10-01-2014, 09:14 PM | #5391 |
PhoneFlash by EcuTeK
Hi All,
We have been busy working on our FlexFuel Kit and it will be ready for SEMA. As an FYI we are also working on making sure our Flash and Go tunes (Pure MAP sensor, not hybrid) works on the Sprintex Kits also. So far everything has been running well on our in house vehicles on our Delicious Tuning 11 PSI map sensor with no other changes needed to your vehicle. So now you can see your real boost levels in your logs and through the Torque Pro application. The benefit of this? This opens up the MAF voltage input value so we can use it for our FlexFuel Kit and Flash & Go Tune while still retaining all the readiness checks on the vehicle for smog. Or we can use the input for many other features that are coming down the road. Cheers, William Knose Delicious Tuning |
10-02-2014, 09:42 AM | #5392 |
Drives: GT 86
Looking to buy a good quality strut brace and would like to know which brands clear the Sprintex charger looks like white line is one of them just wondering if any others will clear...
10-02-2014, 09:54 AM | #5393 |
Drives: 86
My Ground Control clears it. But, you would need to also buy their camber plates and a spacer. If you plan on tracking, camber plates are a good investment.
10-02-2014, 10:11 AM | #5394 |
Drives: GTS86 Manual
10-03-2014, 02:23 AM | #5395 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
10-03-2014, 04:11 PM | #5396 |
Drives: 2014 WRB BRZ
SC install tips and advice
I just wanted put a link to a post I started asking for help with installing a Innovate/Sprintex SC onto my car. If you guys have any special tips or advice, I'd love to hear it before diving into the installation next weekend. Thanks
http://www.ft86club.com/forums/showt...97#post1971097 |
10-03-2014, 11:14 PM | #5397 |
Drives: '13 Raven FR-S
Whiteline strut bar clears as well.
10-04-2014, 11:03 AM | #5398 |
Drives: Subaru BRZ
10-04-2014, 11:21 AM | #5399 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
10-04-2014, 02:49 PM | #5400 |
Yep looks like it except you can get the Cusco one with the MCB which is pretty cool.
10-04-2014, 09:25 PM | #5401 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
10-04-2014, 09:43 PM | #5402 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
10-05-2014, 12:38 PM | #5403 |
LOL I am trying to picture that... The one pulley I saw was already fairly large. Mike have you had one on the dyno yet? I'm curious because the other dyno charts I've seen show a ton of low end torque but then it falls off a lot up top, like peak HP at 6K RPM...
The TVS unit inside the TRD S/C is similar in displacement but a completely different design (roots vs. twin-screw) and doesn't seem to fall off much up top. It has a pretty big pulley for low boost (~8psi) but not quite dinner plate sized. |
10-06-2014, 01:21 PM | #5404 |
Drives: 2013 SWP BRZ
anybody else encountered any vacuum leaks? I apparently have one and for the life of me can't pin it down. I've clamped every damn hose that is vacuum related, or at least connects off the back of the supercharger. Getting pretty frustrated having my car stall 3-4 times before it starts up.
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
