Old 11-21-2013, 10:51 PM   #519
Eric1855
Drives: LP DSP / CSP '13 BRZ
Originally Posted by G_Ride View Post
I believe oil coolers are allowed in SP.
You're right it is in there under allowable mods for SP as long as they meet certain conditions.
Eric1855 is offline   Reply With Quote
Old 01-01-2014, 05:58 PM   #520
EN2_Squirrel
EN2_Squirrel's Avatar
Can the FR-S use the BRZ rear wing?Rear Diffusor? It is in the accessories catalog, it is not spt/sti. or does the FR-S have to use http://www.scion.com/cars/FR-S/acces...wAll&view=grid
EN2_Squirrel is offline   Reply With Quote
Old 01-01-2014, 06:59 PM   #521
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Yes, that's the only fully legal wing/spoiler you can use for STX.
However I'd b surprised if anyone protests a glue on lip spoiler locally because we all know it doesn't do anything. BUT don't quote me on that.
Old 01-01-2014, 06:59 PM   #522
whataboutbob
AutoX-10/10ths every run
14.2.F.1 and 12.3 are relevant.
Even though they are the same car, not sure if the fact that you are talking about a BRZ wing on a FR-S will be allowable as 12.3 references "make", and in this case one is a Subaru and the other is a Scion.
Build thread:Here
Old 01-01-2014, 10:31 PM   #523
xwd
Are you saying the BRZ spoiler is in the accessories catalog? If it is then you could use it, if it's not then you can't.
The rear diffuser isn't legal for either car in STX. It's a port installed option on the BRZ and there is no allowance for a rear diffuser.
Old 01-01-2014, 11:57 PM   #524
EN2_Squirrel
Yes both the deck lid spoiler and rear bumper diffuser are in the accessories catalog. If the diffuser is a factory accessory, I really cant see why i cant have it. It is not spt/sti/trd. Port installed?
F. Addition of spoilers, splitters, rear wings, bumper covers, valances,
side skirts, and non-functional sccops/vents is allowed provided that
either:
1. It is a production part which is standard or optional equipment of a
US model of the vehicle.
“Model” is defined in Section 12.3.
2. It is listed in the vehicle manufacturer’s US accessory catalog
for that vehicle for normal highway use. This does not allow for
parts sold through a manufacturer’s performance catalog (e.g.,
Ford Racing, HPD, MazdaSpeed, Mopar Performance, Mugen,
NISMO, SPT, TRD, etc).
Parts must be installed as directed by the manufacturer. Exact rep
licas (including weight) from alternate sources are also permitted.
Old 01-02-2014, 02:29 PM   #525
piknockout
Drives: 2014 BRZ
either:
Notice it doesn't say diffusers. There is not an STX allowance for diffusers, port installed, in a catalog, or otherwise.
piknockout is offline   Reply With Quote
Old 01-02-2014, 08:22 PM   #526
xwd
Yeah when I looked at the rules last year, the rear diffuser, as useless as it might be, would bump you up to Modified.
Factory rear diffusers are legal in all classes, so port-installed versus factory makes a difference. It's an orderable item on the BRZ when you order the car, but the fact it's port installed makes it not legal.
Old 01-03-2014, 02:36 AM   #527
brianL.
brianL.'s Avatar
Drives: BRZ/1J Supra
Thanks for the info!! I plan to be in c-stock this year but as time goes on this will be the class I'll run.
brianL. is offline   Reply With Quote
Old 01-03-2014, 01:30 PM   #528
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by whataboutbob View Post
I'm pretty sure you are right, provided the one that is installed meets that criteria. No aftermarket stuff though.
Why wouldn't the Five-Axis lip spoiler be allowed? They're pre-installed on a TON of cars sitting at dealer lots. If you buy a car with it would you be forced to remove it?
raul is offline   Reply With Quote
Old 01-03-2014, 02:10 PM   #529
xwd
Yes. If it's not in the OEM accessory catalog or installed as a factory item (meaning it was on the car when it went on the boat in Japan), it's not legal.
Old 01-03-2014, 06:21 PM   #530
NYR Solo
Drives: Subaru & Mazda
Mostly wrong. The 5 Axis piece is not OK unless it is a full OEM replica. More importantly:
Originally Posted by Solo Rules, 2014 Draft
12.4 STANDARD PART
An item of standard or optional equipment that could have been or-
dered with the car, installed on the factory production line, and delivered
through a dealer in the United States. Port-installed options provided
by the factory are considered to be the same as those installed on the
factory production line. Dealer-installed options or deletions (except as
required by factory directives), no matter how common or what their
origin, are not included in this definition. This definition does not allow
the updating or backdating of parts.
edit: stupid vBulletin.
NYR Solo is offline   Reply With Quote
Old 01-03-2014, 06:36 PM   #531
xwd
The "Yes" part was in response to if he would have to remove it.
Did they change the port versus factory wording at some point? I thought there was a bunch of hulabaloo some years ago with the WRX/STi short-shifter because it was port installed? Or maybe I'm just getting old and mixing up dealer installed versus factory/port installed.
Old 01-03-2014, 06:46 PM   #532
NYR Solo
I have been aware of the rule for a number of years. I don't plan to search for old rulebooks to check when.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
