#519 |
Late to the party, but just got a call from the dealer that sold me my FR-S to check if I was still the owner.
They said they don't have the parts in yet, but will notify me when they do so I can bring it in. Forgive me since I'm sure it's been asked already (easy to miss in 37 pages), but is this a motor-out situation on a boxer? I'm wondering if I should go ahead and have them do the spark plugs while they're in there. |
#520 |
chicken tonight
Interesting. The springs themselves? o.0
#521 |
Drives: Subaru BRZ
AUTOMATIC
SU003-08061 SPRING-VALVE EG KIT 1 *The kit above includes the following parts. Part Description Part Number Qty Drawing Individually Packaged Parts Inner Compression Spring SU003-07325 16 Fig.2_30 Fuel Delivery Pipe No.2 SU003-00342 1 Fig.2_21 Cylinder Head Cover Gasket SU003-00280 1 Fig.2_27 Cylinder Head Cover Gasket No.2 SU003-00281 1 Fig.2_28 Front Stabilizer Link Assembly SU003-00394 2 Fig.1_11 Nut (Stabilizer Link) SU003-04506 4 Fig.1_12 Nut (Exhaust Manifold) SU003-02872 6 Fig.1_6 A1 kit Bolt (Cowl Brace) SU003-02821 2 Fig.1_1 Nut (Cowl Brace) SU003-02885 6 Fig.1_2 Bolt (Body Mounting Cushion) SU003-02801 6 Fig.1_9 Bolt (Body Mounting Cushion) SU003-02816 2 Fig.1_10 B kit C kit D1 kit Spark Plug Tube Gasket SU003-06775 4 Fig.2_29 Crank Shaft (Timing Chain or Belt Cover) Oil Seal SU003-02180 1 Fig.2_17 Exhaust Manifold to Head Gasket SU003-01111 2 Fig.1_5 C kit Oil Pan Drain Plug Gasket SU003-02159 1 Fig.1_8 Crank Shaft Pulley O-ring SU003-02190 1 Fig.2_16 Timing Gear Case Lower O-ring SU003-02186 1 Fig.2_24 Timing Gear Case Upper O-ring SU003-02183 3 Fig.2_25 Oil Level Dipstick Guide O-ring SU003-00306 1 Fig.2_15 O-ring (Vacuum Pump) SU003-02184 1 Fig.2_23 Chain Tensioner O-ring SU003-02185 1 Fig.2_26 O-ring (High Pressure Pump) SU003-02187 1 Fig.2_22 Fuel Injector Seal (No.2) SU003-00324 2 Fig.2_18 Fuel Injector Grommet SU003-00317 2 Fig.2_19 Fuel Injector O-ring (No.2) SU003-00335 2 Fig.2_20 O-ring (Discharge Hose) SU003-A0025 1 Fig.1_3 D1 kit Throttle Body Gasket SU003-00316 1 Fig.1_4 Radiator Drain Cock Packing SU003-01196 1 Fig.1_7 Clip (Under Cover) SU003-02984 4 Fig.1_13 Clip (Under Cover) SU003-02989 9 Fig.1_14 Clip (Wire Harness) SU003-06476 3 Fig.2_31 Clip (Wire Harness) SU003-06475 4 Fig.2_32 MANUAL SU003-08062 SPRING-VALVE EG KIT 1 *The kit above includes the following parts. Part Description Part Number Qty Drawing Individually Packaged Parts A1 kit B kit C kit D1 kit Inner Compression Spring SU003-07325 16 Fig.4_24 Fuel Delivery Pipe No.2 SU003-00342 1 Fig.4_16 Cylinder Head Cover Gasket SU003-00280 1 Fig.4_21 Cylinder Head Cover Gasket No.2 SU003-00281 1 Fig.4_22 Nut (Exhaust Manifold) SU003-02872 6 Fig.3_6 A2 kit Bolt (Cowl Brace) SU003-02821 2 Fig.3_1 Nut (Cowl Brace) SU003-02885 6 Fig.3_2 B kit Spark Plug Tube Gasket SU003-06775 4 Fig.4_23 Crank Shaft (Timing Chain or Belt Cover) Oil Seal SU003-02180 1 Fig.4_12 Exhaust Manifold to Head Gasket SU003-01111 2 Fig.3_5 C2 kit Oil Pan Drain Plug Gasket SU003-02159 1 Fig.3_8 Crank Shaft Pulley O-ring SU003-02190 1 Fig.4_11 Timing Gear Case Lower O-ring SU003-02186 1 Fig.4_18 Timing Gear Case Upper O-ring