Old 07-13-2016, 12:17 PM   #491
Cartman
Cartman's Avatar
Drives: GT86
Originally Posted by ajc209 View Post
Mine squeal like mofos under medium to hard braking from any speed. Not sure if I have bp20 or bp10. I've got whatever the kit came with.
I've put copper grease between pad and shim and chamfered the leading edge of the pad.
Sent from my SM-G935F using Tapatalk
I decided to order some EBC green stuff... the pads were cheap on amazon... I'll be testing them after this weekends track day and see if they don't squeal... the BP20s are just way to loud to DD.
Cartman is offline
Old 07-13-2016, 12:36 PM   #492
Irace86
Drives: BRZ + Ducati M796
Have you got them really hot yet? any squeal?
Like he said, just squeeking after they warmup on gentle braking.
Irace86 is offline
Old 07-13-2016, 12:38 PM   #493
Irace86
Do those pads cover the whole rotor?
Irace86 is offline
Old 07-13-2016, 12:51 PM   #494
Cartman
Cartman's Avatar
Drives: GT86
Nope, any pad based on the Willwood 7416 or 7420 pad will cover the same area as the BPs...
According to Essex page for the Endurance kit, this are the pads that have mor depth to cover more rotor area.
Carbotech CTFRP3116, Circo MB2660, Endless RCP106, Ferodo FRP3116
Cartman is offline
Old 07-13-2016, 01:02 PM   #495
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I'm running BP10s in front on my SP kit and I have minimal noise. I do sometimes get a bit of squeal under light braking, especially when the rotors are still wet from recent rainfall, but it's not loud and I can just adjust my pedal pressure a bit and it goes away. For the most part, I don't get any excessive brake noise. Sometimes I can hear the fronts release when I let the brake pedal go from a stop but that's about it.
When installing the brake system, I loaded up on anti-seize for all parts that have metal on metal contact, especially around the mounting bolts and the hub so that may help keep things quieter. I didn't use anything on the pads, just dropped them in.
Lynxis is offline
Old 07-19-2016, 05:03 AM   #496
ajc209
Drives: GT86 Cosworth
Just an update. I did have BP20 pads with my sport performance rear brake kit and they squealed really badly once they got hot. On track it was at every corner under braking.
I've fixed it by using EBC self adhesive anti squeal shims between the piston and the metal pad relocation plate.
I got the rotors up to 450F which is about what I see at the track and no squeal what-so-ever.
I am changing the pads to DS2500 though as the temp profile of the BP20 means that as they get hotter I get more rear brake bias which is undesirable.
ajc209 is offline
Old 07-19-2016, 07:57 AM   #497
gt86ser
gt86ser's Avatar
Drives: Toyota 86
pm u Rafi@RR-racing
gt86ser is offline
Old 08-08-2016, 06:28 AM   #498
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Stage 4 worked amazing on track:
[ame="https://www.youtube.com/watch?v=KcHl4vYQBcw"]GT 86 les Écuyers. - YouTube[/ame]
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline
Old 08-10-2016, 01:31 PM   #499
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Is there a rear caliper template? I printed out the front one today but can't see to find a rear one.
TRAKRAVN is offline
Old 08-10-2016, 01:32 PM   #500
klear
Drives: 2002 V7 Bugeye STI/2014 BRZ limited
The rear should clear everything as long as the front clears.
Sent from my SAMSUNG-SM-N910A using Tapatalk
klear is offline
Old 08-10-2016, 01:54 PM   #501
TRAKRAVN
Okay. Thanks for the heads up. I just wanted to make sure I wasn't missing something.
TRAKRAVN is offline
Old 08-16-2016, 12:41 PM   #502
yutinggao
yutinggao's Avatar
Drives: Gr86
Just FYI, stock wheel will need at least 15mm to clear stage 2 caliper.
yutinggao is offline
Old 08-19-2016, 03:46 PM   #503
KayoTrap
I'm looking for 17s that fit stage 2 without spacers.
So far I found thread confirmation that these fit:
TSW Nurburgring 17x8 +35
17x8 +42 WedsSport TC105N
Any other 17s that fit stage 2?
For the record, my 18 x 9.5 +40 57xtremes fit stage 2 no problem.
KayoTrap is offline
Old 08-19-2016, 03:58 PM   #504
MaximeT
MaximeT's Avatar
Apex ARC 8
MaximeT is offline
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
