply With Quote
Old 12-18-2020, 06:06 PM   #5584
bfrank1972
Drives: 2013 FR-S Argento
Wait, so you're saying you *didn't* budget for a spare engine? tsk tsk...
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
HaXx (12-19-2020)
Old 12-19-2020, 09:35 AM   #5585
mrg666
pessimistic skeptic
mrg666's Avatar
I also did >35K miles in 3 years with JRSC. I am not sure if you mean valve springs or spring valve (recirculation valve), doesn't matter. I replaced them both
Old 12-28-2020, 06:17 PM   #5586
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
JRSC comes with Gates DK060791.
https://www.amazon.com/gp/product/B000UO8MAG
You need double sided belt I wouldn't use that one sided Goodyear belt in the picture.
Does the c38 kit use this same belt?
Sent from my SM-N960U using Tapatalk
tfp is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
