Old 09-11-2014, 04:58 PM   #533
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Lots of boosted people change to a taller gear ratio. I would imagine because 1st and 2nd get kind of unmanageable with enough power at the factory ratio. So I guess tires would be another way to go about it.
I actually plan on getting 16" wheels in the future and going smaller than stock on the outer tire diameter, so it's pretty funny that all this time I've been running bigger tires.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-11-2014, 05:38 PM   #534
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by industrial View Post
I dont know about that. A 1 inch tire height difference is pretty extreme. It's like running a 3.9 diff as is. You don't gain any tread width with a taller tire and gain sidewall flex and weight. I don't see the advantage here.
Yeah, but he can regear around that extra height. If he planned 4.56 he can go to 4.88 and beat the extra tire size.
Here is a great place to experiment with gear ratios and tire sizes: http://www.grimmjeeper.com/gears.html
Save your money then. The smaller tires will get you your regear without having to pay for the ring, pinion, and labor. See the above link and plan accordingly.
Luckrider is offline   Reply With Quote
Old 09-11-2014, 05:49 PM   #535
Anthony
Weight Nazi
Anthony's Avatar
Well I wanted to go pretty aggressive. Like 4.88ish. I don't know if I'd have to run Honda Ruckus wheels to get the same results. I'll check that link on my computer later. Still at work for 12 minutes.
Old 09-11-2014, 05:53 PM   #536
Luckrider
Luckrider's Avatar
You can always go 5.13 to keep the larger tires. I come from the Jeep world and gears solve everything so I know the desire for low gearing... especially with a car that is only driven for performance.
The Following 2 Users Say Thank You to Luckrider For This Useful Post:
Anthony (09-11-2014), kavanagh (09-11-2014)
Old 09-11-2014, 06:28 PM   #537
Anthony
Weight Nazi
Anthony's Avatar
Nah, I'd rather have smaller wheels and tires. Less weight, less flex, and cheaper to replace.
The Following User Says Thank You to Anthony For This Useful Post:
Luckrider (09-11-2014)
Old 09-11-2014, 08:46 PM   #538
kavanagh
Fat on Corn Syrup
I thought I saw some Aussies running 15" rims... I'll see if I can find it. Because that would get you super small and light rims and tires and the reduced final drive.
Old 09-11-2014, 09:37 PM   #539
Anthony
Weight Nazi
Anthony's Avatar
Well I want those TWS wheels. The 16's are 10 pounds. TEN POUNDS!!! And they're gorgeous.
Old 09-11-2014, 10:59 PM   #540
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Yeah the TWS 16s are hot. I just wish we could get better tire selection in 16s. You have the entire world at 17 in 225/45 but drop down to 16 and it's so limited.
industrial is offline   Reply With Quote
Old 09-11-2014, 11:08 PM   #541
Luckrider
Luckrider's Avatar
It is funny because this is the same issue with Jeeps. Hundreds of thousands of Jeeps had 15" wheels which offered insane amounts of tire options until the Rubicon edition came along in 2003 which gave us Lockers F/R and 4:1 low range from the factory which was amazing, but also gave us 16" wheels which means the very nice factory wheels have to be swapped because the only half decent size 16" tires are for large pickup trucks and this means the tires are too stiff. One factory mounted tire had a load capacity of the Jeeps Gross loaded weight. In contrast, all other factory tires (load range C) and many popular 15" sizes offered load range ratings that were exactly right for the 3400lb Jeep and were also $50/tire cheaper. 16"s are just the bastard size of tires.
The Following User Says Thank You to Luckrider For This Useful Post:
Old 09-11-2014, 11:15 PM   #542
Anthony
Weight Nazi
Anthony's Avatar
They can't all be zingers, I guess.
Old 09-11-2014, 11:22 PM   #543
kavanagh
Fat on Corn Syrup
Primus sucks.
The Following User Says Thank You to kavanagh For This Useful Post:
Old 09-11-2014, 11:37 PM   #544
Anthony
Weight Nazi
Anthony's Avatar
Get out of my thread. Ben Stiller sucks.
Old 09-11-2014, 11:41 PM   #545
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Damn blue collar tweakers.
Old 09-12-2014, 12:13 AM   #546
kavanagh
Fat on Corn Syrup
Well, they can't all be zingers. But zoolander slayed me because I worked at Victoria's Secret. Entire movie is fact.
mother fu(king winning!
