Old 01-07-2013, 03:55 PM   #519
PMok
Codename: Stitch
PMok's Avatar
Yeah to me it seems that the foam gasket is where the water is getting by into the back, then into the small holes around the bulb socket openings. Notice in the pic below, how little bits of leaves/dirt is getting caught on the adhesive which only seems to cover the top portion of the foam gasket. As flimsy as the gasket is, I can see how even just removing the tails once could ruin the integrity of the foam gasket's seal against the lens housing or against the body panels. I'm thinking if you put a ring of silicone or other similar substance around the gasket before installing it, it will help keep the water out of the back?
Old 01-07-2013, 03:55 PM   #520
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by wdninja View Post
Over lunch hour I took the Colin tail lights out and noticed the gaskets from the stockers didn't stay put, which is more than likely why I had water in my trunk and condensation in the aftermarket tail lights. I reapplied them, but not before tracing some templates so I can make my own out of a better (and slightly thicker) silicone or neoprene foam. The stock gaskets are about $11 each, but I venture to say that even new, fresh stock ones would suck.
Thanks for the info...please keep us posted. I have some red Colins on order and I'm disappointed to hear that there are condensation issues with those too.
Phaedrus29 is offline   Reply With Quote
Old 01-07-2013, 04:29 PM   #521
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Good idea. I'm going to order a sheet of 1/4" thick neoprene foam and do exactly that after I cut the templates out. I might cut 2 sets out so I can also test the stock tail light housings with the thicker sealed gaskets.
By the way, when removing the tail light housings, the 4 nuts holding it on are 8mm (5/16" works too). Another thread said it was 10mm. A 8mm deep socket or ratcheting wrench are easiest.
I'll document all these steps incase it works well, then I can use it for a DIY.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 01-07-2013, 05:44 PM   #522
Skibum4444
Drives: 2013 BRZ Limited
Just brought mine in for this. Of course they are back ordered.
Skibum4444 is offline   Reply With Quote
Old 01-07-2013, 06:10 PM   #523
PMok
Codename: Stitch
PMok's Avatar
can someone link to the full TSB for this issue? I have tried searching 5 different ways and can't find it, and I'm not about to go read through 14 pages of this thread hoping to find it. Would be nice if someone who posted in the first page of this thread could link to it so at least it would be easier to find.
Specifically I would like to see the instructions to reinstall the housing, what the torque specs are and what the proper sequence of tightening the bolts is.
Old 01-07-2013, 06:18 PM   #524
gmookher
this?
gmookher is offline   Reply With Quote
Old 01-07-2013, 06:32 PM   #525
PMok
Codename: Stitch
PMok's Avatar
Originally Posted by gmookher View Post
this?
perfect, thank you!
Old 01-07-2013, 09:01 PM   #526
wdninja
wdninja's Avatar
I suck with the pen tool, but here's a rough template for the gasket. I ordered a sheet of 1/4" thick neoprene foam, I'll keep this thread updated with the results of the testing.
Old 01-08-2013, 10:42 AM   #527
pastuch
pastuch's Avatar
Both my lights have been ordered, I'll keep you posted on how the install goes. It's been 3 weeks and they still aren't in.
pastuch is offline   Reply With Quote
Old 01-10-2013, 02:53 PM   #528
alrashwa
alrashwa's Avatar
Drives: '12 370Z Monterey Blue
Seeing some slight condensation coming back in both of the tail lights, this is after they were already replaced a few weeks ago.
alrashwa is offline   Reply With Quote
Old 01-11-2013, 11:05 PM   #529
Siberian Husky
Siberian Husky's Avatar
Drives: 72 240z
Does anyone know is this issue has been rectified by toyota in later builds? I just pulled the trigger on an FRS and it is on its way from the land of the rising sun as we speak--should be here the 28th. Been reading all the horrible issues in this part of the forum and for some reason the only one that really bothers me is this notorious condensation issue. I am also subscribing hoping the member that is going to test a thicker foam gasket finds a cure. These kinds of problems are generally fixed by the popular effort of the community rather than the manufacturer; glad we have some trouble shooters on our side; I'm rooting for you guys!
1.)1992 240sx SE A/T bone stock: The Daily
2.)1972 240z SBC355 5spd: Ratrod Project
3.) .....[undecided]....: Weekend Warrior
Siberian Husky is offline   Reply With Quote
Old 01-11-2013, 11:28 PM   #530
gmookher
i still think its tq spec..
Old 01-12-2013, 01:42 AM   #531
wdninja
wdninja's Avatar
I have posted my DIY for making your own neoprene foam tail light gaskets here: http://www.ft86club.com/forums/showthread.php?t=26217.
I have yet to extensively test the new gaskets. It's raining tonight, but it's supposed to be sunny and warm tomorrow so I'll do my testing then.
Old 01-12-2013, 11:02 AM   #532
Yruyur
Yruyur's Avatar
Got my new tailight installed yesterday. Unfortunately dont get much rain here. Crossing my fingers.
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
