Old 10-06-2014, 02:25 PM   #5405
MAPerformance
Drives: Asphalt FRS
Have you checked your vacuum lines under the manifold?
http://www.ft86club.com/forums/showthread.php?t=62562
Originally Posted by xxscaxx View Post
anybody else encountered any vacuum leaks? I apparently have one and for the life of me can't pin it down. I've clamped every damn hose that is vacuum related, or at least connects off the back of the supercharger. Getting pretty frustrated having my car stall 3-4 times before it starts up.
MAPerformance is offline   Reply With Quote
Old 10-06-2014, 02:30 PM   #5406
xxscaxx
Drives: 2013 SWP BRZ
Yep...those lines are moved because of the SC and they are all clamped. The only one I don't have clamped is the EVAP by the injectors...can't remember if i put a zip tie on it or not though, I will have to check. Thanks for the reminder.
xxscaxx is offline   Reply With Quote
Old 10-06-2014, 02:39 PM   #5407
blown
Drives: ft86
how bad is the vac leak?
blown is offline   Reply With Quote
Old 10-06-2014, 02:45 PM   #5408
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The grey 90degree fitting on the back of the unit sometimes leaks. They don't seem to use sealant on threads and if it rotates it can loosen and leak. I had to use liquid thread sealer and work it in by rotating the fitting back and forth then sealed it with RTV to be sure. That killed the leak I was having.
Old 10-06-2014, 02:55 PM   #5409
xxscaxx
I actually replaced all three with brass fittings with teflon.
I think my issue may be the brass fitting i used for the evap solenoid. Its slightly smaller than the previous line and I think i'm getting a sealing issue. I put on a fuel line clamp on it and just tightened it down really good so ill see if it gets any better, but its very annoying to say the least
Old 10-06-2014, 02:57 PM   #5410
xxscaxx
my short term fuel trim is around -8 to 10, long term pinned at 0. that was last time i checked. I just put on this clamp so I have to re-log it.
my AFR was also high when WOT which is when I initially noticed it, i thought my start issue was e85 related. i don't get on my car much but when i did I was seeing AFRs at 14/high 13s but backed off it immediately.
Zach suggested doing a smoke test but I don't have the equipment or know of any shops around that do it so i'm just going to try to pinpoint it as best I can.
Old 10-06-2014, 04:36 PM   #5411
blown
Drives: ft86
seen it done by watching STFT and a propane tank. otherwise a smoke machine would be the best bet.
Old 10-06-2014, 04:56 PM   #5412
Draco-REX
Corner Junkie
Draco-REX's Avatar
I used brake cleaner. Shot it at suspect areas and listened for a rpm jump.
The Following User Says Thank You to Draco-REX For This Useful Post:
xxscaxx (10-07-2014)
Old 10-06-2014, 05:51 PM   #5413
blown
Drives: ft86
anyone use the perrin oil cooler with the stage2 innovate kit?
Old 10-07-2014, 01:56 AM   #5414
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hi All,
Check out DSport magazine. We broke well past 300whp with our FlexFuel Kit, 69mm pulley and Tomei full header back exhaust. The full article is in this months DSport Magazine. This was on the stock intake and intake filter. And then add a Airaid intake, 310whp...
I think we have hit the max, for this package, as everything is tapped out, including stock clutch and injectors.
DSport Magazine - Nov 2014 (Dyno Jet SAE Corrected)
DSport Magazine - Nov 2014 (Delicious FlexFuel Kit)
Cheers,
William Knose
The Following 9 Users Say Thank You to DeliciousTuning For This Useful Post:
8686 (10-07-2014), CK_Bladesmith (10-07-2014), Ethan (10-07-2014), Lawnik (10-07-2014), MAPerformance (10-07-2014), MINOCIN (10-07-2014), poorsche (10-17-2014), R2 (10-07-2014), sam69 (10-07-2014)
Old 10-07-2014, 08:22 AM   #5415
sam69
Drives: GT 86
Love ur work and still looking at all the options to get my 86 retuned.
Not in any great hurry as I figure that things can only improve for tuning this platform over time but it appears now that you think you've reached the limit for power out of the Sprintex setup.
William how would that whp figure compare to a mainline dyno and what was the temp / humidity and elevation where the dyno run was done ?
I have a Perrin 2.5" cat back and over pipe atm and are about to fit a set of Tog 4 into 1 headers very soon and have just got an innovate wideband as well to keep an eye on afr's.
Also I can't get e85 where I live so are looking to go water meth inj and was wondering if this would give similar results to e85
I could send you a dyno graph from my car if that helps
Thanks ...... sam69
sam69 is offline   Reply With Quote
Old 10-07-2014, 08:54 AM   #5416
Captain Caveman
Drives:
How much more could we expect from the 210+?
Sent from my MB860 using Tapatalk 2
Captain Caveman is offline   Reply With Quote
Old 10-07-2014, 10:01 AM   #5417
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
I think Sprintex posted recently that it would be a ~10% increase.
Sellout is offline   Reply With Quote
Old 10-07-2014, 10:46 AM   #5418
xxscaxx
Yeah I will do that later with some electronic parts cleaner. Forgot about that little trick. Thanks!
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
