go_a_way1
Old 09-03-2019, 11:36 AM   #5111
max20s14
Drives: 14' Raven M/T - 02' is300
Originally Posted by mrg666 View Post
With JRSC, the car is almost the same power/weight ratio with Cayman. However, that does not mean it will match Cayman performance with just JRSC. Oil cooling, brakes, clutch (if manual), wheels, suspension, etc all need to be upgraded so that you can compare with a Cayman. You need to decide if you will enjoy doing all these upgrades/mods (it is hard work and sometimes frustration) and learn your car inside out. If you just want to enjoy driving and not worry about upgrades/mods, get the Cayman.
I come from an sr swapped 240sx been there. I liked the FRS because it was so similar to the s13 I had minus the boost. My frs already has headers tune springs adjustable arms ect... happy with the handling and stance. IF I bought the cayman I would probably buy headers tune wheels ect... for it also
max20s14 is offline   Reply With Quote
Old 09-03-2019, 02:43 PM   #5112
Originally Posted by max20s14 View Post
Ideally a 2009/10
If you're an experienced driver the 987 will need brake and cooling upgrades to perform at the track. You may be better off just customizing the 86 to your specific preference and needs.
Old 09-12-2019, 07:33 AM   #5113
Var
Drives: 2017 Subaru BRZ PP
Originally Posted by peaches View Post
The thing is now, do I have to get the dedicated oil cooler and not use the oil cooler piece from the radiator or are the louvers going to help enough to keep the temps down?
I wonder if it's possible to run an additional small cooler inline or if running the plumbing would be too much of a pain. I just ordered the DROC and the TrackSpeed Vents with the intent of running a Harrop blower later
(or maybe you can try a DIY mister setup for something on the cheap)
Var is offline   Reply With Quote
Old 09-12-2019, 09:11 AM   #5114
peaches
Drives: '14 BRZ Limited
Running an inline cooler would be possible, just needs custom lines as I don't think someone sells a kit for that. Still waiting on the louvers, depending on those results I might have to get the dedicated oil cooler.
peaches is offline   Reply With Quote
Old 09-13-2019, 11:03 PM   #5115
steved
Drives: 2013 FRS
I've been really hesitant to cut into the hood. If I can't get this system to cool properly I'll end up putting the car back to stock and selling it.
So I'm still working out how to better direct air flow through the radiators. Building on CSG Mike's suggestion of trimming the little wings at the front air inlet, I've removed them and boxed the intercooler in with some thick rubber material. I also boxed in the bottom/top/sides between the intercooler -> radiator around the SC cooler so air has nowhere to go but intercooler -> SC cooler (and around it) -> radiator. I didn't take any pics of the inside work (its nothing pretty that's for sure) but I did take a before / after of the front bumper area.
Before:
https://photos.app.goo.gl/ijkFhHdwSvEndyj4A
After:
https://photos.app.goo.gl/qNxQ6UqCoCJeYE9fA
I'm headed back to the track next Friday and so far the temperature should be roughly in the middle of the last two events when I was overheating. I'll post an update and maybe some more pics if I pull the bumper cover off before then.
steved is offline   Reply With Quote
The Following User Says Thank You to steved For This Useful Post:
CSG Mike (09-14-2019)
Old 09-17-2019, 05:39 PM   #5116
stlgrym3
Drives: 2017 Subaru BRZ Limited
less than 3 months left in 2019, and yet still no CARB tune for 2017+ 86 from Jackson Racing?
stlgrym3 is offline   Reply With Quote
Old 09-18-2019, 01:20 AM   #5117
Mr_Eyo
Drives: 2017 Toyota 86
I consider myself lucky to have a 2017 for the Edelbrock kit. For some reason, they got 2017 CARB approved but not 18+. However, if JR got theirs approved for 2017, I'd switch in a heartbeat because of that stupid vacuum actuated bypass valve.
Mr_Eyo is offline   Reply With Quote
Old 09-25-2019, 12:07 AM   #5118
steved
Drives: 2013 FRS
Before:
After:
The only thing I accomplished was getting into the 260's slightly slower. I ended up running with heater on full again in 74F ambient temp at the peak of the day and hitting 267F oil temperature. Earlier in the morning it was quite a bit cooler (somewhere around 65F) and the temp would stay 257F with heater on full. This was running on a large ~5km track in 20 minute sessions.
I would say the JR dual radiator oil cooler is _not_ up to FI track duty and the product page for it should list this explicitly.
Over the winter I'll rip it out and go with a dedicated oil cooler. I've read a few threads where people have noticed the ECU pulling timing above 230F, and seen a dyno video where multiple runs had power results all over the place as the ECU appears to be extremely sensitive to temperature changes. My guess is with FI this car can only be adequately cooled for hard track use with a very large cooler.
Seeing as I'd really like to be running <230F at full tilt I don't think I'll give the JR track cooler a shot, I'm looking to piece together my own larger cooler as I don't drive the car in the winter.
Here's some pictures of my arts and crafts project to create a air shroud around the different cooling components for anyone's future reference:
Old 09-25-2019, 03:55 PM   #5119
peaches
I haven't received the louvers yet but that tells me I'm going to have to get the dedicated oil cooler anyway :/
Old 09-30-2019, 01:03 PM   #5120
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
I was curious too so I emailed them and they replied back saying they'll have a "2017+ CARB legal certification available in the near future".
NaturallyAspirated is offline   Reply With Quote
Old 10-04-2019, 06:58 PM   #5121
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
Two questions:
1. Are there any vendors outside California for the JR C38 system for a 2015 FRS (to avoid sales tax)? Feel free to pm me.
2. Is the JR oil cooler the best option to complement the C38 system?
Thanks in advance! Have a great weekend.
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 10-04-2019, 10:07 PM   #5122
pcs
"are there any vendors that are willing to purposely and willfully help me evade sales tax?"
pcs is offline   Reply With Quote
Old 10-04-2019, 10:14 PM   #5123
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
...also known as legally selling a product. In California, there is a line for out-of-state purchases on our tax returns.
Old 10-07-2019, 11:35 AM   #5124
sroby
Drives: 2015 Firestorm 08/05/15
They want us in the car community to pay for all their liberal social asinine policies. Come on California wake up, vote these idiots out of office, so you can at least change your damn oil in your own drive way. Place has lost their mind. So glad I have moved my grandson out of Sacramento back down to north west Ga.
y’all just take down the flag as the last person leaves
sroby is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
