go_a_way1
Old 10-04-2021, 08:02 PM   #5055
downshiftxlr8
downshiftxlr8's Avatar
Drives: 2020 86 Hakone
Do you have a complete modification list and alignment spec?
Intake
Brake Lines
Hawk HP+ (F/R)
Exhaust (Headers, front pipe, cat back)
and a Tune for 91
Nothing done to the suspension yet, just started tracking this car this year after being away for some years so wanted to start slow and learn more about the car before going to far off the deep end like I did with my last car.
downshiftxlr8 is offline   Reply With Quote
Old 10-04-2021, 08:08 PM   #5056
Originally Posted by downshiftxlr8 View Post
Intake
Brake Lines
Hawk HP+ (F/R)
Exhaust (Headers, front pie, cat back)
and a Tune for 91
Seems you need camber.
Bolts for a cheap solution, plates for a proper solution.
Kelse92 (10-04-2021)
Old 10-04-2021, 08:57 PM   #5057
strat61caster
strat61caster's Avatar
I haven't changed the suspension at all, how much camber do these cars like to run front and rear ?
F -3 to -5
R -2 to -3
Currently I'm on -4F -2.5R, but I'm a filthy autocrosser, I still wear the outside edges with stiffer springs and front roll bar. Rears wear more evenly then fronts because MacPherson struts vs multi link.
ineedyourdiddly
Old 10-04-2021, 10:34 PM   #5058
downshiftxlr8
Awesome , thanks for the advice!
Old 10-04-2021, 11:50 PM   #5059
Also, check out 86cup.
86cup.us
mixxxx (10-07-2021)
Old 10-04-2021, 11:56 PM   #5060
downshiftxlr8
86cup.us
I was out at the last event , met a lot of fun folks, going to be at the one at the end of this month ?
The Following User Says Thank You to downshiftxlr8 For This Useful Post:
CSG Mike (10-05-2021)
Old 10-05-2021, 11:10 AM   #5061
J95
J95's Avatar
Hey Mike
I plan to install an oil cooler. Do you think it is worth it to get one that is not attached in the front bumper? (to avoid potential failure/rips due to possible off tracks)
I have this in mind:
https://avoturbo.com/brz-frs-86-fa20...il-cooler-kit/
Compared to an used Mishimoto that I can get much cheaper.
J95 is offline   Reply With Quote
Old 10-05-2021, 01:10 PM   #5062
Originally Posted by J95 View Post
Hey Mike
None of the oil coolers I'm aware of attach to the front bumper.
I have a used Perrin (with setrab core, no the chinese cores) for sale.
I would recommend a Jackson Racing or GReddy oil cooler. Both are in stock at CSG.
J95 (10-05-2021)
Old 10-05-2021, 05:12 PM   #5063
J95
J95's Avatar
Ok thanks! Im from Europe, but thanks for the offer
On the other hand, could you please tell me what would be some appropriate next steps for my set up? Aparte from the oil cooler.
The usage is roadtrips on weekends and occasional track days (6-8 per year). Not daily but frequent trips. Current set up:
Code:
Rays gram lights 57CR 17x9
Tires Yoko v105, but planning to get some semi slicks 245 40 17 soon
K&N replacement filter
Steel brake lines HEL + RBF 600
Brake pads PFC Z rated
Eibach pro kit lower springs
Camber bolts
JDL Headers 4-2-1
OFT stage 2+
Alignment:
Front Toe -1° -1°
Back Toe 0° 0°
Front camber -1.2° -1.5°
Back camber (stock) -1.8° -1.6°
Old 10-05-2021, 05:13 PM   #5064
Code:
Camber bolts
JDL Headers 4-2-1
OFT stage 2+
Alignment:
Front Toe -1° -1°
Back Toe 0° 0°
Get a track alignment, a proper tune, and upgrade the brake pads/fluid.
J95 (10-05-2021)
Old 10-05-2021, 07:05 PM   #5065
J95
J95's Avatar
What do you mean by proper tune? I have no reliable tuners in my area, plus I already purchased the OFT (not cheap in Europe ). Is something better than stage 2+ that I can do with the OFT?
And what would be your suggestion for the alignment? I would not want to compromise too much the tire wear when driving milles in the roadtrips
Old 10-05-2021, 07:41 PM   #5066
Align via what the pyrometer says. 949 has an excellent guide here.
http://949racing.com/using-a-tire-py...49-Racing.aspx
Get a proper Ecutek tune. You do not need the tuner to be local to get tuned. The vast majority of 86 tuning is done remotely.
J95 (10-06-2021)
Old 10-06-2021, 08:25 AM   #5067
J95
J95's Avatar
Ok thanks! But after investing in OFT I would like to stick to it (to Europe the price increases a lot, same for ecutek). Any customized ROM by wayne or similar should be also fine?
I have one last question though. I am worried about lubrication problems when using semi slick 245 and long right hand turns. I heard some people broke the engine because of the pump not reaching enough oil. How necessary is a Sump Baffle Plate then?
Old 10-06-2021, 01:58 PM   #5068
"cheap insurance". I've seen slick equipped cars on banked tracks run without issue.
I Have no opinion on Wayne's ROMs, as I've never seen a car with one running in person.
J95 (10-06-2021)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
