Pat.Thornton
Old 09-25-2016, 08:32 PM   #505
sato
sato's Avatar
Drives: Dodge Patitas
Same problem here... taking car to dealer this week to have it checked.
Old 09-26-2016, 08:03 AM   #506
SlammedSilly
Drives: 2015 Ultramarine FR-S
my 15 frs is currently at the dealer, waiting for them to drop the trans and tell me nothings wrong with the car bc they have no idea how to work on my car
SlammedSilly is offline   Reply With Quote
Old 09-26-2016, 09:52 AM   #507
sato
sato's Avatar
Hahaha, true. Or, state it's normal vehicle operation when they can't find what's wrong.
BTW, my 14 FR-S has less than 55k miles, but has a 85 - 90% highway duty cycle.
The Following User Says Thank You to sato For This Useful Post:
SlammedSilly (09-26-2016)
Old 09-26-2016, 11:53 AM   #508
SlammedSilly
if they tell me normal vehicle operation, i will burn the fucking car down. i have gap so idc. haha, still no update and its been there since open. if i don't get any update by 5, i may call and check up on it. go to a drift event in a 92 sentra sedan this weekend isnt going to end well if my car isnt completed, hah
edit: and my car has 33.5k on it... mind you its been happening since 24k and they thought it was the slave, so they bled it and the issue went away for a little then came back
Last edited by SlammedSilly; 09-26-2016 at 11:57 AM. Reason: edit: and my car has 33.5k on it... mind you its been happening since 24k and they thought it was the slave, so they bled it
Old 09-26-2016, 02:59 PM   #509
SlammedSilly
and of course they call me and say its not making the sound anymore. fucking joke. sorry for my language. but this is bullshit. it was making it prior to me dropping the car off yesterday. if i have to go there at somepoint this week to show them the noise im going to freak the fuck out.
Old 09-26-2016, 04:27 PM   #510
SlammedSilly
update: so they haven't dropped my transmission....
but they're only ordering a throwout bearing right now. should have the car back Wednesday/Thursday.... doubting that it'll be done by then
Old 09-26-2016, 05:54 PM   #511
shellslinger
Drives: Whiteout FRS
Don't do it man....I deal with this stuff on a daily basis and its quite obvious. Remember insurance fraud is serious business my friend.
shellslinger is offline   Reply With Quote
Old 09-27-2016, 07:52 AM   #512
SlammedSilly
well i personally wont burn it, thats why you give $100 to a crackhead and give them what they need to do it, hahah
Old 09-27-2016, 09:55 PM   #513
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
I fixed this issue recently on my 2016 BRZ w/19K miles as mine started getting bad with the squeaking sound. The issue causing the squeak is the pivot ball point on the clutch fork that sits inside the transmission.
Where the rubber boot sits on the transmission that surrounds the clutch fork, you need to slide this up and turn it sideways so you can access the hole it covers. Stick your fingers down the uncovered hole on the rear side of the clutch fork with the rubber boot out of the way. Get a feel for the clutch fork and try and to locate the pivot ball point. I found it by locating the center vertical point of the clutch fork and sliding my finger straight down, you will eventually feel the pivot ball point.
Once you get a feel for the location of the pivot ball point, dab some grease on your finger and apply it to the pivot ball point. Get in your car and press the clutch pedal a few times. Re-apply grease, rinse and repeat till the squeak goes away.
Once done, slide the rubber boot that surrounds the clutch fork back in the transmission. I admit, putting the rubber boot back was tricky so take your time and do it right. You don't want dirt getting in there.
Si_Chris is offline   Reply With Quote
The Following 3 Users Say Thank You to Si_Chris For This Useful Post:
humfrz (09-27-2016), Readytoxplod (09-27-2016), tobin (09-30-2016)
Old 09-29-2016, 02:35 PM   #514
SlammedSilly
go to get the car back from the dealer last night, cars not fixed, nor was the center console/trans tunnel console even screwed in. this fucking dealership is on the chopping block after they actually fix this thing.
Old 09-29-2016, 02:59 PM   #515
c4lvinnn
Drives: Toyobaruion
Every time I see this thread, I twitch a little from the spelling of "pedal" that somehow turned into "peddle"
c4lvinnn is offline   Reply With Quote
The Following 3 Users Say Thank You to c4lvinnn For This Useful Post:
Pat (09-29-2016), Sigh-on-Rice (09-29-2016), Ultramaroon (09-30-2016)
Old 09-30-2016, 02:35 AM   #516
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
What started off as just squeaks became worse this cold morning.
Sounds like the HPFP crickets on steroids... Goes away when the clutch pedal is depressed.
I'm going to try the stealership and see what they say.
WARNING: Headphone users
[ame="https://www.youtube.com/watch?v=8ASx3jsTgAo"]https://www.youtube.com/watch?v=8ASx3jsTgAo[/ame]
dhuang is offline   Reply With Quote
Old 09-30-2016, 10:54 AM   #517
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I have the same noise in the morning when the clutch is depressed. Goes away after a couple of minutes of driving or when clutch is not touched.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 09-30-2016, 02:15 PM   #518
Ultramaroon
not playing cards
Ultramaroon's Avatar
That's TOB fail.
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