SU003-02183 3 Fig.4_19 Oil Level Dipstick Guide O-ring SU003-00306 1 Fig.4_10 Chain Tensioner O-ring SU003-02185 1 Fig.4_20 O-ring (High Pressure Pump) SU003-02187 1 Fig.4_17 Fuel Injector Seal (No.2) SU003-00324 2 Fig.4_13 Fuel Injector Grommet SU003-00317 2 Fig.4_14 Fuel Injector O-ring (No.2) SU003-00335 2 Fig.4_15 O-ring (Discharge Hose) SU003-A0025 1 Fig.3_3 D2 kit Throttle Body Gasket SU003-00316 1 Fig.3_4 Radiator Drain Cock Packing SU003-01196 1 Fig.3_7 Clip (Under Cover) SU003-02984 4 Fig.3_9 Clip (Wire Harness) SU003-06476 3 Fig.4_25 Clip (Wire Harness) SU003-06475 4 Fig.4_26 Last edited by n0thing; 12-20-2018 at 07:11 PM. |
The Following User Says Thank You to n0thing For This Useful Post: | Ultramaroon (12-20-2018) |
#522 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
From what I can tell it's just the differences between the motors require different things to be replaced it seems (gaskets, nuts, etc) |
#523 |
I wanna know why the end links are getting replaced lol
The Following User Says Thank You to finch1750 For This Useful Post: | Ultramaroon (12-20-2018) |
#524 |
chicken tonight
They're anticipating cutting off rusty parts for the sake of expediency, or just normal wear.
#525 |
Makes sense given I had to cut one of mine off lol
#526 |
Rust bucket enthusiast
Wonder if it'd be much to have them replace spark plugs while they're in there...
#527 |
Drives: Subaru BRZ
#528 |
#529 | ||
#530 |
Drives: Subaru BRZ
it pays 12.5 (manual) or 13.8 (auto), that's less than FRM lol
#531 | |
Country Boy 4 Life
Well doesn't that just sound totally reasonable... I Hope that you receive this level of customer service. But, from my experience with local dealerships: They will charge for ANYTHING & EVERYTHING not covered under the recall. I expect them to try and charge me for any additions. (like the spark plugs) My dealership sucks: they ran my bumper into the curb last time I left my car with them. Then parked it so close to a wall that I didn't see the scrape on the passenger side till later that day. (I wondered why my car was parked funny; guess I should have checked it out better before driving off) I called and they basically told me to prove it didn't happen after I left.
I LIKE TIRES! |
#532 | |
Senior gif poster
Drives: 2013 Asphalt FRS
I'm so not thrilled about taking my car in for this recall. I saw someone posted claiming that in some documentation they have if the spring where to fail then it would have likely done so in the first 3k. I asked to please post that image and still waiting. |
The Following User Says Thank You to DandoX For This Useful Post: | Leonardo (12-20-2018) |
Broken Valve Spring | sybrite | Engine, Exhaust, Transmission | 45 | 11-02-2018 04:20 AM |
Valve spring swap | rcmf5525 | Engine, Exhaust, Transmission | 6 | 05-19-2018 03:12 PM |
Jrsc replacement diverter valve issue | Brzxton | Forced Induction | 6 | 12-08-2017 09:39 AM |
GSC FA20 Valve Spring Kits | MAPerformance | Engine, Exhaust, Transmission | 41 | 07-20-2015 10:22 AM |
Skunk2 Dual Valve Spring and Titanium Retainers | limitedblkwrx | Engine, Exhaust, Transmission | 0 | 01-04-2015 11:12 PM |
