07-14-2014, 06:10 PM | #5027 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
So here's what we got.
We made a few of these to test the waters, basically a 3" MAF housing, support arm, and giant K&N filter. This is a huge amount of filtration area and it just clears the AC lines etc. And an engine bay shot of the prototype (plain and made of scrap sections, new ones are one-piece, this filter is 5 years old and hasn't been cleaned!) Note that with some oil coolers you may need to move it a bit closer towards the front. There's enough bracket on there so you can easily cut the end and drill a new hole. Black and blue available as of today, we will make black, blue, and red for inventory later this month. Yellow is spoken for so that's August delivery. Please understand the merits of a large surface area vs a cooler charge. We have been testing this setup on both pump gas and ethanol, with the 70mm pulley, intercooled and not, summer and winter. With the IC setup you won't notice the heat, on the non-IC setup and pump gas you will when you first take off on a really hot day. With ethanol the 10-15 degree difference makes 0 difference. For reference, the SC flows 445 CFM. You'll empty that engine bay hot air in seconds. This intake is designed for a no compromise flow path. The filter and MAF body are as big as you'll ever need on the 210 (and 335....) Because we're not trying to fit it in the bumper space, the filter size is unrestricted. Replacement filters are a common K&N part. This will give you lots of whine for sure, especially with the 70mm. See our youtube channel for examples. |
The Following User Says Thank You to Xero-Limit For This Useful Post: | mikalem (07-14-2014) |
07-14-2014, 06:31 PM | #5028 | |
Drives: 2013 WRB BRZ Limited
Assuming requires a tune .... any cost for those that have your tune already, or is that additional...?
07-14-2014, 07:28 PM | #5029 |
07-14-2014, 07:32 PM | #5030 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
07-14-2014, 07:36 PM | #5031 |
If it fits you can just cut off the mounting arm. We made this so it can work with the other systems that use the stock airbox, i.e. AVO, NA setups.
Where it sits it has the highest chance of getting cold air though. Putting it back there you're more likely to get the overpipe and heat from the passenger side head. Up front you're right by the bumper. |
07-14-2014, 09:36 PM | #5033 |
That Guy
Drives: 2013 asphalt FRS MT
07-15-2014, 06:09 AM | #5034 |
Super 86
Drives: Red 86 GTS
So anyone who has tapped a boost gauge into the MAP plate, any tips?
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
07-15-2014, 07:31 AM | #5035 |
Grip>Slip
I did it on one of my FA20club IAT plates, but never actually hooked it up since i had stopped using that sensor (and lost the tubing that came with my AEM failsafe). I've got replacement tubing now and may try to see if i can get it back together this afternoon.
The Following User Says Thank You to xjohnx For This Useful Post: | Khorne (07-15-2014) |
07-15-2014, 05:59 PM | #5036 |
The Following User Says Thank You to mikalem For This Useful Post: | Xero-Limit (07-15-2014) |
07-16-2014, 07:32 AM | #5037 | |
Drives: GT 86
Thanks for the reply William, are checking out all my options atm and waiting to see what Sprintex comes up with as well . Cheers sam |
07-17-2014, 06:25 PM | #5038 |
Drives: 08 STI|15 BRZ|95 L Coupe
07-17-2014, 06:31 PM | #5039 |
07-18-2014, 10:35 AM | #5040 |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
