#491 |
Drives: JAWS
So around 20k miles (like most with this issue) clutch started squeaking, and has progressively gotten worse. I can feel slight crunchiness in end of pedal travel, and it's now happening with car on and off, usually starts after driving for a while. No abnormal TOB squealing or high pitch noises, just this creaking noise:
Dry clutch fork? Or throwout bearing binding on transmission snout? Dreading taking my car to the dealer. [ame]http://youtu.be/hQnkycC_6fQ[/ame] @Ultramaroon |
#492 | |
However, it could be the shaft from the slave cylinder making that sound, which can be lubricated - see discussed methods). I suppose it could be the fingers on the pressure plate .. ?? If our cars have a clutch return spring (a little help here @Ultramaroon), I would place that as the #1 suspect. Good clear video .... humfrz |
#493 |
A.K.A. Starlord
Drives: 2015 Series.Blue
It isn't the clutch return spring. If you have someone depress the clutch while you look under the hood, you'll be able to pinpoint where the noise is coming from.
I got my entire clutch assembly replaced due to this noise, but I think it's already coming back less than 1,000 miles later, so maybe it is just a lack of grease on the clutch fork shaft thing. |
#494 | |
not playing cards
When they drop the transmission make sure they don't just dab grease in there. That snout needs to be fully cleaned. If it is worn or scored, it must be replaced.
#495 | |
Drives: JAWS
#496 | |
A.K.A. Starlord
#497 | |
not playing cards
Something about the clutch mechanism, the materials, the lubricant, something is critically flawed. I think they should lengthen the bushing on the TOB to better prevent binding when it starts to wear. Maybe the specified lubricant sucks. Maybe the bell housing ventilation blows dust from the disk in just the wrong way. So much to consider.
#498 | |
A.K.A. Starlord
#499 | |
not playing cards
Mine is still ok after about 5000 miles but I don't expect it to last forever.
#500 | |
A.K.A. Starlord
#501 |
not playing cards
Show them the crunch now. Less than 1000 miles? I'd be furious.
#502 |
A.K.A. Starlord
I'm not furious because they didn't seem to know what the issue was the first time around, so they just replaced all the clutch stuff hoping that would fix it. Everyone gets a "chance" to fix something as far as I am concerned, and since the replacements they made did solve the problem initially, I don't blame them. The crunch doesn't always happen yet, but as soon as it becomes persistent I'll look into bringing the car in (my schedule is so busy lately it's hard to coordinate that stuff) and hopefully they will take a deeper look at things.
#503 | |
Drives: innovate sc frs
Corn fed, Intercooled Innovate sc tuned by vit viper, perrin crank pulley, raceng 72.5 mm pulley, Tomei EL header, Perrin front/mid pipe and 2.5 resonated exhaust, Cusco oil cooler, dual radium catch cans and more!
#504 |
not playing cards
| Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 08:58 AM |
| Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 02:10 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 04:08 PM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 06:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 01:00 AM |
