Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > EUROPE
Old 07-31-2014, 03:48 AM   #519
remme
remme's Avatar
Drives: GT86 & Celica T180
Hello Guillome.
I was considering it because the 2014 model has stiffer front mountings than the 2012 version. Normally the pillowballs also allow camber adjustment on a mcpherson suspension. Alignment is spot on on mine, and I didn't lower the suspension. I was thinking of it because it removes quite a bit of the remaining (already little) 'flex' in the front. Toyota did the same on the rear and changed the shocks as well to make it more 'neutral' at the back. However according some of the test drivers it's not as playful (and dangerous) as the original was. Harder rubber mounts are for example part of the TRD accessories (for stock and 'entry' uprated suspensions, but high end racing shocks normally require pillowballs if I'm not mistaking? I don't want to end up with a car that's a pure track machine as I'm doing .... euhhhh 'fast road'.
remme is offline   Reply With Quote
Old 07-31-2014, 04:32 AM   #520
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Pillow ball upper mounts do let you adjust camber indeed, but I'd say it's overkill if you're on otherwise stock suspension. The BRZ is my DD as well and I find it stiff enough on the road, so I am not considering switching to go-faster coilvers.
That's why I went the camber bolt way: quite cheap and gives you that extra ~.7° of negative camber without any compromise on the ride quality. For a DD, I'd say -.9° or so is the sweet spot for a responsive front end.
Old 08-05-2014, 06:29 AM   #521
remme
remme's Avatar
Hello Guillome.
Partially agree with you, but the BRZ has a different suspension setup than the 86. BRZ is stiffer/harder than the 86. Spring rates are not the same. Drive one after the other and you'll feel the difference immediately. Meanwhile I've been testing, and I'm going to keep the rubber top mounts until they're worn out. At that moment I'll see whether going for OEM or harder rubbers (depending on the flexibility -wear&tear-of the entire front at that time) or go for slick looking pillowballs.
Well JoeHK, for normal driving, you will not feel any difference say 98% of the time. The 2% when you do feel the tower brace is when you put torsion on the car's body. Typically I'd say when you turn in whilst braking. Keeps the car flatter than without. The more agressive you drive, the more you feel it working. Apart from that technical reason. and at least counting for 50% of the reason why I bought the brace ... for roughly 200€ and 6 nuts, this is the cheapest and easiest bolt-on thing to do to make the engine bay looking quite 'racy'. The thing just looks yummy honestly speaking. It's like food, the taste is important, but you also 'eat' with your eyes !
The Following User Says Thank You to remme For This Useful Post:
JoeHK (08-11-2014)
Old 08-08-2014, 05:42 PM   #522
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Great track day at the Ring with Skylimit Events.
[ame="https://www.youtube.com/watch?v=W_0-qxLFqq0"]Subaru BRZ - Back to the Ring - YouTube[/ame]
Old 08-10-2014, 06:24 AM   #523
janvier
Drives: white Toyota GT86
meeting 17/08
Hi guys, who's coming to the carpool meeting next week?
Let's say around 14 o'clock.
janvier is offline   Reply With Quote
Old 08-11-2014, 04:37 AM   #524
remme
remme's Avatar
I'd like to come.
As long as I'm not the only one there ...
Sunday, parking Puurs, at crossing of N16 and N17 ; at 14h00
(Fort Breendonk exit ?)
Old 08-12-2014, 05:29 AM   #525
Yrr
Yrr's Avatar
Drives: Toyota GT86
Originally Posted by GT86meMR2 View Post
Yeah sure would be great so as far as i know none in belgium have the cricket problem :p i sure never had it but im in the UK now with my car filled up with shell vpower nitrate and for the first time ever i have those crickets :p and damn it sucks
Still having the crickets?
I think that the twins are very picky what gas is concerned.
Experienced the crickets every time when visiting a gasstation other then BP, looks like the other gasstations (in my neighborhood) sell cheap "premium" fuel and not real RON98.
But luckely after three complete refills with BP98 my crickets are gone everytime.
Maybe you guys have better fuel quality than we have in the Netherlands or in the UK?
Yrr is offline   Reply With Quote
Old 08-12-2014, 07:20 AM   #526
JoeHK
JoeHK's Avatar
Drives: Raven Toyota GT86
i'd like to be in too
I won't be staying too long though since i have to study.
Greetz
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT
JoeHK is offline   Reply With Quote
Old 08-12-2014, 07:29 AM   #527
janvier
okay, that makes 3
Where are the other fanatics; Elbarto, GT86meMR2, ProjectXTR, Guillaume..
Old 08-12-2014, 09:06 AM   #528
remme
remme's Avatar
... hunting crickets ???
BTW, Shell V-power is not "euro98".
And indeed, V-power is different in most of the countries.
Euro95 and Euro98 are very precisely described on what they should be.
RON is a theoretical value, MON is coming much closer to the true knock resistance.
EU95 has RON of 95 minimum to 97.9max, and a MON of minimum 85
EU98 has RON of 98 minimum , but a (MON+RON)/2 value of at least 93
What does that mean : you can't just add some stuff to EU95 to turn it into EU98, but you can turn it into V-power. When you get the knocking, that's when you loose a few%'s of power due to the automatic 'less-pre-advancing' of the ignition. The anti-knock pichs up that sound and starts (should start) protecting the engine.
Not sure what happens however when you start chipping the engine's ECU?
Old 08-12-2014, 01:10 PM   #529
projectXTR
Drives: Sterling Silver BRZ
Ill see if I can get home in time to drop by
projectXTR is offline   Reply With Quote
Old 08-12-2014, 03:32 PM   #530
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by remme View Post
I'd like to come.
I'm coming too
@remme: it's the exit 7 Puurs, from Brussels, you come off the A12, go on the N16 and go left at the first crossing, the carpool is then on the right.
Coming from Antwerp, you cross the N16 on to the N17 and the parking is on the right.
Coming from Sint-Niklaas it's the exit just before the crosspoint of the A12 (Mechelen, Brussel)
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
JoeHK (08-13-2014)
Old 08-12-2014, 06:09 PM   #531
Twinguin
The 86 is gone.
Twinguin's Avatar
Drives: a Pony*& a HotHatch & a Cabriault
Hi guys, one of you been at the Nürburgring today? We noticed a blue BRZ/GT at the "small" parking and later on the Ring. Cheers.
"There is a curse. They say: May you live in interesting times!", Terry Pratchett
Twinguin is offline   Reply With Quote
Old 08-12-2014, 06:14 PM   #532
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Not me!
How many FR-S/BRZ owners are former AE86 owners? DarrenDriven Other Vehicles & General Automotive Discussions 27 06-09-2012 11:35 PM
GT86 pricing for Belgium (Europe) NA_T Scion FR-S / Toyota 86 GT86 General Forum 13 01-15-2012 12:33 PM
MR2 OWNERS Abflug Other Vehicles & General Automotive Discussions 8 09-02-2010 09:35 PM
