#5503 |
Drives: 2017 Camaro 1SS
#5504 | |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
#5505 | |
Drives: Asphalt 2013 FR-S
I was going to say that maybe you didn't put any gear oil in the charger itself but then I remembered that they come prefilled. Also, do you find the whirl and whine of the supercharger to still be obnoxiously loud? If so then don't worry about it, once you get headers installed you'll barely even notice it anymore lol As for the accelerator trim settings on the maps, you would want to confirm with Zach or Bill on how yours is configured but they normally come assigned like this: MAP 1: SOFT MAP 2: STANDARD & Auto Throttle-Blip MAP 3: SPORT (Optional - Fuel Type: E85 or 93) MAP 4: DRAG & Auto Throttle-Blip (Optional - Fuel Type: E85 or 93)
#5506 | |
I just looked up @moto-mike 's kit and it appears that it doesn't require cutting either. Sweet maybe I'll go with that. It's a lot cheaper too. |
#5507 |
Drives: 13 BRZ Limited, 2000 Impreza Sport
Yea I'll post it later, dimensions are too big I need to resize on my laptop. I'm installing the perrin 3" Cai today too and I'll post a pic of that finished as wel
Innovate powered- Corn fed- FBM tuned
#5508 | |
The 4 maps... is there a difference between 1 and 2 besides auto-blip? |
#5509 | |
![]() All the headers I've heard definitely make the car louder. The only real way to tame them that I've heard is to stick with the stock muffler. The oem muffler keeps the exhaust quiet except for when you're really revving it out. It is often said that you don't get any real performance gains from aftermarket mufflers/axlebacks so you'll only be missing out in the looks department. The oem muffler is also designed to work with the aerodynamics of the car. Without a rear diffuser an aftermarket muffler will generate more drag and lift at higher speeds. Map 1 is SOFT (ECO mode). Personally I don't like this mode at all. It makes the car feel vague, less responsive and slow. Map 2 is Standard and it provides you with the throttle response that you should already be accustomed to.
| The Following User Says Thank You to MINOCIN For This Useful Post: | brianhj (10-19-2014) |
#5510 | |
| The Following User Says Thank You to poorsche For This Useful Post: | brianhj (10-19-2014) |
#5511 | |
Twin Screw You
| The Following User Says Thank You to Dustin For This Useful Post: | brianhj (10-19-2014) |
#5512 | |
How soon after resetting AVG MPG should i start seeing normal numbers? I'm at like 12 AVG MPG but I'm assuming it's because I just reset it by disconnecting battery? |
#5513 |
Before and after perrin 3" big maf cai. Lots of red plasti dip and lots of patience and it turned out pretty good.
#5514 |
I like the red intake tube!
#5515 |
Would anyone be able to record the supercharger whine from inside while idling? And giving it a little gas, maybe to 2k rpm or so, back and forth a few times.
#5516 |
Thanks, I originally plasti dipped it black because I didn't like the smooth plastic finish. It held up so well that I decided to get the red perrin tube and match it. I'm very happy with how it turned out. Also dipped my yellow fluid caps black and battery tie down red. Cheap way to clean the engine bay up.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
