Northern California NorCal
Old 01-06-2015, 06:30 PM   #5419
Kaotic Lazagna
Drives: GR Corolla
I would guess it just has something to do with the formulation of the gas. Different brands have different blends (ie different ratios of heptane, ocatane, detergents, oxygenators, etc.) which can affect the stoichiometric ratio (basically, the ideal/perfect AFR) of that given gas. Since our cars are equipped with a fueling system computer and O2 sensors, it adjusts the AFR to compensate for the different blends. So basically, your car maybe running slightly richer on one blend (hence the black carbon deposits) and leaner on the other. This doesn't necessarily mean one gas is "cleaning" your engine better than the other.
But then again, I could just be full of BS, so I will just shut-up now...
at the last sentence.
Running rich is safer for the engine, correct? Might also explain why I get less mpg with Chevron compared to 76. Hmmm, which company to stick with? Choices, choices. Haha
Old 01-06-2015, 06:37 PM   #5420
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Rich is technically "safer" because its less efficient (engine runs cooler), but can still harm the engine due to fowling. I don't think either is harming your car.
And answer to your question? Shell V-power, because no crickets
Old 01-06-2015, 06:52 PM   #5421
PMok
Codename: Stitch
PMok's Avatar
I preferred to run Shell or 76 because no crickets, but I noticed through monitoring in my OFT that it was causing a little bit of knock. Bringing my IAM down to about 0.85 sometimes. E85 takes the crickets away.
But this last time I switched back to 91 from E85, I filled up with Chevron. Like clockwork the crickets came back, but you know what? No knock / IAM drop. So I think although further testing is required, I will take crickets over knock/loss of power any day. YMMV
Old 01-06-2015, 07:05 PM   #5422
BigFatFlip
BigFatFlip's Avatar
What does "IAM" stand for again? I've never really had the chance or the equipment to monitor my engine, so I just stuck with what "felt/sounded" better. My 6 mile daily commute to work is probably worse for my engine than a slight knock.
Old 01-06-2015, 07:12 PM   #5423
Kaotic Lazagna
Drives: GR Corolla
+1 on what IAM stands for again. lol.
So far, with Shell, 76, and Chevron, I've had crickets. lol. I haven't noticed any power differences with the three, but Shell and Chevron give me lower mpg.
Old 01-06-2015, 07:15 PM   #5424
PMok
Codename: Stitch
PMok's Avatar
Ignition Advance Multiplier. Basically when the engine is operating normally, IAM = 1.00 and ECU will allow maximum timing advance. When it detects some knock, it starts to reduce IAM and that in turn bluntly reduces amount of advance your engine is allowed to run. So 0.85 means you are running 15% less advance than you could be on better fuel. Due to poor octane content this is a common problem here in CA and also in Australia it seems. But for what it's worth, when I'm driving around and not paying attention to IAM, I could not really feel much of a difference between what 0.85 and 1.00 feels like. Then again, my butt is not that finely calibrated compared to others...
The Following User Says Thank You to PMok For This Useful Post:
BigFatFlip (01-06-2015)
Old 01-06-2015, 07:22 PM   #5425
Kaotic Lazagna
Drives: GR Corolla
It's not a good thing to be constantly retarding timing, right?
Old 01-06-2015, 08:03 PM   #5426
PMok
Codename: Stitch
PMok's Avatar
I'm no engine tech or even remotely scientific, but yeah, retarding timing means you are dialing back to be conservative and trying to save the engine from damage. At a minimum it means you are not making as much power as you could be, if you had better fuel.
A different way to look at it though, is that it means the tune is too aggressive for the fuel provided. Fine tuning the fuel and ignition maps to match the fuel you are using would allow the engine to operate the best it can without needing to retard the timing. Keep in mind our cars are tuned from the factory to operate optimally at 93-94 octane.
Old 01-06-2015, 08:16 PM   #5427
BigFatFlip
BigFatFlip's Avatar
^But seriously though, my thoughts exactly. IMHO cars are meant to function with a range of fuels and environments, which is why the ECUs have feed back loops to allow it to run as efficiently as it can given the conditions. Like P said, these cars are meant to run with 93 octane, and maybe 60-90 deg temps, at sea level, etc. but doesn't mean our cars are better off here than in Colorado (see what I did there P? )
The Following User Says Thank You to BigFatFlip For This Useful Post:
PMok (01-06-2015)
Old 01-06-2015, 09:26 PM   #5428
OmarYasin
OmarYasin's Avatar
Does anyone have a good recommendation for a DD tires? Want something between 250-350 treadwear, i dont want to spend 900 plus, im currently running evo2 ventus 12 hankooks and want something slightly stickier, options as of now Michelin pilot ss or re11s but again i daily drive 10miles a day and frequently hit some back roads to canyon carve ect
OmarYasin is offline   Reply With Quote
Old 01-06-2015, 09:36 PM   #5429
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Bridgestone s-04 pole position are comparable to the PSS, but cheaper. Though not sure either would be a huge change from the Hankooks you are running. Another option is Federal 595 Rs-r. May not last too long but are pretty damn cheap to allow more replacement.
And isn't the re-11 a 200tw along with the Rs3, rivals, and zII?
PMok (01-07-2015)
Old 01-06-2015, 10:11 PM   #5430
OmarYasin
OmarYasin's Avatar
Re11 and rs3 are 200tw but im still considering them
Old 01-06-2015, 10:12 PM   #5431
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
What's your position there?
Senior lead supervisor of the custodial department
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
The Following User Says Thank You to unsurety For This Useful Post:
PMok (01-07-2015)
Old 01-06-2015, 10:13 PM   #5432
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Jk I'm in parts
Kaotic Lazagna (01-07-2015)
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1398 02-08-2019 01:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 01:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-08-2013 11:07 PM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 12:38 AM
